Old Aug 06, 2012, 09:07 PM
big_poppa4904 is offline
Find More Posts by big_poppa4904
Build, Fly, Crash, repeat
big_poppa4904's Avatar
United States, NC, Shelby
Joined Nov 2010
nitro motor got wet, now what?
Crashed my 40 size Stik into a tree and it got rained on. Motor got pretty wet. It is a OS 40 is all I know. It turns over by hand pretty good. Dont seem like its binding up or anything. muffler took a lick.
But anything I should do to the motor to ensure it (hopefully) will run again one day? I don't plan to get another plane for the motor for a while. Any oil, WD40 or anything I should spray on it or inside it?
big_poppa4904 is offline Find More Posts by big_poppa4904
Old Aug 06, 2012, 09:17 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I like to flush them out good with WD-40 and then oil them a little with something better. Then fire them on back up and get them flying again. Many years ago we used to dunk the engines quite regularly using airboats in the ocean. We were trying to jump the little waves at the beach then. The radio systems didn't fare as well as the engines did though. We had to take apart the RX and servos and flush them with fresh water real good, and we had to do it fast before the salt water corroded everything. Usually we could get the radio gear working again, but sometimes not. But the engines merely needed to be flushed out some with glow fuel and the engines were ready to go again.
earlwb is offline Find More Posts by earlwb
Old Aug 06, 2012, 10:06 PM
Joined Nov 2010
how exactly do I "flush" the engine with WD40 or other oils?
Old Aug 06, 2012, 10:23 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I guess at our last club "float fly" a couple of the guys dunked their engines pretty good. Like completely submerged. They brought them back in, removed the glow plug and spun it over with a starter to pump out the water. They were immediately re-fueled and they started right up, more or less. Nobody said anything about the radio gear.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: I looked and I looked and I...
Old Aug 07, 2012, 12:11 AM
jjkupinski is online now
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
As "kenh3497" presented, run the engine as soon as possible to "blow out" any water that may be residual in the motor, preferably with a fuel that has castor oil as a part of the lubricant package. I personally don't like using WD-40 as a flush as it does not have any anti-rust component in it, nor is it a lubricant. If you can't run the engine, give it a good shot of after run oil, Marvel Mystery Oil, or auto trans oil thru the carb and the glow plug hole. And give it quite a few flips to work the oil in.
jjkupinski is online now Find More Posts by jjkupinski
Old Aug 07, 2012, 12:21 AM
datsunguy is online now
Find More Posts by datsunguy
Joined Jun 2011
Just run it. Make sure it turns over and then just run it. Oil well when done.
datsunguy is online now Find More Posts by datsunguy
Old Aug 07, 2012, 12:46 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
Flush them by running the engine.
Please note you shouldnt do that to one that has sit without oil for very long. Reoil it first.
You can also take the rear crankcase off and that makes it go much faster.
Frankly... This is god's way of telling you its time for a Crockpot+antifreeze bath and lube up with ATF!
Generally the engines are none the worse for wear in fresh water. Little of conciquence will rust. Screws/nuts/bolts, bearings, ring if its a ringed engine, needle valve. Thats about it on a 2 stroke. All cheaply replaceable parts or psrts that are easy to remove rust from.
Toysrme is offline Find More Posts by Toysrme
Old Aug 07, 2012, 12:48 AM
Toysrme is offline
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
Plus, so few people ever clean the inside of their engine spent castor oil builds up and protects half the junk inside it hah
Old Aug 07, 2012, 12:44 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
You mentioning ducking your boats brought back fond memories of a time when I was into boating myself so here are a few pics of the simple airboat that I've kept all these years with that reliable simple OS Max 15. Built it from a plan, we were five of us and we did put a big needle up front trying to burst balloons on the water. I remember having to wash out and dry the engines as well as electronics and then spray some electronic cleaner on the insides of the receiver. I was smoking Belga cigarettes at the time hence their logo.
Reginald is offline Find More Posts by Reginald
Old Aug 07, 2012, 01:31 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yeah I think I should have worded that better, with the 2 stroke engines you can remove the glow plug and flip the prop some to expel the water and put the plug back in and the engine should fire on up and be running again in no time. But if the electronics got wet, then if you can't run the engine right away, you need to flush it out some after getting most of the water out. WD-40 works well as it is a water displacement oil and helps remove more water from the engine. But it isn't a long lasting oil though, so if you are going to put the engine up for a while you need to use a better oil in it.
Nice boat Reginald, it reminds me of some of the airboats I had over the years. The first airboat was one I ran on Okinawa when I was in the USMC. It was sold under the Futaba brand at the time and it used a .20 size engine. It was mostly ABS plastic but it looked fast just sitting still. Anyway a number of us all got them and were staging races and wave jumping competitions in a little cove nearby on base. It was ocean water and salty of course. It isn't easy jumping waves as the torque reaction from the engine and prop will flip the boat right on over as soon as it gets a little air under it. You have to time several things just right or you get to go swim for your boat. But at the time the temperatures were great and the water was fine too.
After that I built several Duma airboats of different kinds and a large scratch built wedge shaped airboat as well.
Old Aug 07, 2012, 01:45 PM
Joined Nov 2010
Well my plane got completely destroyed but luckily where the electronics were inside the fuse, the rain did not touch it. So I believe they are fine.
After further inspecting the motor, the only thing that got bent was the two long screws the holds the muffler on. Any idea where I can get two more??
This is a OS Max 40 motor. So I will need screws that will work with that. I did clean the motor up some. All looks well like I say except the muffler screws
Old Aug 07, 2012, 03:04 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
My son had a freeflight flyaway at the 1980 Nats. It spent the fall and winter through to next spring in a tree near Dayton, OH. It blew down and was recovered. The engine was a Fox 25 run on all castor fuel. No damage. I put in some Rislone just to lube it up, then fueled up and ran it. It was fine.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Aug 09, 2012, 11:34 PM
TigreJohn
Joined Aug 2008
earlwb; your using WD-40 to flush water out of wet electronics? Shame on you! Unless you are fastidious and perfect in the process, the residue left behind can still be conductive and make your efforts a waste of time (and maybe money). Don't know if they have a newer specific replacement fluid for the flushing process, But during WW II, the Navy's SOP was to use methanol or denatured alcohol to dry out wet electronics.
Old Aug 10, 2012, 12:50 AM
Joined Jun 2011
He didn't say to use wd-40 on electronics. He said to use it on an ENGINE. I raced boats for years A ,B, and C hydros. They were always upside down in the water. All we did was pull the plug hit the engine with a starter and then run it in the next heat. At the end of the day Run WD-40 through them and then a good shot of Marvel air tool oil. Never had rust problems. Of course I also used castor oil.
Old Aug 10, 2012, 01:55 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
If the threads are ok on the muffler bolts, you can straighten it out with pliers holding onto the threaded part and bending it straight if you are careful not to nick the threads. Depending of course how bad shape the bolts are. Don't fix them if the threads are mangled at all though. A good hobby shop should have spares.
aspeed is offline Find More Posts by aspeed
Help! Electronics got wet. ESC or motor broken? Daniel S Waterplanes 10 Aug 03, 2012 03:35 AM
Discussion My son got his JR XP6102 wet is it junk now? Dave K Radios 5 Jul 16, 2009 04:31 AM
Okay I got the CDRom Motor out Now What? Wingtips24 Power Systems 15 Jul 21, 2005 06:43 PM
Question Got My endoplasma Motor now What ? Allan Glover Electric Plane Talk 5 Apr 11, 2004 05:02 PM
