Old Aug 09, 2012, 09:38 PM
j2591 is offline
Find More Posts by j2591
Joined Apr 2012
Question
How do you know what part is bad?
I need to get my Mini CP back in the air and I'm not quite sure what component(s) are causing my issue. The Mini started having short flight times so I bought a couple new batteries but they didn't make any improvement. Now it doesn't have enough power to get off the ground more than a few inches.
I suspect the main motor is probably to blame but I have also noticed there is some vibration. The blades appear to be tracking fine. I'm suspecting probably replace the motor and check the blades and some of the other components such as the feathering shaft.
All this got me to thinking... what about bearings? How do you know when to replace any of those? When do you lubricate them?
I would appreciate any sage advice to help me get back in the air without having to replace half of the heli
Larry
j2591 is offline Find More Posts by j2591
Old Aug 09, 2012, 10:12 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Your first course of action is to check your battery voltage before and after each flight attempt. Otherwise, you are just taking wild guesses.
Balr14 is offline Find More Posts by Balr14
Old Aug 10, 2012, 01:35 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Assuming the new batteries are ok, and not maltreated, or drained too far, which can wreck a lipo in a single flight, I would say it's either the motor, or a connection somewhere, causing high resistance, and as a result more voltage drop.
SoloProFan is online now Find More Posts by SoloProFan
Old Aug 10, 2012, 09:42 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I have had several bad chargers with Walkera micro helis that cooked the batteries after a few charges. That's why I always check the voltage.
Old Aug 10, 2012, 10:32 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
You really need to do a visual check of your pitch curve first. It is possible that you just do not have enough positive pitch to take off. Is the collar pressed down firmly?
zadaw is offline Find More Posts by zadaw
Old Aug 13, 2012, 07:39 PM
j2591 is offline
Joined Apr 2012
The madness continues...
So I have been trying to sort all this out and found a few things, but I'm still not quite off the ground yet.
First, I checked the blade pitch and found it was off. Turns out the main gear had moved on the main shaft. Next I got a couple other new batteries and used a different charger. ...things got a little better. I think I'm on the right track and should be able to get most issues fixed by trimming and replacing suspect parts.
The only issue I'm not sure about is the tail spin. It's an issue I have had since I got the Mini. To keep it from spinning wildly I have to turn up the subtrim to R 36.5 but as you change the throttle it doesn't hold the heading. I have checked the settings and can't figure it out. It's like having tail blowout. If you have ever flown with a cracked tail blade you understand what I mean.
Any ideas what might be happening?
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Discussion How do you know when your springs are "right" Bugman Jeff Off-road Cars 2 Jul 11, 2012 04:52 AM
Discussion How Many R/C Helicopter Brands Do You Know? mushia Electric Heli Talk 5 Jul 08, 2012 09:08 PM
Discussion Catching a thermal, whats it like, how do you know? what should you do? GreenAce92 Thermal 25 Mar 11, 2009 05:21 PM
Shanked??? how do you know you have a bad seller?? pval3 Aircraft - Electric - Airplanes (FS/W) 43 Jan 22, 2003 06:31 PM
