Old Jan 15, 2013, 10:26 AM
skylane42 is online now
Find More Posts by skylane42
skylane42's Avatar
USA, MI, Portage
Joined Sep 2003
ken, Nitro planes shows the servo.. check at the bottom of the page.
http://www.nitroplanes.com/dy8952parts.html
but, out of stock....
skylane42 is online now Find More Posts by skylane42
Old Jan 15, 2013, 10:45 AM
Ken Smith is online now
Find More Posts by Ken Smith
United States, TX, Johnson City
Joined Mar 2005
Yes I know and Garyson has the servo in stock but does it have the 18" lead or is it the short one that is used on the rubber and elevator
I asked Garyson and never did get a straight answer. I sent a request to Niro asking but I am not holding my breath for an answer let alone a correct one.
I kind of got on Garyson because it appeared my question was not worth any effort to find the correct answer.
Thanks to you for looking for me
Ken Smith
Ken Smith is online now Find More Posts by Ken Smith
Old Jan 15, 2013, 12:05 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Call them they easy to reach and talk to.
Tim
Ken Smith
w4yn is offline Find More Posts by w4yn
Old Jan 15, 2013, 12:59 PM
Joined Mar 2005
Call who Garyson? I have called twice never had anyone answer plus sent an email asking no answer.
Ken
Old Jan 15, 2013, 04:33 PM
Cubcrazy is offline
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
One thing that I find very common to the foamy model emthusiast, is preferring to purchase OEM replacement parts when something goes wrong. There are so many options out there for electronics. I am boggled by the lengths that people will go to get an OEM radio component. No offense intended..more like...suggesting that it is best to find the best value in a replacement part, rather than making sure it is identical to stock. If I have a situation where I need a long lead servo, I open the case of a servo with incorrect..and solder new servo wire to whatever length I want. (I keep rolls of servo wire handy available at Servo City and HK) I make my own servo leads whenever warranted. Maybe it is because I came to the foamy model segment after years of traditional kit building. I am just used to fabricating solutions that are generally better than OEM anyway.
-Cub
Cubcrazy is offline Find More Posts by Cubcrazy
Old Jan 15, 2013, 04:55 PM
poziovahim is offline
Find More Posts by poziovahim
poziovahim's Avatar
United States, NM, Espanola
Joined Nov 2011
-Cub
Roger That!
Dan
poziovahim is offline Find More Posts by poziovahim
Old Jan 15, 2013, 04:58 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
-Cub
I agree 100% with you . i make my own servo wires and i usually replace worned out oem parts with something low cost but better quailty .
i have a A-1 Skyraider (from starmax ) that i purchased from Bananna hobby . one of the retracts burned out on the first landing. i called up BH after a few tries got ahold of them . they agreed to replace . i had to ship out the damaged one,(cost me somewhere around 10.00 . they sent me a replacement 6 weeks later and it was damaged as well. i went with some other retracts after that . i learned why bother getting a oem when there bound to be super cheap or will break just as fast as the first oem . i have a Dynam Peaks(pitts special) the rudder servo(17 gram) stripped on its 2nd landing i replaced it with a power up metal gear servo which ony cost me 7.00 . i have over 20+ flights on the pitts with no problem . i dont bother calling or email the sellers to replace a part that was cheap from the get go. i take it as a wash and move on . another thing i do is i usually just order the kits and put my own parts ,but unfortunetly the Waco doesnt come as a kit . "yet"
think of it this way your buying a reciver ready plane for 130.00. four hi qualty servos will run you the price of that plane . dont expect much from the servos . esc or motor that come with these low cost planes . there bound to strip, burn out or malfunction.
THESANDMAN is offline Find More Posts by THESANDMAN
Old Jan 15, 2013, 05:14 PM
Joined Mar 2005
Add more
-Cub
Funny thing I was just thinking that myself, not sure if I could solder the servo leads but was thinking about ordering a PZ sevo and putting that in, come to find out, I have a brand new in my pile of stuff
I don't surpose it would hurt if it have more torque then the stock one
Thanks for the idea
Ken
The PZ servo for the Trojan dropped in perfect, sometimes I get so focused on an idea I have to get hit in the face to see the trees
Old Jan 15, 2013, 06:00 PM
skylane42's Avatar
USA, MI, Portage
Joined Sep 2003
On replacement servos.. I had one get stripped out on a EDF. I could not get a OEM servo so I replaced it with the closest I could find. Only problem was .. the travel was not the same. I ended up trying different horns and positions in the servo arm.. Ended up very close but not exact. And when the 2 servos are on a Y .. you can`t adjust travel for the difference.
Old Jan 15, 2013, 06:12 PM
Joined Mar 2005
That is the reason I always use differential when possible, I can adjust the throw of each servo, plus I like the way it make the models turn. I have found that you can do too much and then the model flies very poorly
Thanks for the input I will be looking for that.
Ken Smith
Old Jan 15, 2013, 06:36 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
I know everybody has weighed in, but here is my two cents. I have a drawer full of OEM cheap crappy servos that don't work or don't center. What does that tell you.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Jan 15, 2013, 07:15 PM
THESANDMAN's Avatar
Joined Oct 2010
it tells me that you should make some flying combat wings with the servos that do work (even if they dont center right and . do combat
Old Jan 15, 2013, 11:23 PM
6Sally5 is offline
Find More Posts by 6Sally5
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
Without going into detail I managed to break an aileron servo. I am being told by Garyson Hobbies that the original servo with the 18" lead is not available, if any of you have had to replace this item., then please let me know where and P/N
Ken Smith
Yeah...something else I get to fix before even flying it! my left aileron servo sounds like it's stripping a tooth or two. Sure looks pretty sitting on top of my wife's car in the garage, tho!
6Sally5 is offline Find More Posts by 6Sally5
Old Jan 16, 2013, 01:50 AM
WestTexasKing is offline
Find More Posts by WestTexasKing
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
For those that ordered from killerplanes...
What's the deal with the Dynam flap installation option on the Waco page?
Do they actually install flaps on the Waco if you select that option?
I didn't know there was enough room for flaps on a Waco...so, maybe it was an oversight?
Here's the link to the page:
http://www.killerplanes.com/content/...e-arf-or-rtf-0
WestTexasKing is offline Find More Posts by WestTexasKing
Old Jan 16, 2013, 02:10 AM
Cubcrazy is offline
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
In a situation like that (a Y-harness) replacing both servos is the best thing to do. let's say the OEM servo on the left aileron just died...how long do you suppose the right one is going to last? Point being..just get a matched set upgrade, and not have to worry about it again for at least a while. You know what they say, not if, but when.
-Cub
Sold Dumas Waco YMF-5 Biplane EP Kit 35" $50 shipped carrera0to60 Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2012 07:21 AM
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 09:06 PM
Off Site Vintage PICA WACO YMF.3 NIB For Sale Come check it out! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 23, 2012 09:05 AM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 06:35 AM
For Sale LPU Great Planes Waco YMF-5D RTF $300 RCGill Aircraft - Fuel - Airplanes (FS/W) 9 Mar 22, 2012 12:42 AM
