Old Aug 07, 2012, 02:17 AM
ELERC is offline
Find More Posts by ELERC
ELERC's Avatar
Joined Sep 2005
Need your suggestions for the new UAV
Delete
ELERC is offline Find More Posts by ELERC
Old Aug 07, 2012, 06:15 AM
Nīmā is offline
Find More Posts by Nīmā
No ceiling for my altitude
Nīmā's Avatar
Iran, Tehran
Joined Dec 2009
A power-plant include 3 engines, Is it really necessary?
You can do the same with just 1.
Your plan seems to be interesting, I like to know your purpose for using more engines (and reduce of drag)?
Nīmā is offline Find More Posts by Nīmā
Old Aug 07, 2012, 08:07 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
That design will be very sensitive to pitch inputs and center of gravity.
Most certainly will require a built in, tuned stabilization system or autopilot.
Need a duration of an hour or more for a small, tactical UA.
Reduce the number of moving parts (use one motor)
Must be rugged and modular (easy to switch payloads)
Must protect the payload and electronics
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Aug 07, 2012, 12:50 PM
johnorama is offline
Find More Posts by johnorama
UAV Dude KF7HYV
johnorama's Avatar
United States, NV, Silver Springs
Joined Mar 2007
A true UAV has the camera on the underside of the aircraft. It is hard to see your subject when your airplane is blocking the camera. You need a retractable camera system like I have designed. Allows for a pan and tilt camera undertheath the plane but retracts for takeoff and landing. This will also keep clean airflow moving over the vertical stabilizer where a camera on top will disrupt the airflow and reduce control.
johnorama is offline Find More Posts by johnorama
Site Sponsor
Old Aug 08, 2012, 03:03 AM
ELERC is offline
ELERC's Avatar
Joined Sep 2005
Hello,yes, we decide to use two 22/28mm diameter outrunners(pulling in front) or single 35mm ( tail pushing)
Old Aug 08, 2012, 03:05 AM
ELERC is offline
ELERC's Avatar
Joined Sep 2005
Thank you for the suggestions.
The plane will be made from EPO and modular.
For the profile design , we will test and improve.
The video for the wood plane will be uploaded soon, and hope for your suggestions then
Old Aug 08, 2012, 10:30 AM
Nīmā is offline
Nīmā's Avatar
Iran, Tehran
Joined Dec 2009
Do you have any plan for reduce of operational range?
By the way ... (excuse me that I ask more questions, I'm just a bit curious!) ... What is the use of this drone? just simple URAV or ... ?
Old Aug 09, 2012, 08:07 PM
ELERC is offline
ELERC's Avatar
Joined Sep 2005
What sort of UAV will be more popular?
Old Aug 13, 2012, 01:24 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
I think before designing the airframe you have to decide what the most popular application will be. There really is no Swiss Army sUAS they are generally designed for one task only. Plenty of examples here http://www.suasnews.com
My design criteria access to a vertically mounted camera that I can get at with my fat fingers. At the moment I really like putting cameras in wings away from the centre line as it keeps them just a little bit further from the ground. With a single prop it also keeps them further from vibration as well. (This is in a normal airframe configuration, I actually think flying wings make the best sUAS as they have less bits to fail)
As Gene says you have to watch out for pitch in planks, especially when operating at speed.
The airframe market is fraught with danger it will be copied! Jimmy Prouty, Chris Mc Nair, Rob Swynerton, and Gene have all had airframes and designs ripped off by companies in America no less and these are just the ones I know about.
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Aug 13, 2012, 09:53 AM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
[QUOTE=Gary Mortimer;22430612]I think before designing the airframe you have to decide what the most popular application will be.
QUOTE]
That's a great point, Gary. The smart way to design a platform is to first identify the payloads it will carry and the environment it will operate in. Only then can you start to design and optimize the airframe.
Site Sponsor
Help! Need naming suggestions for a new multicopter product line! Garret H Multirotor Talk 86 Apr 14, 2012 05:12 PM
Discussion UAV For Film Shoot Needed RonDub USA - District XI 0 Mar 29, 2012 12:37 PM
Discussion New to UAVs need your input please help NoobTube Aerial Photography 3 Dec 10, 2008 08:37 AM
Help! New RC Pilot - Need your help/suggestions! Kieraw Micro Ready-to-Fly 17 May 26, 2007 11:59 AM
