Old Nov 08, 2012, 09:52 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
**Wagstaff**
Cubcrazy is online now Find More Posts by Cubcrazy
Old Nov 09, 2012, 07:31 AM
w4yn is online now
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Originally Posted by Cubcrazy View Post
**Wagstaff**
Tnx, old gray cells and never could spell worth a ------
Tim
w4yn is online now Find More Posts by w4yn
Old Nov 09, 2012, 07:33 AM
w4yn is online now
Joined Jan 2007
Originally Posted by jwellsy View Post
Girl co-pilots go in the front seat.
All my "busty" pilots are either too big (sic) or to small (shame full)
Need to find some correct scale YL's with proper enhancements!
Tim
Old Nov 09, 2012, 07:57 AM
e_gadgetgeek is offline
Find More Posts by e_gadgetgeek
e_gadgetgeek's Avatar
United States, OH, Troy
Joined Jun 2004
Originally Posted by P 51 Jockey View Post
Finished! She's ready to fly. I need to paint the white clevises and do a little touch up, but that can wait until after I fly it this Sunday!
Oh, she has a 700 watt 4240 750kv motor stuffed in on 4 cell.
What type of paint did you use? Now that I've successfully flown my a couple times and it is getting windy here again, I'm thinking about painting mine but don't want to screw it up.
Steve
e_gadgetgeek is offline Find More Posts by e_gadgetgeek
Old Nov 09, 2012, 08:14 AM
jwellsy is online now
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
Originally Posted by w4yn View Post
Tell that to Patti Winestaff
Tim
You tell her she's a co-pilot
jwellsy is online now Find More Posts by jwellsy
Old Nov 10, 2012, 08:13 AM
skylane42 is offline
Find More Posts by skylane42
skylane42's Avatar
USA, MI, Portage
Joined Sep 2003
motor stutter
Got my Waco all done but won`t be flying anytime soon. Question, did anyone figure out a cure or reason for the stuttering on slow start up on the stock esc and motor? Mine does stutter if I give just a slight bit of throttle but if I just go to like 1/8 throttle it does not show up...
skylane42 is offline Find More Posts by skylane42
Old Nov 10, 2012, 08:38 AM
e-flight-Ken is online now
Find More Posts by e-flight-Ken
United States, MD, Clarksville
Joined Aug 2007
If you go back and review the ESC issue in this thread you will find that the solution is to replace the ESC with one that actually works. There are many options available on aftermarket ESC's. The $13 ESC supplied with the Waco is marginal at best and may in some cases actually work - if you are lucky! But there is nothing you can do about it if is defective except replace it.
As the old saying goes, "you get what you pay for".
Ken
e-flight-Ken is online now Find More Posts by e-flight-Ken
Old Nov 10, 2012, 09:49 AM
Norm62 is offline
Find More Posts by Norm62
United States, SC, Greenville
Joined Jun 2011
Mine does the stutter at very slight throttle sometimes as well. I just advance the throttle a little bit more. I can't fly at 1 or 2 clicks of throttle anyway. It comes down cool and seems to be fine, but I use a Dimension Engineering sport BEC (that I can move from plane to plane) just in case. I have about 25 flights on it so far with no problems and it flies great! I've only had 1 ESC give up the ghost in over 20 planes and that was on a small edf where I actually had the fan installed too tightly in the fuse causing the fan to rub against the housing slightly. All but one of those ESCs are HK Plush or Dynam ESCs from Hobby Partz. Call me lucky I suppose. Anyway, It's working for me..... Your mileage may vary.
Norm
Norm62 is offline Find More Posts by Norm62
Old Nov 10, 2012, 06:47 PM
w4yn is online now
Joined Jan 2007
My Dynams does stutter also but works fine, has many flights on it. I think I just got a lemon happens. Good part is I purchased at Grayson and they will take care of it.
Tim
Norm
Old Nov 10, 2012, 10:45 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Stuttering is often caused by the "soft start" effect. If the ESC you have does not allow for start-up adjustments, then the motor will often studder on start-up at very low throttle settings. It actually doesn't hurt anything. It sounds weird, and requires you to take the throttle up a bit before bringing it back down to a very low idle. If the ESC does not have a programming adjustment for this, then you can swap it out and toss it in the ol' scrounge box. It may not do it with a different motor; largely dependent on internal resistance values and input voltage of the particular setup.
-Cub
Old Nov 11, 2012, 10:13 AM
Norm62 is offline
Joined Jun 2011
Hmm, Hadn't thought about the soft start feature. I believe that is adjustable on these ESCs. It's lit up on the prgramming card anyway.
Norm
Old Nov 11, 2012, 10:44 AM
skylane42's Avatar
USA, MI, Portage
Joined Sep 2003
The manual details the esc programing for soft start and other options. I think I read in these post that the esc comes preset at normal. The other options are soft start and super soft start. If you figure something else out, let us know...
Old Nov 11, 2012, 11:02 AM
Ken Smith is offline
Find More Posts by Ken Smith
United States, TX, Johnson City
Joined Mar 2005
On the ESC I agree with e-flight Ken, R & R that baby you will be a happy and relaxed flier. I did a thread on ESC and I believe the the HobbyWing line is the best bang for the buck, cost a little more but great performance and peace of mind
Ken Smith
Be Safe
Ken Smith is offline Find More Posts by Ken Smith
Old Nov 11, 2012, 11:27 PM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
Did all of you guys Waco's come with a 50 amp esc? What amp esc's have you guys been putting back in them? I think I've read anywhere from 40 to 45 amp esc's, or are most of you putting a 50 amp back in? Anyone put a watt meter on the stock setup to see what its pulling?
sj3cub is offline Find More Posts by sj3cub
Old Nov 12, 2012, 07:14 AM
w4yn is online now
Joined Jan 2007
Mine came with 40 and was DOA, I installed a 50 THZ that I had in shop.
Tim
Sold Dumas Waco YMF-5 Biplane EP Kit 35" $50 shipped carrera0to60 Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2012 07:21 AM
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 09:06 PM
Off Site Vintage PICA WACO YMF.3 NIB For Sale Come check it out! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 23, 2012 09:05 AM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 06:35 AM
For Sale LPU Great Planes Waco YMF-5D RTF $300 RCGill Aircraft - Fuel - Airplanes (FS/W) 9 Mar 22, 2012 12:42 AM
