Old Feb 24, 2013, 01:58 PM
Ken Smith is offline
Find More Posts by Ken Smith
United States, TX, Johnson City
Joined Mar 2005
I don't want to insult you but you are the first of many that has had this problem are you sure maybe take it apart let it and set for a day then go back to it. I say take it apart to reduce or remove the stress from the plane
Ken
Ken Smith is offline Find More Posts by Ken Smith
Old Feb 24, 2013, 02:00 PM
ironace is offline
Find More Posts by ironace
United States, WV, Martinsburg
Joined Oct 2012
1 1/2"? Something simply cannot be right. I have 2 of these planes and nothing is even close to that far off. Do recheck everything, and post pics if need be.
ironace is offline Find More Posts by ironace
Old Feb 24, 2013, 02:02 PM
ironace is offline
Joined Oct 2012
Agreed Ken. That's probably a good idea.
Old Feb 24, 2013, 02:44 PM
DejaD is offline
Find More Posts by DejaD
DejaD's Avatar
United States, MI, Wyandotte
Joined Jun 2011
I just disassembled one side but after sitting for 5 days there wasn't much spring back so they looked much better than they did before assembly. I'm not insulted that you guys are questioning my assembly skills or techniques. But after spending the last 25 years working in the dimensional control field, this kind of stuff drives me nuts. Even the distance between the holes on the plastic mounts isn't the same as the holes on the z brackets. It just isn't that difficult. Or maybe it is...
DejaD is offline Find More Posts by DejaD
Old Feb 24, 2013, 02:50 PM
Joined Mar 2005
Again not hurt your feelings but they are called "N" struts
Ken
Old Feb 24, 2013, 02:57 PM
DejaD is offline
DejaD's Avatar
Joined Jun 2011
Hahaha. I hear ya Ken. But a Z is just an N that nosed over on landing...
Old Feb 24, 2013, 04:47 PM
Joined Mar 2005
I am glad you can still laugh this will get worked out you are just doing something wrong and when you see it yow will be saying man oh man
Ken
Old Feb 24, 2013, 05:00 PM
DejaD is offline
DejaD's Avatar
Joined Jun 2011
I really don't think I did anything wrong. I followed all the suggestions I found here and my plane looks just like all the pictures I see here. Maybe I had a set of warped wings or something. If this plane flies like I hope it does, I won't give a fat rat's fuzzy butt how it went together. Now it's just waiting for the weather...
Old Feb 24, 2013, 06:03 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Darn I getting ready to order a second one and now it looks like there may be quality control issues now. Mine had no issues at all went together very nicely only mod I did was tap plastic to use 3mm button head screws and no nuts.
If you bought through Grayson they will help you out Nitro you are on your own.
This one an their Pitts are my favorite planes, building their Tiger Moth now.
Tim
w4yn is offline Find More Posts by w4yn
Old Feb 24, 2013, 06:47 PM
krazyman is offline
Find More Posts by krazyman
krazyman's Avatar
United States, AZ, Camp Verde
Joined Jan 2007
If you look closely at the picture of the N struts you will see a flat edge on the ends, that side goes to the top wing. The ends that are rounded mount to the bottom wing. If yours are mounted that way and you are having to twist the wing then I woud get some new struts from the seller. http://www.nitroplanes.com/60p-wako-09-wingstruts.html
Terry
krazyman is offline Find More Posts by krazyman
Old Feb 24, 2013, 07:19 PM
WestTexasKing is offline
Find More Posts by WestTexasKing
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
DejaD, pics of the install maybe?
Could be time to send a portion of the model back and get a replacement...that's a lot of inaccuracy!
Just for reference, most everyone in the biplane world calls the outer struts on the wing N struts, and the inner struts cabane struts.
The problem with calling them N struts are that sometimes they're not arranged in the same N configuration, sometimes they're backwards from the same point of view.
Another problem is that not all biplanes use the N configuration, some of them don't have the middle strut making it an N shape, some have cross braces between them in an X shape, and others use a single strut (like a Pitts).
Technically the term for the outer struts are interplane struts, because they tie the two wing planes together.
Cabane struts are the correct technical term for the inner struts attaching wings to fuselage.
However, since we're dealing with a tiny scale version of the real thing, I believe the term Z bracket is somehow fitting...though I sincerely hope my N struts don't turn into Z brackets on landing
WestTexasKing is offline Find More Posts by WestTexasKing
Old Feb 24, 2013, 08:17 PM
DejaD is offline
DejaD's Avatar
Joined Jun 2011
I will have to take a look for the flat spot and see how I mounted it. Thanks for the support, fellas. I really appreciate it.
Old Feb 24, 2013, 08:30 PM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
Tim
No need to worry Tim. Order it, as I'm sure it will go together fine just like all the others have. I really doubt there is any quality control issues. I'm sure Deja will get his figured out.
sj3cub is offline Find More Posts by sj3cub
Old Feb 25, 2013, 08:52 AM
6Sally5 is offline
Find More Posts by 6Sally5
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
Hey Deja...check out my post about this issue at #610. Not as severe as yours, but this was my fix. Changing the plastic brackets to plywood was a great choice for me. Good luck.
6Sally5 is offline Find More Posts by 6Sally5
Old Feb 25, 2013, 11:06 AM
Joined Mar 2005
I wanted to post some photos both of my planes are setup in this way
Ken
Sold Dumas Waco YMF-5 Biplane EP Kit 35" $50 shipped carrera0to60 Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2012 07:21 AM
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 09:06 PM
Off Site Vintage PICA WACO YMF.3 NIB For Sale Come check it out! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 23, 2012 09:05 AM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 06:35 AM
For Sale LPU Great Planes Waco YMF-5D RTF $300 RCGill Aircraft - Fuel - Airplanes (FS/W) 9 Mar 22, 2012 12:42 AM
