Thanks for the interest posted here and via private message.
I just cut an updated version which addresses a few minor but necessary improvements. It will be assembled this evening and I will post photos and a video shortly after. I plan on posting here, diydrones.com and fpvlab.com. Any other sites I should post on? |
Canada, NS, Halifax
Joined Dec 2005
It will get lost on DIYDrones
It is "a good thing" to post on all those sites mentioned. Also might consider on the FPV forum of RCG, and certainly on the aerial photography forum. It will be VERY popular there.
I have found that once you post things on DIYdrones, it is very hard to even find the thread or item. The underlying software seems more intended for blogging rather than thread oriented like RCG. It is what you get used to I suppose. I know I have made posts on DIYDrones, but have not been able to pick up on those threads in a long time. They are there, just not easy enough for me to find again. So posting here at RCG might be more useful, certainly for me. Jim H |
Here is a working version. I am going to add another cable tie hole to pull the video cable back behind the lens and the retract mechanics need to be redesigned. You can see that when the camera is down (deployed) all the weight is carried by the large black pan servo. When the camera is up, I designed it so the retract servo arm is in line with the push rod so there wouldn't be any rotational torque on the servo output, but there is still too much leverage. A hard landing and something will break. I am going to try a scissor lift more forward to handle the weight when it is in the up position.
UPDATE!
I have made a significant redesign to address the fact that there was too much torque on the lift servo when the camera was raised up. One hard landing and something was going to break and the servo was the likely victim. (See photo for new design). Also, the lift servo is being upgraded to an HS-81 and the rotation servo is being reduced to an HS-81. This will reduce weight significantly. I plan on building this new version tomorrow after work. I am hoping to have these ready for shipping by the end of the week. |
Joined Jul 2009
I have a customer who wants me to make something like this for him to fly on a large telemaster and carry a DH1 or NEX. I was thinking of something along the lines of a B24 belly turret which retracts straight up.
This looks like a good idea but I wonder if it could be scaled for bigger cameras. the loads on the lift servo would be very high when retracted. |
I assume you want it to go straight up when it retracts to keep the hole in the fuselage as small as possible. |
Joined Jul 2009
FINALLY! I got all the math and physics worked out and the right servos installed. The retract works flawlessly and without strain. It also appears that it can take a beating when retracted during hard landings. I need to make a few tweaks for cable management and add a brace for when the camera is in the down/deployed position, but these things are minor.
Please chime in and tell me your thoughts. I know there will be feedback on the vertical clearance but unless you have any other ideas, it is what it is.
| Thread Tools | |
| Discussion Pan and Tilt CCD Camera Mount for Axn | Zangetsu57 | Video Piloting (FPV/RPV) | 14 | Dec 01, 2012 03:54 PM |
| Discussion Nano/Micro Pan and Tilt camera mount | boredom.is.me | Indoor and Micro Models | 2 | Apr 28, 2012 07:59 PM |
| Wanted XAircraft CM130-TPS Pan/Tilt Camera Mount | Guntars | Aircraft - Electric - Multirotor (FS/W) | 0 | Mar 03, 2012 08:07 AM |
| Sold Custom Camera Mount (pan/tilt) for AP | GoRgOyL | Aircraft - General - Miscellaneous (FS/W) | 1 | Nov 11, 2006 02:56 PM |
| Help! Servos for pan & tilt camera mount | joshidharmesh | Aerial Photography | 2 | May 01, 2006 02:35 PM |
