Old Aug 08, 2012, 04:04 PM
Unb3lievableFly is offline
Find More Posts by Unb3lievableFly
Joined Aug 2012
Wot-4 - Major problems with Scratch built wot-4 engine mounting
Any ideas what to use. This is the first plane i have ever built. The engine keeps falling out of the polystyrene mount that i have made any ideas.
I glue it in first time and then more glue the second and still the slightest touch and it comes loose what do you guys use?
Unb3lievableFly is offline Find More Posts by Unb3lievableFly
Old Aug 08, 2012, 10:26 PM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
We really need to see a closeup photo or two before we can help you. Just saying that your motor comes loose gives us nothing to work with.
Depronicus is online now Find More Posts by Depronicus
Old Aug 09, 2012, 03:37 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If it's scratchbuilt from foam then it ain't really a Wot 4 so what does it look like, size, weight etc ? Motors are usually mounted onto a ply firewall but what motor are you trying to mount ?
BTW if it's really an "engine" i.e. fuel not electric, then foam isn't really going to work.
Steve
slipstick is offline Find More Posts by slipstick
Old Aug 09, 2012, 03:58 AM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
Pictures essential really. It sounds like if you mount onto just foam that will be the problem. You need a light-ply bulkhead/firewall, which in turn will be stuck into the foam fuse with light ply bracing so you spread the load. Then screw the motor with mount onto the firewall.
A lot depends on what you have to start with, get the pictures posted and I'm sure we can come up with the ideal solution
RWData is offline Find More Posts by RWData
Discussion Wot-4 - Major problems with Scratch built wot-4 engine mounting Unb3lievableFly Micro Ready-to-Fly 2 Aug 08, 2012 04:00 PM
Discussion right elec engine for scratch built gravy g Electric Plane Talk 2 Jun 24, 2012 05:41 PM
Discussion What engine and servos would be best for Wot 4? Also how much fuel is needed? absandams Beginner Training Area (Fuel) 5 Jun 13, 2012 06:44 PM
For Sale Scratch-Built 60-size Cloud Dancer with Saito 82 4-stroke and JR servos, rx-ready !!! shooboy Aircraft - Fuel - Airplanes (FS/W) 5 Mar 13, 2012 10:08 AM
Help! MAJOR PROBLEMS with Thor 45cc 2 Stk Petrol engine....PLEASE HELP!!! thkoutsidthebx Engines 5 Mar 22, 2008 01:22 PM
