Old Aug 08, 2012, 02:06 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Great Planes Z- Bender >> So Disappointing
I normally make snake bends, but thought I would give this tool a try before recomending it to beginners.
GP claims "perfect 90 degree bends everytime." I beg to differ.
Have a look at the photos. I am so dissapointed.
I'll be sure to contact GP and see what they have to say. Maybe they are using a new supplier?
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Aug 08, 2012, 02:34 PM
helifreak1 is offline
Find More Posts by helifreak1
Joined Jan 2012
z-bend
I had the same prob till i noticed something.
Check the thickness of the rod and compare it to the bender templates.Some z-bends can only do ???mm rods, and some can do the bigger(thinkness) rods.
The problem that you look like you are haveing is you are trying to bend a rod that is to thick for the Z-Bender. example the bender can bend 2mm rod nicly but you are trying to bend a 4mm rod
helifreak1 is offline Find More Posts by helifreak1
Old Aug 08, 2012, 02:52 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
You'd need one hell of a tool to make a Z-bend in 4mm music wire I don't think the rod in the picture looks like it's too big for the tool. I suspect that A) the tool should be able to handle common wire sizes, and B) Frank knows how to use a basic wire-bending tool.
I just use the little snap-on connectors that come with GWS kits. Best invention since the Sawzall*. Make an L-bend, apply a connector... done. They come in two specific wire sizes, but they still provide a secure fit on most common music wire diameters found in parkflyers and trainers. I think the same general product can be found in many different types and brands. They make setup and adjustments a lot easier in crowded models because you don't have to monkey around with removing and replacing the arm.
I did manage to make some perfect Z-bends for a very small model recently, but I used needlenose pliers and the wire was like 0.5mm, maybe even smaller... And I STILL mostly used the GWS connectors there as well
*This stems from a quote by my grandfather who, during the renovation of some Section 8 housing, once said, "The Sawzall is the best Western invention since cheese". Wise words indeed.
Piece is online now Find More Posts by Piece
Old Aug 08, 2012, 03:00 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
C4, I agree with grandad! Frank, I use a Hanger9 Z bender with great results. What C4 said about the little keepers, they work well, I like them, but not as well as a Z.. ..Dave/ZeeZ
zeezee is offline Find More Posts by zeezee
Old Aug 08, 2012, 03:09 PM
azflyingguy is offline
Find More Posts by azflyingguy
Gilbert AZ
United States, AZ, Gilbert
Joined May 2012
A Table vice, pliers, and hammer is my Z Bender.
Also do not do much Z bending any more.
I use these instead. Comes in difference sized. Life is easier.
Oh sometimes I have used my teeth.
azflyingguy is offline Find More Posts by azflyingguy
Old Aug 08, 2012, 09:57 PM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
How funny: The photo on the product page doesn't even show it bending 90:
http://www.greatplanes.com/accys/gpmr8025.html
That said, here's my observation as a mechanic (45+ years): The way the tool is constructed dictates that it will only work well on a certain range of wire gauges. In particular, it looks like the jaws will bind on the wire before it completes the bend if the wire is too thick. That's what I think is happening in the illustration on the product page and probably what happened in your test, Frank.
It also probably can't make a sharp z-bend if the wire gauge is too small. It might do 90 but the bends will probably be rounded instead of sharp.
I used to use z-bend pliers but I had a collection of them for different sized wire. They did an OK job as long as I used the right one for the wire thickness I was working with, but I was never happy about the right-angle portion of the bend which always seemed to be twice as long as it needed to be. So I bought a good pair of smooth-jaw duckbill pliers and switched to snake bends. The best thing about snake bends is they can also be bent in a smooth-jaw vice. That and a soft hammer will even let you make nice sharp bends in thick wire too.
These days I use a small Knipex Plier Wrench for bending wire:
Smooth jaws that are always parallel, great gripping strength, and all the leverage for bending that you could ever want. They also work better as wrenches than wrenches.
Pete
PGR is online now Find More Posts by PGR
Old Aug 08, 2012, 10:16 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
OK, I'm old and new to rc (but back from cl in the 50's) Anyway, what's a snake bend? Still looking for best way to make control rods.
bobly is offline Find More Posts by bobly
Old Aug 08, 2012, 10:25 PM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
CLICK HERE, Bobly, and all will be revealed.
Pete
Bob Reynolds is online now
Find More Posts by Bob Reynolds
Tucson, AZ, USA
Joined Nov 2000
Havn't used a Z for many years. I use rone nose pliers and make a simple U bend. Use a dremel to cut off the excess length from forming. Easy to put on and can't come off on it's own. The bend radius also fills the hole nicely and gives a much closer fit.
Bob Reynolds is online now Find More Posts by Bob Reynolds
Old Aug 08, 2012, 11:48 PM
phoam is online now
Find More Posts by phoam
don't stare at the sun
phoam's Avatar
Aguanga, Ca
Joined Mar 2010
If you like z-bends, this thing works amazing for control rod wire diameters up to 3/64". 3/64"?? Don't you just love the imperial system?
http://www3.towerhobbies.com/cgi-bin...&I=LXYNN0&P=ML
Not to be used with piano wire, however.
phoam is online now Find More Posts by phoam
Old Aug 09, 2012, 03:14 AM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
GP claims "perfect 90 degree bends every time." I beg to differ.
$34 for the GP ! The Hobbyking ones are under $7 and personally, I like them. Maybe I'm only using the correct diameter of wire for them (don't appear to be diameter fussy) but they certainly do a good job - at a fraction of the price.
Mac50L is offline Find More Posts by Mac50L
Old Aug 09, 2012, 09:25 AM
zeezee is offline
zeezee's Avatar
Joined Apr 2009
I sure do like those Knipex pliers, I have never seen anything like that with the parallel jaws, nice!! ZEE
Old Aug 09, 2012, 09:37 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Yeah, those GP z-bend pliers don't really do a good job. It's not just you, Frank. I usually have to compress the holy hell out of them to get something even close to a useable z-bend. Not my first choice so I only use them if I have no other option.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: Moving on from the F-14
Old Aug 09, 2012, 10:00 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Perfect bends every time. Life time warranty. Not cheap. They also do the swags on
cables.
Brad uses them all the time for every thing.
They are only 4 1/2" long.
http://buy1.snapon.com/catalog/item....re&dir=catalog
As mentioned earlier, piano wire is a whole other thing. It will often break when you try to do a sharp
90`. Heat it first and let it cool slowly. Then you can do nice sharp bends.
Kimber is offline Find More Posts by Kimber
Old Aug 09, 2012, 11:28 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
cables.
I find brazing to be much easier than soldering for joining piano wire to piano wire.
Anyway, I use this style pliers:
Good ones on the cheap at wal-mart (few years back, anyway).
CNY_Dave is offline Find More Posts by CNY_Dave
Found LOOKING FOR Z-Bender Pliers P.M.S Aircraft - General - Miscellaneous (FS/W) 1 Mar 16, 2012 01:11 AM
Sold Great Planes Z-benders crudpuppy Aircraft - General - Miscellaneous (FS/W) 1 Apr 15, 2006 01:07 AM
WTB. Great planes precision Z-bender bfraser Aircraft - Electric - Airplanes (FS/W) 6 Nov 28, 2004 09:59 PM
Disappointed in Great Planes Triton Charger wrenwright Batteries and Chargers 39 Jul 21, 2004 01:39 AM
Z Bender chrisc Aircraft - Electric - Airplanes (FS/W) 1 Sep 21, 2003 10:24 AM
