Joined Jul 2012
5.8 GHz 200-900mw + Fatshark goggles: Is this a good first FPV setup?
I would like a setup that goes 1 mi or over. I like the fatshark head set and would like a transmitter/receiver to connect to it. is this even possible because the goggles have a built-in transmitter?
Also What is better on 5.8?- 100,200,400,500,600,800, or 900mw? ![]() One of these: http://www.ebay.com/itm/251068852166...84.m1423.l2649 http://www.ebay.com/itm/290750556252...84.m1423.l2649 http://www.ebay.com/itm/271027607644...84.m1423.l2649 http://www.ebay.com/itm/320957553291...84.m1423.l2649 Fav so far http://hobbywireless.com/index.php?m...products_id=22 or even: http://www.ebay.com/itm/Professional...#ht_1211wt_936 To go with this: http://www.hobbyking.com/hobbyking/s...et_System.html Could you tell me if either of these setups are good and can work together?
Joined Jul 2012
also would I only have to buy ?http://www.hobbyking.com/hobbyking/s...le_600mw_.html
I will need to buy a receiver also? |
Joined Jul 2012
Cool, would any of these work with the fat shark?
http://www.bevrc.com/index.php?main_...s_id=0&button= I dont know to buy 800mw or 1500mw |
Joined Jul 2012
Ok I think I like http://www.bevrc.com/bev-13g-800mw_p52.html
I hope it works with the fatshark and now I see somthing about a filter antennae ? |
Joined Jul 2012
Last question
Is this better than the cloverleafs http://www.bevrc.com/bev-1213g-the-smallest_p63.html and is a filter needed for 1.3, what are they? |
Australia, QLD, Toowoomba
Joined Jul 2012
As a noob myself, I think you'll find FPV requires a lot of reading and preparation before you're ready to make informed decisions for purchases.
There are so many variables (quality and compatibility of components, type and configuration of antennas, interference from the environment and your own aircraft, your own competence with the assembly and use of the equipment, local laws regarding radio use) that nobody can give you useful information about any given system's range without knowing a LOT more information about your proposed setup. To assist with your most recent questions: Most FPV receivers and transmitters will have a range of different frequencies (channels) they can operate on - generally, they're listed in the specifications and there's usually 8 channels the operator can choose from. You need both your transmitter and receiver to have a matching frequency, so they can talk to each other on that channel. (As a rule of thumb, FatShark & Immersion use frequencies ending with 0, the HobbyKing/BevRc/Foxtech gear uses frequencies ending with 5 - this might make things easier when glancing through spec sheets) The power of your transmitter is NOT the most significant factor in getting good range from your equipment. The selection of appropriate antennas and setting up your aircraft and ground station well will be much more important. Don't over-simplify by assuming that big numbers on your transmitter and antenna will ensure the greatest range - this is definitely not the case. Quote:
| Thread Tools | |
| Wanted Fatshark Predators and 1.3/5.8 GHz FPV equipment | Zangetsu57 | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | Dec 21, 2012 09:25 PM |
| Found 5.8 GHz 200 mW video transmitter | alek3d | FPV/RPV - Equipment and Vehicles (FS/W) | 10 | Jun 22, 2012 08:50 AM |
| Found 5.8 GHz FPV setup (w/ Fatshark if possible) | MCrites | FPV/RPV - Equipment and Vehicles (FS/W) | 2 | Mar 26, 2012 12:02 PM |
| Question FPV newbie... questions about signal strength/quality FatShark 5.8 GHz | Mike_Then | Video Piloting (FPV/RPV) | 21 | Feb 21, 2012 03:19 PM |
| Sold FatShark 5.8 GHz video goggles + receiver. | rlshayes | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | Mar 27, 2011 03:58 PM |
