OpenAero2 open-source stabilisation software for KK2 boards
UPDATE: V1.2 Beta 8 with new features and bugfixes
Bugfix - V1.1 (Release) suffered a last-minute bug in the real-time servo trim and limit code that causes the servo movement to be wrong. - V1.1.1 (Updated) fixes this bug. - V1.2 Beta 8 acc calibration bug fixed Version 1.1 Final Release Please ensure you read the manuals in the following order.
Version 1.2 - Beta 8 - Servos are continually updated when no button pressed. - RC channel names changed to suit JR/Spektrum. - Added switchable output mixers. - Added intelligent RC sync speed algorithm. For RC rates slower than 60Hz, PWM output is after each input pulse/packet For RC rates higher than this, the PWM output is limited to 50Hz if "Servo rate" is LOW RC rate now also tied to "Servo rate" seting so that if "Servo rate" is HIGH, higher rates can be used. - Tweaked Satellite bind timing to be exactly like the real thing. - Shrunk memory requirements a bit. - Fixed bug where settings were lost before repowering after a reset - Fixed bug where autolevel calibration wrong unless inverted calibration also done. Version 1.2 - Major updates from V1.1 - Added support for XPS Xtreme serial protocol - Added support for Spektrum serial protocol - Added support for Futaba S-bus serial protocol - RC inputs display now shows all eight RC channels. - Removed logo, added new faster startup messages. - Added master/slave binding for Spektrum Satellite RXs at power-up - Three configurable flight modes with PID etc. - Added axis-specific gyro modes - Auto-presets when changing gyro modes - Completely reworked/simplified PID gyro input code for I-terms - Added flap deployment speed (0 = normal, 20 = super slow) - Added RC deadband adjustment. - Sensors now have three states - OFF/ON/REV - Added four phantom channels (PSU9 to PSU12) for mixing tricks - Stick rate changed to "Lock rate" and only affects Axis lock mode. - Fixed bug where M8 could not go to 125%. Output code now covers -135% to 135%. - Completely changed the value editing menu code so that servos are (almost) continually updated. Version 1.1 - Major updates from V1.0 Based on OpenAero2 Beta 4.1 code - Stability and Autolevel switch setpoint adjustment - Main mixers can now cross-mix up to four channels - Launch delay mode - Added HANDSFREE autolevel modes (autolevel at centered sticks) - Added working differential mode - Added IMU fixes for inverted flight. New inverted calibration mode - New I-term modes: Normal, Auto and 3D. - Completely changed PID loop to take sticks into account. - Added Dynamic gain setting. - Added "Upside down" orientation. - 3D-mode RC input scaling now menu settable. - New failsafe menu and items. - Restore submenu position if going back into the same submenu. - Changed Flying Wing mixing to on-board only. - Add IMU mode switch (Normal/Advanced.) - Added primary channel reversing in RC setup menu. - Changed mixer order and added "Source mix" manual option. - Fixed flap handling in stabilised modes. - Linked local G measurement with IMU calculation to solve negative G and coordinated turn issues. - Increased autolevel trim response x 4 - New servo menus added, menus edited. - Added real-time servo updating for min/max/trim adjustment. - Added unused RAM usage meter in status screen. - Added basic aileron differential setting to RC menu - Level meter responds properly in all orientations - Added stick calibration screen for people who won't read manuals - Added second aileron reversing independent of main aileron and added success confirmation. - Battery alarm can be reset by cellcount = 0 - Added "Sideways" orientation. - Dropped default min cell voltage to 3.3V - Adjustable launch delay added. Launch resettable if throttle cut within the launch delay. - Updated PWM output driver to have XPS-style staggered outputs - Allow real-time servo position setting of failsafe positions. - Integrated ninja-level PWM code generation concept suggested by Jim Drew of Xtreme Power Systems - Increased inter-PWM spacing to 128us and recalibrated all PWM routines. - Fixed lack of throw in Flying Wing mode. Known bugs V1.1 - Servo trim and limit real-time adjustment broken. See V1.1.1 for fix. V1.1.1 - OUT 7 and 8 (M7 and M8) may not be able to honour 125% servo travel and may suddenly reverse is asked to do so. Until a fix is available, please limit the positive servo travel of OUT7 and OUT8 to 100%. This bug would also be in V1.1, but not V1.0. V1.2 Beta 3 - Some digital servos may not move correctly in servo trim and limit setup mode. This would also apply to a greater degree to earlier versions. - Autolevel calibration and will result in the wrong values for "Z" unless the inverted calibration "Inv. Cal." is done. After you've done a calibration the Acc Z value should show a value something like 124, not zero. Simply doing the inverted calibration after the normal one fixes the issue. Introduction OpenAero2 is an open source aeroplane stabilising software for the KK2 board. It has every function and setting you could think of to use the hardware of the KK2.0 board available from HobbyKing and designed by Rolf Bakke. OpenAero2 provides stability and autolevel functions and contains an extremely flexible mixer that can allow the board to stabilise and control literally *anything*. Enterprising users have set up CCPM controllers for flybarless helis. Others have successfully set up VTOL Osprey-type aircraft. A fully heading-locked 3D mode allows greater control of 3D flight. Spektrum Satellite setup ![]() Futaba S.bus setup ![]() Status menu: The status screen gives you a continually updated display of the battery status, flight modes and any error messages. ![]() Main menu: ![]() New stick polarity setup screen: ![]() Random pictures: ![]() ![]() Source code: For those interested in the code, you can see it at the following repo. https://nextcopterplus.googlecode.co...runk/OpenAero2 Videos Maguro's test flight
Camera stability test
Spektrum satellite binding
Futaba S.Bus demo
Typical installation ![]() Files Attached below and also at the file repo here. Your Support OpenAero2 is a open-source project and is free, however it is also the result of many hundreds of hours of hard work. If you feel motivated to donate to the project please feel free. I'm always happy to make special versions for people.
Beta 1 is in the repository of kkflashtool now.
Good N8 Christian here it is 8 o'clock in the morning, going to get a coffee ;-) |
At the cmd prompt I get ,,javaw is not recongnised as a internal or external command..." What is this, please? |
I think Rolf had to strip a lot out to get these changes in. |
Did you try googling that error message? |
Christian |
| Thread Tools | |
| Discussion CL-OSD a open source osd software for E-OSD and G-OSD | callelj | Video Piloting (FPV/RPV) | 2861 | Today 03:58 PM |
| Discussion OpenAero open-source stabilisation software for KK boards | HappySundays | Video Piloting (FPV/RPV) | 1802 | Jun 11, 2013 05:21 PM |
| Discussion NeXtcopterPlus open-source release for KK and KK+ boards | HappySundays | Multirotor Electronics | 812 | Jan 09, 2013 03:10 PM |
| Poll New tightly integrated, fast Open Source IMU/Autopilot board for student competitions | pixhawk | School Projects and Competitions | 0 | Aug 04, 2010 04:48 AM |
| Discussion Open-source foam cutting software for XP | moreil | The Builders Workshop | 125 | Sep 04, 2008 03:06 PM |
