Old Aug 07, 2012, 03:08 PM
VENOMiTry is offline
Find More Posts by VENOMiTry
United States, MD, Glen Burnie
Joined Mar 2012
Question
blade 450x help
i just got a blade 450x the other day and love it but im learning 3d on it and ive noticed the tail kicks out a tiny bit when giving more pitch. my gyro gain is at the stock setup what the manual tells you to start with ive changed it in both directions to see if it helps but it still kicks a tiny bit its nothing major its just if i can get rid of that i would like it more. is there a adjustment on the beastx i can do to get it to hold better? just please comment if theres anything you think i should try. thanks
VENOMiTry is offline Find More Posts by VENOMiTry
Old Aug 07, 2012, 03:25 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
I had same problem before. I changed tail servo to MKS DS95i and tail is solid rock now though 95i is expensive.
wlee1017 is offline Find More Posts by wlee1017
Old Aug 07, 2012, 05:42 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
You just need a faster servo. The tail will always kick out a little bit... you have changed the amount of reaction force it has to deal with, and you changed it quickly. The gyro can never respond to anything that hasn't happened yet, so it has to wait for the tail to start to kick out before it can do anything. If the servo isn't fast enough, the tail is going to continue to blow out until the servo can "catch" it. As long as the tail goes back to where it was, then it shouldn't be a problem... but if it blows out and stays there, you might try increasing the gain.
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 07, 2012, 08:50 PM
Joined Mar 2012
so a faster servo would fix the problem?
Old Aug 07, 2012, 08:59 PM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
I did all you had tried but the problem gone after I put faster digital servo. You don't have to put MKS, it is kind of expensive. Any faster high speed digital tail servo better than DS76T is worth to try. Anyway, you may have to balance center of gravity (COG) as my 95i kind of heavy and I have to do COG balance.
Old Aug 07, 2012, 09:12 PM
sertav is offline
Find More Posts by sertav
Joined Apr 2012
Really? That stock DS76T servo is FAST. Like 0.03sec/60degrees fast...and that's at 4.8V... What else out there is faster?
http://www.e-fliterc.com/Products/De...odID=EFLRDS76T
sertav is offline Find More Posts by sertav
Reply With Quote  (Disabled)
Old Aug 07, 2012, 09:14 PM
Rocket Programmer
Joined Jul 2007
Probably an optimistic rating
Joined Mar 2012
i just noticed that. im guessing thats wrong cause not even savox has a faster servo
Old Aug 07, 2012, 09:20 PM
sertav is offline
Joined Apr 2012
I spoke directly with Mikel G., the designer of the Blade 450 3D and 450 X, and he said that servo was specifically designed for fast operation with the latest gyros, either tail specific or FBL. He said if there were any performance problems with the tail, it was NOT the DS76T, as long as it was working correctly. I had this discussion with him because the frame rate for that servo wasn't listed anywhere and I needed it so I could set it up with a Spartan Quark tail gyro on my 450 3D after my stock G210 died. That servo performs fantastically with that gyro. It's literally like having a robotic tail because it's so locked in. Speed (or lack of it) is NOT an issue.
Old Aug 07, 2012, 09:23 PM
sertav is offline
Joined Apr 2012
Like all the others aren't? It might be a little "fragile" in a crash, but it's a seriously great performing tail specific servo. And, gears are cheap...easy to rebuild...
Old Aug 07, 2012, 09:25 PM
ForumFever is offline
Find More Posts by ForumFever
Joined Oct 2011
Since you have the BeastX, you could of tried adjusting the precomp first.
I have the beastX on my shita 500
ForumFever is offline Find More Posts by ForumFever
Old Aug 07, 2012, 09:27 PM
sertav is offline
Joined Apr 2012
I believe we called this REVO MIX back in the bad old days before HH gyros.
Old Aug 07, 2012, 09:28 PM
Rocket Programmer
Joined Jul 2007
Yeah maybe so, but I wouldn't exactly rely on the word of someone whose livelihood depends on it. I have never been impressed with the Spek servos and they vary in quality. It is possible to get a bad one. I've had two of them fail for no reason. Will probably convert my 300X eventually because of that.
Old Aug 07, 2012, 09:33 PM
Joined Mar 2012
its not a huge deal and its barely any kick. i prefer no tail movement if its possible when giving pitch. so is there a setting on the beastx i could adjust to see if it helps. i havent looked at the manual to see what all of it does yet. also the servo seems to work great but im not a fan of plastic gears on anything so i might upgrade the servos either way
Old Aug 07, 2012, 09:37 PM
Joined Oct 2011
I can't be bothered explaining it here as I'm going to bed.
But over on HF there is a board specifically for the BeastX.
There is a thread on the BeastX and Gig board that talks all about "precomp" and tail kick fixes with the BeastX.
The BeastX has some great parameters, and you should nip over to have a good read about them.
Link Blade 300x & Blade 450x side by side comparison Diesel6401 Electric Heli Talk 3 Jul 26, 2012 06:15 PM
Sold Blade 450X Main Blades BLH4315 snackdaddy185 Aircraft - Electric - Helis (FS/W) 1 Jun 15, 2012 01:23 AM
Sold Blade 450X for sale RickC2009 Aircraft - Electric - Helis (FS/W) 0 Jun 12, 2012 04:42 PM
Sold Blade 450X CF Blades and Battery Jolly Roger1 Aircraft - Electric - Helis (FS/W) 0 Apr 22, 2012 04:20 PM
Discussion Blade 450x Wierd Tail Problem Please Help celuffka Electric Heli Talk 2 Mar 28, 2012 02:03 AM
