Old Aug 09, 2012, 04:05 PM
ServoCity is offline
Find More Posts by ServoCity
ServoCity's Avatar
United States, KS, Winfield
Joined Jun 2011
New Product
Hitec HS-430BH Servo - now in stock!
New at ServoCity!
http://www.servocity.com/html/hs-430bh_servo.html
Based on the popular HS-425BB, the deluxe ball bearing HS-430BH is a budget-minded analog servo capable of 6.0 to 7.4 volt operation. Designed with the novice hobbyist in mind, this low cost servo can be used for control surfaces on beginner airplanes and as a throttle or replacement servo for many ready-to-fly models. Its excellent durability and dependability make it a solid choice for beginner pilots.
Starting at just $14.49
You can order this servo pre-modifed for 180 degrees, reverse operation, or continuous rotation from ServoCity.
Detailed Specifications:
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 6.0-7.4 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (6.0V): 0.16sec/60 at no load
Operating Speed (7.4V): 0.14sec/60 at no load
Stall Torque (6.0V): 57 oz/in.
Stall Torque (7.4V): 69 oz/in.
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Dead Band Width: 8usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Indirect Drive
Bearing Type: Top Ball Bearing
Gear Type: Nylon
Connector Wire Length: 11.81" (300mm)
Dimensions: 1.59 x 0.77 x 1.44 (40.6 x 19.8 x 36.6mm)
Weight: 1.6oz (45.5g)
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
New Product In stock! Hitec HS-7115TH Ultra Slim Wing Servo! ServoCity ServoCity.com 0 Jul 06, 2012 04:21 PM
New Product Hitec X4 Eighty Multi-Charger now in stock! ServoCity ServoCity.com 0 Jun 13, 2012 08:37 AM
New Product New Hitec Servos in stock! The HS-5565MH & HS-5585MH are here! ServoCity ServoCity.com 0 May 02, 2012 11:14 AM
New Product Hitec Waterproof Servos now in stock! ServoCity ServoCity.com 0 Apr 09, 2012 03:34 PM
New Product Hitec Eclipse 7 Pro (2.4Ghz) now in stock! ServoCity ServoCity.com 0 Feb 23, 2012 09:22 AM
