Old Feb 22, 2013, 09:43 AM
Manny BUSTOS is offline
Find More Posts by Manny BUSTOS
Joined Nov 2012
Originally Posted by HappySundays View Post
Sigh.... Manny! Please read the last few posts.
I put a big warning up to make sure people set up their radios properly because if they don't ...
The RC will REVERSE on you!
...as you just found out.
It's not a problem with Beta 8, it's a problem with the way you set it up.
I did post about it but there are also instructions in the new V1.1 Beta 8 guide and in any case you MUST check RC polarity in all modes before flying.
I think this is what your problem was with earlier Betas.
Oh and the thing with the rudder will be because you either:
1: didn't calibrate the sticks or
2: are using your TX to trim the model
Use the Offset settings to trim the model with all TX trims at zero.
From the first post:
I will run through the setup again. I followed the new guide and did all of the steps as per the guide........ as far as the rudder... all of my planes are flown without any boards and mechanically trimmed with no sub trims or trims what so ever it is how I do every plane . Then once the cg is right and the plane performs as it should I add a board.. I will run through the set up again. Thanks
Manny BUSTOS is offline Find More Posts by Manny BUSTOS
Old Feb 22, 2013, 10:14 AM
Kartika is offline
Find More Posts by Kartika
Joined Sep 2012
Yes, beep sound every time when i press the menu buttons or moving up or down the menus and "no signal" beep too ... except the "low batt" because there are no devices and "high throttle" because it uses PWM.
unusual only in terms of "lost model", OK will be checked again
Or do you have another idea for the sound when the model lost between 2 meters high grass? for example failsafe beeper or other
regards,
Kartika is offline Find More Posts by Kartika
Old Feb 22, 2013, 10:58 AM
Joined Nov 2012
Ok ran through the set up again and all good I will go for a test flight when the wind dies down....The part that I messed up , on the last set up was not putting the sticks full forward and right I found that both my channels were reversed this made all of the difference in the set up. Maybe should be in red ink and bolded for people like me . Because I remember reading it but for some reason I did not move the sticks... The rudder problem is gone too ..... cant wait to test should be great.... I would like to make a donation for all your hard work . What is the pay pal fee and your average donation???
MB
MB
Old Feb 22, 2013, 11:47 AM
papirus is offline
Find More Posts by papirus
Ukraine
Joined Jun 2010
Give it a go and tell me how it works out.
Hello Conducted the first test of the stabilization of weapons on the model of the tank. Use firmware beta 4 (stable). Rotating Tower of gyro, but still want that worked from the accelerometer. I will try another Multiwii.
2-axis stabilizer guns on the rc tank BMP-2M (3 min 42 sec)
papirus is offline Find More Posts by papirus
Old Feb 22, 2013, 03:04 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
There have been so many firmware changes in the past month or so that
I am confused as to which version is the best now for CAM STAB only?
harrym is offline Find More Posts by harrym
Old Feb 22, 2013, 03:43 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
I haven't tested CAMSTAB in V1.1 Beta 8 so maybe V1.0 is still the best.
HappySundays is offline Find More Posts by HappySundays
Old Feb 22, 2013, 03:46 PM
Joined Feb 2011
MB
Hi Manny,
Good idea, I have made the note in large red text on the first post
You don't have to donate of course, but if you do want to feel free.
I am not sure of the average but $5 is a fairly common amount.
Thank you! I hope your next test flights go well
HS
Old Feb 22, 2013, 04:00 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
Ok, thanks Hap!
Old Feb 22, 2013, 07:47 PM
Joined Nov 2012
Hi Manny,
HS
Wind was wipping today but I could not wait and it flew like it was on railes . Both modes worked perfect ... I had it into the wind in stabilized and it took all the bumps out almost like there was no wind .I had it into the wind in stabilized and auto level and it flew backwards and level with no in put from the radio.. I did a stall level wing high up just pulled back and cut the motor, the wing was level and got blown backwards but never went out of control just lightly touched down with no ailrone input ... I am soo happy that everything is working now.. installing on my combat wing now cant wait.. My donation will come in probably under my wife's name (our pay pal account)but last name will be Bustos
MB
Old Feb 22, 2013, 10:55 PM
Joined Feb 2011
Yay! I'm so pleased that you have got it working
Old Feb 23, 2013, 08:48 PM
Cadriel is online now
Find More Posts by Cadriel
Joined Sep 2011
Hey y'all.
Just had a KK2.0 become a spare so I decided to stick it into my AcroMaster. Plugged it all in, worked through the setup guides - and it all seems to be behaving nicely. I haven't taken it up yet but all control surfaces seem good. I have a couple of quick questions though;
1) I can't seem to find any tuning guide. I've never tuned a plane with stabilisation before. Will the defaults suffice?
2) I notice you guys mentioning dynamic P tuning with a POT. I don't have any inputs left once I've setup the model with the KK2.0. Are you just unplugging the gear / stab channel and using a pot during your first few flights or what?
Thanks!
Cadriel is online now Find More Posts by Cadriel
Old Feb 23, 2013, 09:55 PM
Joined Feb 2011
Originally Posted by Cadriel View Post
Hey y'all.
Thanks!
If you have a receiver that supports CPPM (all channels on one wire) you can use all 8 channels.
Personally I have mine like this:
CH5: Second aileron
CH6: Dynamic gain input
CH7: Stability
CH8: Autolevel
If you don't have one of these then yes, you're stuck.
Tuning is quite related to the model so it's hard to comment much on tuning.
But it is similar to most PID systems - too much gain leads to oscillation etc...
Old Feb 24, 2013, 12:14 PM
microdave is offline
Find More Posts by microdave
elk
Joined May 2001
A question about B4_1.hex file. I loaded this file to the KK2 board around the end of Dec. Is this the same FW you talk about on the first page as beta4? Has there been any changes sense Dec?
thanks
microdave is offline Find More Posts by microdave
Old Feb 24, 2013, 12:57 PM
rceccleston is offline
Find More Posts by rceccleston
Joined Feb 2009
thanks
Please refer to the release notes in the first post.
rceccleston is offline Find More Posts by rceccleston
Old Feb 24, 2013, 02:04 PM
Trulsen is offline
Find More Posts by Trulsen
Joined May 2010
Is it much work to take out the CamStab stuff and release them as a dedicated CamStab Beta version?
Trulsen is offline Find More Posts by Trulsen
Discussion OpenAero open-source stabilisation software for KK boards HappySundays FPV Talk 1916 Apr 10, 2016 02:47 PM
Discussion CL-OSD a open source osd software for E-OSD and G-OSD callelj FPV Equipment 4152 Jan 19, 2016 05:17 AM
Discussion NeXtcopterPlus open-source release for KK and KK+ boards HappySundays Multirotor Electronics 812 Jan 09, 2013 03:10 PM
Poll New tightly integrated, fast Open Source IMU/Autopilot board for student competitions pixhawk Chit Chat 0 Aug 04, 2010 04:48 AM
Discussion Open-source foam cutting software for XP moreil The Builders Workshop 125 Sep 04, 2008 03:06 PM
