Old Aug 07, 2012, 06:00 PM
lleach1 is offline
Find More Posts by lleach1
United States, FL, Sebastian
Joined Jun 2008
Tenergy balancing charger problem
I have a Tenergy TB6B balancing charger. The input has alligator clips. I inadvertantly touched the positive clip to the negative terminal on the source power supply. There was a small spark and now the charger will not power up. Does anyone know if this unit has an internal fuse device ? lleach1
lleach1 is offline Find More Posts by lleach1
Old Aug 07, 2012, 08:19 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Good question.
Does the owners manual say anything?
Most of these little chargers are so cheap that the manufacturer doesn't spend the money for anything like a fuse to protect the charger.
I would bet they figure "good, you screwed up, now buy another one from us".
Sorry for your lose.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Aug 08, 2012, 07:02 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Are you sure it's the charger that is bad? Could the power supply have failed? Have you checked the power supply output with a meter?
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Aug 08, 2012, 07:07 AM
lleach1 is offline
Joined Jun 2008
Thanks for the reply. The power supply is a powerful solar powered unit at our flying field. It is OK.
Old Aug 08, 2012, 07:09 AM
lleach1 is offline
Joined Jun 2008
Thanks. You are probably right. Without a schematic it is hard to determine what might have failed. By the time I send it back and pay for shipping and repairs I can buy three more.
Old Aug 08, 2012, 12:42 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
That's just another one of the myriad of clones of that sort. (Accucel-6, IMAX B6, Thunderpower....etc)
Easy to open up and take a look.
Likely you fried something and it would be more trouble than it's worth to fix it.
flydiver is offline Find More Posts by flydiver
Old Aug 08, 2012, 07:39 PM
lleach1 is offline
Joined Jun 2008
Thanks for the replies guys. I opened it up and there was no fuse and no apparent damage. I plugged it into my shop power supply and it powers up and works fine. Must have tripped a breaker at the field. lleach1
Cool Combo: Universal Smart Charger + Two Tenergy 7.2V 3800mAh Battery Packs lordsempra Hot Online Deals 0 Jul 15, 2012 02:00 PM
Discussion Parallel Charging Problem - failure to balance (Bantam BC6 charger) norbert_jones Batteries and Chargers 10 May 17, 2012 06:12 AM
Sold Tenergy TB6 Balancing Charger for NiMH/NiCD/Li-PO/Li-Fe/SLA DrDHalko Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 01, 2009 05:17 PM
Discussion Tenergy TB-6 Charger/balancer? tlr-boise Batteries and Chargers 6 Sep 05, 2009 08:49 AM
Sold 2x Tenergy Li-Po/Li-ion Balance Chargers MonsterMaxx Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 27, 2008 03:42 PM
