Latest blog entry: Chaos 600 ESP build
Set RPM is what I like to use because I'm into scale flight and a fixed head speed suits my flying style better. I've never had to calibrate the endpoints on a Castle ESC when using set RPM. My experience was that the ESC wouldn't arm because the throttle trim needed to be moved down. That was strange because I never had to do that before. I adjusted the trim and everything armed OK and has been fine ever since. Your issue seemed similar so maybe that will help?
Here are a few videos that will help get you set up.
http://www.helifreak.com/showthread....stle+creations |
Good deal, glad you got it fixed!
| Thread Tools | |
| Discussion Adjustable Retract and Door sequencer w/Display -- End point Adjustment? | jrb | Radios | 4 | Apr 13, 2012 01:34 PM |
| Discussion End point adjustment for throttle | hone1er | Beginner Training Area (Aircraft-Electric) | 4 | Mar 31, 2012 10:21 AM |
| Discussion Throttle End point adjustment? | hone1er | Radios | 2 | Mar 30, 2012 05:06 PM |
| Throttle Tx end point adjustment and ESC | luc | Radios | 10 | Apr 14, 2003 03:58 PM |
| Can one end-point adjust the throttle on a Futaba 8UAF? | temacc | Electric Plane Talk | 6 | Jun 13, 2001 09:21 AM |
