Old Aug 09, 2012, 04:40 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
dynam sonic 185 battery upgrade
so i have this sonic 185 glider on the way, i ordered a 7.4 battery, and after it had shipped i noticed the battery said for Car ! crap ! so im wondering can i use a 11.1v battery,plane has a 30amp esc,so what would i have to change to use 11.1v ? if not ill just order a different 7.4v battery. whats different between a car and a plane battery ?
fastfwd is offline Find More Posts by fastfwd
Old Aug 09, 2012, 05:45 PM
fastfwd is offline
Joined Mar 2012
answered my own question. searching forums i see some folks are using 11.1v batteries, they say not to keep full throttle for long periods as motor will heat up. Its a glider so full throttle isnt needed But if a guy went with say a 45 amp esc would that not keep the motor cooler ?
Old Aug 09, 2012, 08:47 PM
john50049 is offline
Find More Posts by john50049
Joined Feb 2011
Wouldn't keep the motor cooler. Might keep the ESC cooler. I fly my 185 with 11.1volt battery
john50049 is offline Find More Posts by john50049
Old Aug 10, 2012, 01:14 AM
fastfwd is offline
Joined Mar 2012
any problems ? my sonic 185 has a 30amp esc, is that what your has ?
Old Aug 11, 2012, 12:05 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Replaced the stock 30A ESC with 50A, using 3S 2200mah with no evidence of motor overheating.
Doubletap is offline Find More Posts by Doubletap
Old Aug 11, 2012, 07:28 PM
fastfwd is offline
Joined Mar 2012
Good deal, i read alot of guys replacing with at least a 40 to 45 amp esc, so ill get one coming, runs fine with the 11.1v 2200mah i put in it.
Old Aug 12, 2012, 12:10 AM
tripleup05 is offline
Find More Posts by tripleup05
tripleup05's Avatar
United States, GA, Grayson
Joined Mar 2008
I fly mine with a 3S and stock ESC. I rarely go full throttle, though. The wings flutter a bit too much for my taste when I try and fly it like a hotliner
tripleup05 is offline Find More Posts by tripleup05
Old Aug 12, 2012, 10:38 PM
fastfwd is offline
Joined Mar 2012
Maiden flight today ! Just flew perfect ! no trimming at all,1600mah 11.1v battery got little hot and only flew for like 6 minutes, so im ordering bigger esc and a 2200 11.1v battery. But i am very happy with this sonic, lots of power and floats like a hummingbird ! Now i did add some weight to tail end,and 4 small wood screws in right wing to get it to balance, i did that in my kitchen
Discussion Dynam Sonic 185 help needed Devine99 Parkflyers 4 Sep 10, 2012 12:31 PM
Sold Dynam sonic 185 LPU Only ARF SOCAL Kmdo Aircraft - Sailplanes (FS/W) 0 Jul 06, 2012 01:33 AM
Sold Dynam Sonic 185 Glider ARF dbc Aircraft - Electric - Airplanes (FS/W) 2 Mar 25, 2012 09:06 AM
Discussion Dynam Sonic 185 RXTX Upgrade limbatus Electric Sailplanes 5 Feb 03, 2011 12:59 AM
