This thread is privately moderated by Ribble, who may elect to delete unwanted replies.
Old Aug 07, 2012, 12:16 PM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Bad servo cause damage?
The servos run off the +5v voltage regulator. You can short circuit the voltage regulator and it will just limit the current and work fine when the fault is cleared. Shorting the voltage regulator would drop the gate voltage on the motor switching FETs and turn them off, stopping the motors.
The servos have +5 volts on the center pin (of three) and you can plug the servo connector in backwards with no damage, the servo just won't work. Someone a while back was using a jumper wire to short the servo connector and all it did was reset the DH9116 receiver.
Sounds unlikely that a bad servo could cause damage to anything else.
What will kill the circuit board is stalling a motor. Kill the throttle before you crash. Stalled motors will suck up all the amperes that the LiPo or Li-Ion battery can provide and with a good battery, something has to burn out. It can happen faster than the Motor Overload Protection System (MOPS) can act.
DH9116 printed circuit boards are quite rugged and take much abuse.
Ribble is offline Find More Posts by Ribble
Question Damaged 6S Lipo; One cell bad; Need help with discharge and disposal Arcturus97 Batteries and Chargers 7 Jun 28, 2016 12:42 AM
Discussion Bad Servo, Bad Tester or Just Bad Luck Gungho High Performance 22 Apr 30, 2012 12:57 AM
Help! Bad Servo Cause Twitches and Rx issues? fk27bob Radios 1 Dec 10, 2009 11:17 PM
Discussion Help with crash cause - bad ESC or servo? AirChime Crash Discussion 0 Sep 29, 2009 05:50 AM
Discussion Bad servo caused weird glitching johndreid Electric Plane Talk 7 Feb 10, 2006 01:23 AM
