Old Aug 06, 2012, 07:46 PM
Jaximus is offline
Find More Posts by Jaximus
Joined Jun 2012
Quick Battery Discharge Rate Question?
Hello
So discharge = C * mAh
I'm buying a model that requires a 4s 30C 3300mAh battery
Will a 4s 20C 5000mAh work safely ?
Since 30*3.3 = 99 A
and 20*5 = 100 A
Jaximus is offline Find More Posts by Jaximus
Old Aug 06, 2012, 08:47 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
Exactly right. The only penalty for the 5000 mAh battery is the extra weight. But actually, not so much -- because high-C batteries tend to be heavier anyway.
Looked at the other way: the main reason to use a high-C battery is to reduce the battery weight (at the expense of mAh capacity.)
rafe_b is offline Find More Posts by rafe_b
Old Aug 06, 2012, 08:56 PM
Jaximus is offline
Joined Jun 2012
Indeed, the 5000 mAh bat is like 150 grams heavier. Fortunately though I should have no weight issues with this model.
Cheers.
Old Aug 07, 2012, 08:49 AM
H2SO4 is offline
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
One thing to be aware of is that the C-ratings on many batteries are pure marketing fantasy, especially the ones that claim 30C and above. There is no set standard for how those numbers are to be measured, so in order to stay ahead of the competition many LiPo manufacturers print labels with extremely questionable (read: "invalid") maximum discharge rate claims.
A 30C battery must theoretically be able to dump its contents in two minutes flat without sustaining damage in the process, again and again. Few batteries can do that for real. The ones which claim 60C or even 100C+ () should be able to do the same in a minute or less - without melting or catching fire.
The 20C battery is probably OK, at least when new (effective C-rating decreases over time, especially if cells are abused, most commonly by leaving them charged). Anything rated 30C will most likely be unable to live up to the promise. Think 20 to 25C, maybe, if on a good day.
That disparity between marketing hype and reality needs to figure in the calculation when approaching the limits of what the battery can supposedly handle.
H2SO4 is offline Find More Posts by H2SO4
Old Aug 07, 2012, 03:16 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
A 2200mAh pack is almost never seen with anything larger than 12AWG leads. If the pack could REALLY be discharged at 65C safely, you'd be running 143A through those 12AWG leads for 48 seconds before you hit the 20% capacity threshold.
Somehow I doubt the leads and/or solder joints would make it more than a few seconds.
100C ratings are laughably absurd if you think about it: 220A from that 2200mAh pack. How many seconds of runtime is that? Can the aluminum cell tabs even handle that much current?
Piece is online now Find More Posts by Piece
Discussion Quick Syma S032 battery Specs Question doubleg Batteries and Chargers 0 Aug 04, 2012 05:46 PM
Help! Battery discharge question. How long will my battery last jasper7821 Batteries and Chargers 3 Mar 04, 2012 01:45 PM
Quick Triton battery discharge question EddieNewYork Batteries and Chargers 8 Dec 02, 2010 02:08 PM
Battery Discharge Rate Question LTChip Batteries and Chargers 3 Sep 12, 2003 01:26 PM
Battery Discharge rate Question ? AirAmerica Electric Plane Talk 3 Oct 13, 2002 01:29 PM
