Old Aug 07, 2012, 07:08 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
Lawmate RX picture has shadow effect
Is this normal for the lawmate or is there something wrong with mine? I get much better range from my lawmate vrx without saw filter upgrade, than my sunsky vrx with saw filter upgrade (but the sunsky picture is crystal clear).... Its just that this shadow effect really sucks... Can I fix it, or its just a bad unit?
I took the picture with my cell phone, ignore the other lines... I circled the shadow effect problem...
KillerCut is offline Find More Posts by KillerCut
Old Aug 07, 2012, 07:23 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I have four, they does it all. It is incorrect video level. I could correct by raising input impedance of my display device, but finally decided to ditch lawmate entirely and go with RMRC rx.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Aug 07, 2012, 07:56 AM
USA, NY, Brooklyn
Joined Jan 2002
So how do I fix it? Will the saw filter upgrade do anything for the picture or no? I was planning on doing the saw filter upgrade on the lawmate too, but I didn't when I saw the bad picture..
Old Aug 07, 2012, 08:17 AM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
The SAW filter won't help. I removed the SMT 75ohm resistors from the EE station and replaced by 1K ones. People rave about lawmate, so I searched the issue elsewhere hitting my head against the wall... until I put them in a drawer.
-Hugo
Old Aug 07, 2012, 09:20 AM
USA, NY, Brooklyn
Joined Jan 2002
I dont want to mod my EagleEyes. How do I fix this on the lawmate rx? Resistor somewhere? I think I read someone used a 39ohms resistor... Do I put it on the ground wire or the signal/video wire or between them?
Old Aug 07, 2012, 11:31 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Ah ha! I bet this is my problem???
http://www.rcgroups.com/forums/showthread.php?t=1705401
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Aug 07, 2012, 11:40 AM
USA, NY, Brooklyn
Joined Jan 2002
Yep, looks very similar, object that are further away look even more messed up with that shadow effect on the lawmate rx... We need to fix this.
I'm using an effio-p camera, one of the best ccd out there... 700TVL, perfectly focused... The lawmate does it with any camera and any 1.2ghz vtx on any channel...
Old Aug 07, 2012, 11:50 AM
Expat
Japan
Joined Apr 2010
Well it's good to find the real problem. I was going to buy a new lens for this. Btw I'm using 2.4ghz lawmate with 8 channels and an LCD.
Old Aug 08, 2012, 06:30 AM
Expat
Japan
Joined Apr 2010
Why would they ruin the RX? How can I get it working clearly with my LCD? Should I send it back to the dealer?
Old Aug 08, 2012, 06:39 AM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
The Lawmates VidRX put out low power, thats why its "shadowing" effect.....
LexusFPV is offline Find More Posts by LexusFPV
Old Aug 08, 2012, 11:30 AM
Expat
Japan
Joined Apr 2010
So I find an "smt 75ohm resister" in my LCD and replace it with a 100? Can that be easily done with a soldering iron?
Can the LM rx be modified?
Shouldn't we all send them back to the distributor as defective?
Old Aug 08, 2012, 11:56 AM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
If you're confident with your soldering skill, look for a 75ohm resistor close the input connector of your LCD. The resistor is not marked so you have to use a ohmmeter. It will be shorting the RCA connector of your LCD. Removing and solder a normal 1K resistor directly on the input connector. Best is to solder a 1K pot and tune it for best viewing experience.
-Hugo
Old Aug 08, 2012, 01:41 PM
USA, NY, Brooklyn
Joined Jan 2002
what about using other vrx, will we have to switch back to a 75ohm resistor, or will the 1000k resistor still work well with other video inputs?
Old Aug 08, 2012, 01:50 PM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Every manufacturers have a different definition of output/input termination and video level standards, not counting great variation among same model. This probably account for a appreciable % of the problems we see on this board. That's why I suggested the 1K pot, so you can tune for every Rx you have. For example, one of my 2.4 lawmate Vrx output 0.5V p-p (half the standard) while my other 0.7V p-p.
-Hugo
Old Aug 08, 2012, 01:59 PM
Expat
Japan
Joined Apr 2010
Thanks Hugo. You wouldn't happen to have a link to such a resistor on eBay or such?
Discussion Lawmate 1.2ghz 1000mw Tx and Rx in stock where? KillerCut FPV Talk 4 Aug 09, 2012 09:41 AM
Discussion fatshark picture has a ghost lag Patscherpofel FPV Talk 3 Jul 25, 2012 12:43 PM
Found Lawmate 1.2 Video RX w/ 1280Mhz iskess FPV Equipment (FS/W) 1 Jul 05, 2012 07:22 PM
Discussion Who has stock on the Lawmate 1.2GGHz video RX? Bill Sanford FPV Talk 11 Jun 09, 2012 04:25 PM
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
