Old Feb 10, 2013, 06:08 PM
seflier is offline
Find More Posts by seflier
Seflier
Joined Jun 2012
Hi Ken,
No, not at all...the poly actually help seal ad protect them...if your decals are coloreful, it makes them look even better.....experiment to verify, but i have tried it on all 11 of my hgr birds and decals are just fine...btw, you
r suggested fasteners worked great!
happy landings
seflier is offline Find More Posts by seflier
Old Feb 10, 2013, 06:58 PM
Ken Smith is online now
Find More Posts by Ken Smith
United States, TX, Johnson City
Joined Mar 2005
Originally Posted by seflier View Post
Hi Ken,
happy landings
Thanks I will try the poly, as far as the fasteners go I wish I could take credit but someone and I don't know who suggested them (the 3mm) I just expended on it. Darn good idea though makes that plane fly like a trooper
Ken Smith
Ken Smith is online now Find More Posts by Ken Smith
Old Feb 12, 2013, 08:28 AM
DejaD is offline
Find More Posts by DejaD
DejaD's Avatar
United States, MI, Wyandotte
Joined Jun 2011
Well I'm told I should have my Waco on Friday...I can't wait to see it..
I stumbled across a old thread and was wondering if it is something that couuld be used to reinforce or remake the plastic strut mounts that seem to be a weak point on this plane. The product is called Instamorph moldable plastic. I don't know what kind of tensile strentgh the stuff has after it hardens, anyone have any experience with it?
DejaD is offline Find More Posts by DejaD
Old Feb 12, 2013, 02:39 PM
Joined Mar 2005
I really wouldn't worry about this there were two, three at the most that had problems and I think the best approach to correct any problems is to go with the larger bolt, washers and locknuts. This has been covered in about 5 or 6 post by me and others. I have two planes each has over 60 HOURS of flying on them with no problems.
Ken Smith
Old Feb 12, 2013, 03:50 PM
seflier is offline
Seflier
Joined Jun 2012
6Sally5
Your props were a great idea! Thanks for sharing...I bought a bag of them....Question regarding the fit of the prop.....The zinger 12/6 does not fit on my motor stem...what must be done to accommodate this prop on this a/c? TIA
Happy landings
Seflier
Old Feb 12, 2013, 03:52 PM
DejaD is offline
DejaD's Avatar
Joined Jun 2011
Thanks Ken. I'm hopeful that it won't be an issue, I was just preparing myself should a repair/replacement be needed. That Instamorph stuff look interesting anyway. I thought about picking some up just to play with. Theres got to be a million uses for that stuff...or at least one good one.
Old Feb 12, 2013, 04:37 PM
skylane42 is online now
Find More Posts by skylane42
USA, MI, Portage
Joined Sep 2003
Seflier- props
is the prop shaft too big or too small? If too big then ream out prop to correct size, If too small, you need a spacer.
skylane42 is online now Find More Posts by skylane42
Old Feb 12, 2013, 07:28 PM
seflier is offline
Seflier
Joined Jun 2012
prop shaft that came with a/c is just a bit oversized...you say ream out, i trust my best bet is to put it on a drill press to ensure a straight accurate drill hole correct?
TIA
Happy Landings
Old Feb 12, 2013, 07:33 PM
Norm62 is offline
Find More Posts by Norm62
United States, SC, Greenville
Joined Jun 2011
TIA
Happy Landings
Or this...
http://www3.towerhobbies.com/cgi-bin...&I=LXEGH6&P=ML
...But yes.
Norm
Norm62 is offline Find More Posts by Norm62
Old Feb 12, 2013, 08:13 PM
6Sally5 is offline
Find More Posts by 6Sally5
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
6Sally5
Happy landings
Seflier
I have a prop reamer that is the same size as the stock prop. Also I believe a 5/16th's drill bit will open the hole to the correct size.
6Sally5 is offline Find More Posts by 6Sally5
Old Feb 12, 2013, 10:32 PM
Rem Fodder is offline
Find More Posts by Rem Fodder
Radio-active flyer
Rem Fodder's Avatar
Canada, ON, Port Hope
Joined Apr 2012
I was wondering if someone could jog my memory regarding mixing baby powder and Poly Crylic, and to what consistency the mix should be for priming? My Waco is finally on the bench and the repaint underway. There are a few dings and gaps to fill in before the priming begins.
Also, has anyone had any luck with the LEDs? I can't fathom the red landing lights? That's not a new FAA regulation is it?? LOL!!
Thanks.
Rem
Rem Fodder is offline Find More Posts by Rem Fodder
Old Feb 13, 2013, 09:41 AM
twowingtj is offline
Find More Posts by twowingtj
United States, NY, Binghamton
Joined Feb 2013
New to RCGroups. I have the Waco and have seen several posts indicating that the CG as listed in the manual is wrong. I'd like to get a good general consensus by those that have been flying the plane for a while as to what the CG should actually be for good sport aerobatics. Thanks guys
twowingtj is offline Find More Posts by twowingtj
Old Feb 13, 2013, 09:57 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
My Patch Plus sample arrived from 3M. Looks promising. looks the same as regular light weight spackle. I keep you guys posted.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Feb 13, 2013, 11:26 AM
warhead_71 is online now
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Originally Posted by warhead_71 View Post
These pilots from Hobbyking are pretty nice and the price is right.
For anyone who is interested... I ordered these and they fit PERFECTLY! The cockpit width is about 73mm or 2-7/8". This pilot is about 66mm or 2-5/8" at the shoulders so there's about 1/8" clearance at each shoulder (or 3.5mm). The height of the head is just at the top of the windshield. There are two color versions, a tan coat and a green coat. And if you get colored Sharpies, you can make him any color you want.
Just so's you know, HK has a confusing way of measuring the sizes. Instead of providing an actual scale, they usually give three dimensions: Length, Width, Height. But Length is the shoulder-width and Width is the chest depth from front to back.
Other HK pilots that will fit:
http://www.hobbyking.com/hobbyking/s...emale_1_6.html (HK's measurements are wrong, she's about 50mm wide at the shoulders and fits great).
http://www.hobbyking.com/hobbyking/s...x29x44mm_.html
And just for kicks, I think this gauge panel would fit pretty good if you want to add more details:
http://www.hobbyking.com/hobbyking/s...S_Habicht.html
warhead_71 is online now Find More Posts by warhead_71
Old Feb 13, 2013, 03:39 PM
seflier is offline
Seflier
Joined Jun 2012
6Sally5/skylane/norm
Thanks for your replies and info....I contacted another pilot in my club and he volunteered to open the props up with his drill press....I dont have a reamer and I have no prior experience using one and want to ensure the hole is straight and accurate.
Cannot wait for spring to fly again on te field.
Happy Landings
Seflier
Sold Dumas Waco YMF-5 Biplane EP Kit 35" $50 shipped carrera0to60 Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2012 08:21 AM
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 10:06 PM
Off Site Vintage PICA WACO YMF.3 NIB For Sale Come check it out! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 23, 2012 10:05 AM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 07:35 AM
For Sale LPU Great Planes Waco YMF-5D RTF $300 RCGill Aircraft - Fuel - Airplanes (FS/W) 9 Mar 22, 2012 01:42 AM
