Old Aug 07, 2012, 03:14 PM
brokenspar is offline
Find More Posts by brokenspar
The dog ate my clearance
brokenspar's Avatar
Joined Jan 2004
ARF Flite Streak lead-out position
I'm modding an ARF 'Streak and doing most of the recommended stuff....bush the bellcrank, beef up the nose and fuse, etc. I'm curious about the lead-outs. Is the stock leadout position OK? How about adjustable leadouts? Thanks.
brokenspar is offline Find More Posts by brokenspar
Old Aug 07, 2012, 03:49 PM
The Kiwi is offline
Find More Posts by The Kiwi
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
ARF Streak Leadouts
The only thing I recall specifically about the leadouts, other than that the BC platform itself seemed weak, is that the leadout wire was just way too flimsy.
Kiwi
The Kiwi is offline Find More Posts by The Kiwi
Old Aug 07, 2012, 03:52 PM
Norm Furutani is offline
Find More Posts by Norm Furutani
Norm Furutani's Avatar
United States, CA, Gardena
We currently have three ARF Streaks in our little group. All are using the stock leadout position and it seems to be fine. If you haven't assembled yours - a suggestion- trace the fuselage side on a piece of 1/2" balsa. It will make the replacement easier
Ours are all running on OS 25FP and two have R/C clunk tanks mounted on the inside (port side) of the fuse. Great combo!
- Norm
Norm Furutani is offline Find More Posts by Norm Furutani
Old Aug 08, 2012, 08:13 AM
brokenspar's Avatar
Joined Jan 2004
Thanks. The stock leadout cables look strong enough, but I don't like the looks of the crimped ends. I'm replacing the leadouts with new cable and wrapping the ends. I was going to make the leadout position adjustable, but it sounds like that isn't necessary.
Old Aug 09, 2012, 02:20 PM
brokenspar's Avatar
Joined Jan 2004
Here's what I have so far: New fuselage of 1/2 inch balsa with plywood doublers on both sides, 3/16 tail surfaces, reinforced at the fuselage joints with balsa fillets, new leadouts with wrapped ends, and home-made aluminum sheet landing gear. Power will be an ancient OS Max 25, though I do have an FP 25 and might try it later. Only a fuel tank remains, haven't decided whether to mount it inboard or outboard. Weight at this stage is 21 1/2 ounces.
Old Aug 09, 2012, 04:54 PM
The Kiwi is offline
Old Timer
The Kiwi's Avatar
Joined Jun 2010
There are OS Maxes, and then there are other OS Maxes
While I would believe that an OS Max III with an 0.19 displacement would work fine, I have already tried two of the OS Max 25s that were sold in between the Max IIIs and the FPs, and I didn't think that the ones I had were adequate to hauling the ARF around the circle (I do mean that I did have those old model OS engines mounted on the plane, on two successive weekends) .
At the time, when those were current products, because they looked like the Max-S 35s. it was common to hear them referred to as "Max S" 25s, but they certainly didn't have 2/3rds worth of the 35's power output -- more like about 40% was all, I thought.
Kiwi
Alert Top Flite Flite Streak Kit NIB-OS Harlan Control Line 1 Sep 13, 2012 10:29 AM
Sold Brand New Electro Streak ARF with rare Fiberglass Fuse lafuerza Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2012 11:45 AM
Sold Brodak Baby Flite Streak nib Mendo Aircraft - Fuel - Airplanes (FS/W) 4 Jul 08, 2012 11:54 AM
Discussion Best elevator throw on the Baby Flite Streak RknRusty 1/2A Planes 32 Jun 29, 2012 11:12 PM
Discussion I need some advice applying the Flite Streak color pattern RknRusty Painting and Finishing Tips 7 Jun 13, 2012 01:32 AM
