Old Nov 19, 2012, 12:00 PM
Dick L. is offline
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Originally Posted by PirateTwisty View Post
Gnome: For all I know, that could be fine. Obviously, the lighter the better, but how light, I just don't know!
Search for their "select" (or Black Label) pine and and you should be able to find some straight-grained stuff - or try Aircraft Spruce (on-line) for nice Sitka spruce - a little spendy, but nice straight, tight grain..
Once you have ripped the stock for the mast blank, you can always split it lengthwise, and run each piece through a router with a square or round bit to make a groove on inside of mast. Then re-glue sides together to form one piece with hollow. I've had good luck gluing in a carbon tube for structural strength before gluing mast back together. Just a thought if you want to fabricate your own and stay with wood, rather than metal.
Good luck with project, boat looks really nice. Dick
Dick L. is offline Find More Posts by Dick L.
Old Nov 24, 2012, 10:38 AM
PirateTwisty is offline
Find More Posts by PirateTwisty
United States, NY, Queensbury
Joined Aug 2012
Dick: Those are great ideas, as well a great excuse to go buy a router! I arrived at a similar end, but by a more roundabout method! By the way, I would have used spruce in the first place if it was easy to find! I will probably go that route before spring gets here, but for now, at least I have something to work with.
So here's my progress report: Made some more shiny things! Upper and lower spreaders, chainplates, mast crane. Started rigging her up with some temporary shrouds and "display sails". Also, decided it was time for some bottom paint.
PirateTwisty is offline Find More Posts by PirateTwisty
Old Nov 24, 2012, 12:21 PM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
Very nice.
Terry
marter1229 is offline Find More Posts by marter1229
Old Nov 24, 2012, 09:48 PM
Joined Aug 2012
So, I am really happy with the bottom paint! And if the long list of warnings on Krylon Fusion spray paint is any indication, it should last forever!
Old Nov 24, 2012, 09:50 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
You should be happy! she looks great!
bgnome is offline Find More Posts by bgnome
Old Nov 24, 2012, 09:54 PM
Joined Aug 2012
So painfully close to done, and I saw the first snow flurries of the season today
Old Nov 24, 2012, 10:29 PM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
Bah! get one of those giant industrial floor fans and sneak into the Nearest YMCA with an indoor pool
Old Nov 24, 2012, 11:12 PM
Joined Aug 2012
We need a "like" button!
Old Nov 24, 2012, 11:48 PM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Yes we do.
MILLERTIME is online now Find More Posts by MILLERTIME
Old May 28, 2013, 10:33 PM
Joined Aug 2012
So, after what seemed to be an endless winter, my Star is finally almost ready for the water! Today, as one final, and slightly terrifying, hurdle, I learned how to cast lead! My skills here show some room for improvement, but it will work, and summer is way too short around here to worry about perfect bulb shape!
Old May 29, 2013, 11:49 AM
planebow is offline
Find More Posts by planebow
planebow's Avatar
United States, MT, Kalispell
Joined Jun 2011
Good to see that you are working on your boat again. I have started to work on mine again as I just bought a bulb. Still have to put the deck on mine. I realy like your deck and have been thinking about doing something very similar.
planebow is offline Find More Posts by planebow
Old May 29, 2013, 03:48 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
The bubbly surface is either a cold/moist mold or cold material. I've had good luck baking the mold in the oven on low (250 degrees?) for a while just before you are going to pour the molten lead. It's amazing how much moisture builds up in plaster when it sits around. Or you could make the mold slightly oversized and shape the outside of the cool lead with a rasp and file. Always remember that lead is nasty stuff. Gloves, mask, wash hands, etc.
Boat looks nice, by the way.
Dave
boater_dave is offline Find More Posts by boater_dave
Old May 29, 2013, 09:06 PM
Joined Aug 2012
Dave, even after baking at 275 for a couple hours, the molds still had some moisture. I knew that, just ran out of patience! (the bondo is drying now!)
Old May 30, 2013, 12:02 AM
Joined Aug 2012
Ok! Keel done, electronics installed.....I would never call her "done", but by God, I think it's time to go sailing!
Old May 30, 2013, 09:08 PM
Joined Aug 2012
Today was the day! The maiden voyage went off without a hitch! If only I'd had a really small bottle of champagne
For Sale Beautiful Star 45 Hull For Sale!!!! PingChandlerPong Boats (FS/W) 0 Jun 21, 2012 02:39 PM
Sold Vintage Dumas Star Class 45" sailboat kit nero1156 Boats (FS/W) 3 Apr 06, 2012 07:28 AM
For Sale Vintage Dumas Star Class 45 glass hull kit nero1156 Boats (FS/W) 0 Mar 12, 2012 07:07 PM
Discussion PRO-STAR "A star is born" superdave42 Coaxial Helicopters 17 Apr 17, 2008 12:50 PM
