An improved carb, a slightly larger bore for a very slight increase in displacement, and a better exhaust valve seat is what Saito said they did.
Latest blog entry: My Low Wing plane
Joined Feb 2007
Any update on how things are going on now with your FG-21? It's quite confusing to notice you have had such a bad luck with the FG-21 while some others have found the engine to be reliable. Are you sure you haven't overpropped it? CH Ignition has experimented the Zama carb in conjunction with the FG-21 with good luck. Just for your consideration. Btw. why do you think you are luckier with the FG-30? |
The FG21 is $505.
W/the C&H conversion you can convert the FA125 to gas for just a little more than that & have a better ignition system & more reliable carburetor to boot. The system for applying the trigger magnet & hall sensor is much better on the C&H system too. It is much easier to set up & make adjustments than the Saito/RCEXEL system. C&H originated the synchrospark CDI systems back in 1997. I have 3 of those systems & they still work flawlessly. RCEXEL copied the module (but not the trigger magnet/sensor mounts) to make cheap Chinese knock offs. FA125 ..........................................$375 CH complete gas conversion kit..$150 Total............................................. .$525 Many end up replacing the module & carb on the Saito FG engine W/the C&H parts to get reliable operation. Why not just go the C&H route W/the FA125 in the 1st place & avoid the added expense/headaches? |
Joined Feb 2007
However, one thing that is confusing is the Zama in conjunction with the FG 20 seems to give about 8100-8300rpm with 16X6 evolution prop as peak according to Adrian's experiments . The original Saito carb seems to perform better what comes to max power output: about 8500-8800rpm with 16x6 apc or equivalent prop according to various tach readings reported? Why? |
I would bet that the difference is because one carb has a slightly larger venturi bore to it.
Adrian seldom experiments W/ignition timing beyond the 28* initial setting. A bit more advance might also boost power output. It certainly does when burning methanol W/CDI. Adrian's tests could have been done on a day W/high humidity or windy conditions. I also suspect that some manifold work to blend the bore of the ZAMA carb to the manifold diameter would help. On my FA180HC CDI engine I gained .45HP when I modified an FA150 intake manifold to the ID of the FA220 Big Bore carb on the updraft portion & opened up the horizontal portion that joins the head to the size of the 180 intake port. I doubt that I would have seen that much gain from just bolting the big 12mm 220 Big Bore catb onto the standard 11mm bore FA180 intake manifold. Once CDI is introduced into the equasion, there is lots of room for various tweeks to maximize power output. That's why I convert all of my Saitos to CDI even though I still burn methanol feul. The ignition timing can be adjusted to take advantage of the various tuning needs that arrise. Besides, which is better, an engine that makes 8300 RPM of dependable power, or an engine that might make 300 RPM more that is unreliable? |
| Thread Tools | |
| Discussion Saito FG-21 gasser | skypup | Engines | 43 | Apr 08, 2013 12:43 PM |
| For Sale new Saito FG-20 | airtimeallen | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Jul 10, 2012 09:35 AM |
| For Sale Saito FG-20 | airtimeallen | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jun 30, 2012 01:47 PM |
| Off Site New Saito FG-20 in the Box | JetA320 | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jun 12, 2012 04:48 PM |
| Discussion Saito FG 20 discontinued, Hello FG 21 | Ayeager | Engines | 1 | Apr 27, 2012 11:03 PM |
