Old Oct 03, 2012, 04:05 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
do u really need to enlarge the cheater ??
that should be a cg problem don't u thing?
i also have this cool hawker (and awefull to build too!)
i use mine on 8cells HEt motor 700-68-1680kv 100A CC and 2 4000mah kypom 4s 35c lipos
flight time with throttle managment is about 5-6 minutes
thrust is about 4.4kg on about 3kg auw
the complete plane is fiberglassed and epoxied removable wings ang carbon key in them , e-retract an alloy struts use a cg a bit forward from original position and no enlarged cheater hole to fly correctly, just a bit enlarged air ducts
take off and landing are just amazing !
everybody might have this one at home!
here's pics
gianni sanchez is offline Find More Posts by gianni sanchez
Old Oct 03, 2012, 06:09 PM
jofro is online now
Find More Posts by jofro
Joined Jan 2010
Hi above, it never does any harm to enlarge air intake on this one. Didn't understand your 2nd line, refering to CofG. I had yesterday two more flights in extremely windy conditions using larger capacity batt. and advantage to adjust my CofG probe. After doubling my Elevator travel I get lot more authority now. As someone mentioned, a "Pattern-ship" of jets. I landed it yesty into the wind at walking pace.
That is brilliant flight time, 5-6min. you must be doing lot of wind soaring. Mine draws only 75amps but 3.5min is my limit and that is using 8S4000/40-50C packs. See above pic. what happened to one of my pack on maiden while using only 30C's. These things suck lot of juice from li-pos, J.
jofro is online now Find More Posts by jofro
Old Oct 04, 2012, 06:37 PM
Joined Jan 2012
no wind soaring man just throttle management
what's your set up?
i use the 700-68-1680kv on 8 s with 4000mah 35c pack
this one is just a good compromise between pretty nice power and flight time
i've calculate FSA and we have just the perfect % for a 90mm with stock cheater and air duct witch is a lil' more than 85%
so i don't think it'll help u the enlarge it
btw as we say here the bigger can do the smaller too ..
good job on this one
Old Oct 05, 2012, 03:09 AM
jofro is online now
Joined Jan 2010
I very much agree with you, throttle management is all, what EDF flying is about, but no matter what type of "high performance" EDF I fly, the 3-4min. is just about all I ever get with 8, 10 or 12S set up. So far, I'm pretty pleased with this weird fan/rotor/motor combo I got in this one, yesty had 2 more flights in the windiest conditions and today 2 flights in extreme hot, 35deg. C. everything holding well, tho only 8 flights, time will tell, J.
Old Mar 02, 2013, 05:51 PM
sihinch is offline
Find More Posts by sihinch
Canada, ON, Toronto
Joined Jun 2007
Almost finished my Hunter today.
I've done it in 8SQN RAF markings, because I found out my Grandfather used to work on them from 1963 to 1965.
I've used E-Flite 15-25 retracts, the stock fan shroud with a Wemo Pro rotor and HK3545-1850kV warhead motor. Static test today gave 77A and 1700watts.
Just need to sort out the nose gear steering, set control throw and balance it. Although I'm not sure the weather will be ready for a maiden until April.
sihinch is offline Find More Posts by sihinch
Old Sep 25, 2013, 07:02 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
https://www.hobbyking.com/hobbyking/...dproduct=24730
I see that HK now has these in stock at the US warehouse. Has anyone built one lately?
Looks like something I could fly from the grass field behind my house. Is it too large to hand launch? Can I land on a short strip or do they float a lot on landing?
RC Man is offline Find More Posts by RC Man
Old Sep 25, 2013, 07:05 AM
RC Man is offline
United States
Joined Feb 2001
Does it fly ok with the stock motor and fan. The motor is listed as B36 1500kv Brushless Outrunner. That seams like a very low Kv for the recommended 5s battery?
Old Sep 25, 2013, 01:32 PM
RC Man is offline
United States
Joined Feb 2001
Is there a detailed build log of electric retract instillation? What brands would fit?
Old Sep 25, 2013, 01:35 PM
sihinch is offline
Canada, ON, Toronto
Joined Jun 2007
My build log is here, with some retract info. I used E-Flite 15-25 tricycle retracts.
http://temac.ca/smf/index.php/topic,3591.0.html
Old Oct 21, 2013, 12:31 AM
herropreeze is offline
Find More Posts by herropreeze
Joined May 2012
I fly mine on everything stock, but I use 6s, as I am at altitude. She has plenty of power and on a 5000mah nanotech (35-70c) I am getting excess of 5 minutes flight times
herropreeze is offline Find More Posts by herropreeze
Old Apr 26, 2014, 11:21 PM
phippsa3 is offline
Find More Posts by phippsa3
South East London
Joined Oct 2007
Hi gianni sanchez , Your Hunter looks fantastic. Can I ask you where you found those struts. They look great.
phippsa3 is offline Find More Posts by phippsa3
Old Apr 27, 2014, 09:56 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I used this set in the Hunter (and other planes).
Good value.
http://www.hobbyking.com/hobbyking/s...dproduct=25499
4stripes is offline Find More Posts by 4stripes
Old May 06, 2014, 11:43 PM
Opvaulet is offline
Find More Posts by Opvaulet
Joined May 2014
My Fly Fly Hunter. The main mods were substituting the air retracts from the kit with E-flight 15-25 electric retracts (powered by another separate 350 mah batt just like the RX for safety, will do 4 flights), adding a rudder servo, reinforcing all three landing gear mounts substantially, and swapping the kit fan with a Wemotec Pro, and now with upgraded rotor; the super sounding 11 blade from the Wemotec Evo. One major upgrade was the addition of a Mylar thrust tube, which reduced the takeoff roll by almost half!
The motor is a HET, with CC 85HV, battery is 6s1p 5000mah, flight time 5 mins.
Paint scheme is modelled after '527' parked at the Republic of Singapore airforce Museum. I did it freehand with Tamiya spray cans.
The Hunter is a real pussycat to fly. Just like a pattern plane.
Opvaulet is offline Find More Posts by Opvaulet
Old May 07, 2014, 12:26 AM
Opvaulet is offline
Joined May 2014
Two more photos...
Old May 07, 2014, 12:36 AM
cnchelicopter is online now
Find More Posts by cnchelicopter
United States, CA, Garden Grove
Joined Sep 2011
My 70mm little cousin Hunter Hawker EDF Jetflight 1 May-4-2014:
Hunter Hawker EDF Jetflight 1 May-4-2014 (2 min 26 sec)
Hunter Hawker EDF Jet flight 2 May-3-2014:
Hunter Hawker EDF Jet flight 2 May-3-2014 (2 min 28 sec)
cnchelicopter is online now Find More Posts by cnchelicopter
Rave Kirks Hawker Hunter! (biggest single fan EDF) gunradd Electric Ducted Fan Jet Talk 71 Jun 27, 2012 08:35 PM
Sold 90mm Hawker Hunter PNP $450 L.P.U. SkylineFlyer Aircraft - Electric - Jets (FS/W) 4 Apr 29, 2011 07:55 PM
Sold RC Lander Hawker Hunter - Swiss - $250 flyandi Aircraft - Electric - Jets (FS/W) 2 Dec 25, 2010 12:52 PM
NEW Hawker Hunter project (90mm fan + retracts) greddin Electric Ducted Fan Jet Talk 104 Sep 20, 2007 01:22 PM
