Old Oct 15, 2012, 04:05 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by jsipprell View Post
I suspect that under such exacting circumstances, JR/Spektrum (and perhaps others) radios might exacerbate the issue because of "Servo Sync" which attempts to drive pairs of servos in tandem.
Yes, but the rx in question does not support that, so it's not a contributing factor for Tom's repeated crashes.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Oct 15, 2012, 04:07 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by richard hanson View Post
Your engines did not have a servo operated throttle ?
On those basic FF-assist planes with ignition engines, the THRO channel goes to the ignition for using the failsafe (or they use an AR6255 instead of AR600).
Andy
Site Sponsor
Old Oct 15, 2012, 04:40 PM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Andy. under interference conditions (Not Brownout)
blocking Both DSM2 Rf links. is the below true or false ?
"if the F/S event was too long, the receiver would then take a 3-5 seconds to reconnect,"
Reflex1 is offline Find More Posts by Reflex1
Old Oct 15, 2012, 04:45 PM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
I don't believe we are talking about a "brownout" here. The alleged problem was induced on the ground by forcing a hold for more than one second (or so), not by dropping voltage on the rx. Adding additional conditions only serves to complicate understanding/testing the problem.
Agreed
Old Oct 15, 2012, 05:07 PM
mybad is offline
Find More Posts by mybad
Sure, I can fly after sunset!?
United States, MI, Novi
Joined Jan 2011
My Experience!
One year ago, I bought a DX6i.
At a swap meet. It was used.
It had been repaired prior to this. Not sure what the repair was.
Everything was great at first. Then, I broke the antenna. I jury rigged it.
Then, I broke the aileron trim.
Several months ago, I crashed three planes due to a range problem. I SHOULD have done a range check, but like most people (?) I did not. Afterwards, I discovered that I failed the range check at about 15 feet.
I set the DX6i aside and "made do" with the DX5e that came with my Radian.
Finally, after several months, I decided to contact HH. $25 minimum charge for 1/2 hour bench time. Well, I thought about junking it and buying a new one. Who knows how much this would cost? But, I decided to throw caution to the wind and mailed it in.
A couple days later, I got an email verifying that my package got there.
The next day, I got an email stating that the work was complete and it was being shipped back to me!
I got it today ... opened the box ... and there was my DX6i, looking as good as new. The invoice had this note...
IN THE SPIRIT OF CUSTOMER SERVICE, YOUR DX6i HAS BEEN OUTFITTED WITH A NEW ANTENNA, RF DECK, AND TWO NEW SWITCHES FREE OF CHARGE! THE UNIT HAS BEEN TESTED FOR BIND, RANGE, FUNCTION, AND OUTPUT STRENGTH, AND ALL TESTS INDICATE A FULLY FUNCTIONAL TRANSMITTER. IF YOU HAVE ANY FURTHER QUESTIONS OR CONCERNS, PLEASE CONTACT OUR PRODUCT SUPPORT TEAM AT 1 877 504 0233. THANKS.
They fixed the range problem and all the other problems. I didn't even know there was a problem with a second switch!
NO CHARGE!
And all this for a unit that I TOLD THEM I bought second hand!
How is THAT for CUSTOMER SERVICE?
Thank you Horizon Hobby!!!
mybad is offline Find More Posts by mybad
Old Oct 15, 2012, 05:17 PM
Mikecam is offline
Find More Posts by Mikecam
Mikecam's Avatar
Canada, MB, Winnipeg
Joined Apr 2008
Too bad range issues with your DX6i cost you 3 planes!!!!!!!
Mikecam is offline Find More Posts by Mikecam
Old Oct 15, 2012, 05:39 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Did you read the whole story? The guy is blaming himself for having so many mishap with his Tx, then failing to do range testing (I guess particularly after the first crash), and you say it's the abused DX6i's fault for crashing 3 planes.... Wow!!!!
RealGambler is offline Find More Posts by RealGambler
Old Oct 15, 2012, 05:43 PM
Mikecam is offline
Mikecam's Avatar
Joined Apr 2008
Originally Posted by RealGambler View Post
Did you read the whole story? The guy is blaming himself for having so many mishap with his Tx, then failing to do range testing (I guess particularly after the first crash), and you say it's the abused DX6i's fault.... Wow!!!!
Pretty much sums up the Spektrum mantra,
it can't be the radio so it must be the user.
Old Oct 15, 2012, 05:45 PM
mybad is offline
Joined Jan 2011
Yeah, but the instructions with the planes and the radios state that you should always do a range check. THAT was my fault!
Prior to the first crash, I was puzzled by intermittent lack of control when the plane was further away. Everything was OK again when it was closer ... so I flew it further away again. Lost control again, but this time I cut the motor and it crash landed.
I wasn't sure what was wrong. Must have been something with that plane? So, I pulled out my Radian. Same thing happened. Must be the TX I thought.
So, I pulled out my third plane, a HZ Super Cub, and decided to just fly it close. Worked for a while! Then, I flew it further away and another crash landing.
I'll chalk it all up to a Senior Moment!
Fortunately, I was flying over high grass and shrub next to a soccer field. The crashes were not bad; nothing that some CA and a hot glue gun couldn't fix. I had them up and flying the next day ... but with my DX5e.
If I had done the range checks (I do them now!) I probably would have avoided all the crashes, or at least the last two.
Amazing how being in a hurry usually costs you time in the long run.
Old Oct 15, 2012, 05:51 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Thank you for your integrity even when being bullied by haters. It says a lot about you - you're a "real man!"
And thanks again for buying Spektrum (even second-hand!)
Andy
Site Sponsor
Old Oct 15, 2012, 05:52 PM
Canada, QC
Joined Oct 2009
He blamed the 3 crashes on himself, but you blame the radio. He said the radio was broken from prior abuse, and was fixed for free anyway. Truly, you cannot read!
Old Oct 15, 2012, 06:02 PM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
I applaud you for admitting your errors
at least you learnt a lesson you won't forget.
I wish you good luck in the future
Old Oct 15, 2012, 06:56 PM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
No, it's not necessary
RyanNX211 is offline Find More Posts by RyanNX211
Old Oct 15, 2012, 08:16 PM
mybad is offline
Joined Jan 2011
Andy
You're welcome, but I don't really feel like I'm being bullied. We all have differences of opinions, and sometimes they become so concrete that there is little chance of changing them. I've got some myself, but we won't get into that here.
No product is perfect, but I'm pretty satisfied with what I have. And so far, I have 4 Blade helis, a HZ Super Cub, a Radian, and a PZ S.E.5a. THESE were all bought new, in the past 22 months. And, I'm having a ball.
Old Oct 15, 2012, 10:48 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Oh that's sorta like my old ignition engine!
richard hanson is online now Find More Posts by richard hanson
Discussion Another reason why we hate lawyers dll932 Life, The Universe, and Politics 37 Jul 02, 2012 04:30 PM
Rant this is why i hate fee bay bethelflier8036 Other Websites 6 Apr 18, 2012 01:22 AM
Why do birds hate model planes ? Feodosia Flyer Electric Plane Talk 14 Jun 28, 2001 04:19 AM
