Old Oct 24, 2012, 12:23 AM
visualizerent is offline
Find More Posts by visualizerent
United States, CA, Nevada City
Joined Sep 2012
Landing Gear Durability Question
How's the stock main landing gear holding up for you guys that are flying the Waco alot?
Is the stock gear holding up OK on grass fields after many cycles?
How's the tailwheel steering? Good positive control?
I gotta Peaks and the gear is holding up OK, but on pavement only...I have the HK 1400mm J-3 Cub that's pretty weak in this department, she is also a bit too heavy/high wing loading (for a cub).
I'm looking for a fun, relaxing, touch and go machine that can take a little abuse.
JB
Nevada City, CA.
visualizerent is offline Find More Posts by visualizerent
Old Oct 24, 2012, 06:58 AM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
JB
Nevada City, CA.
Have not maidened mine but fly there Pitts a lot, small wheels so grass can be an issue. Gear itself is fine, just beef up mounting area with some balsa and epovy filler. The Pitts is a pussy cat to land I expect Waco to same.
For real easy touch and goes just get a PZ T-28, one of the best all round planes ever.
Tim
w4yn is offline Find More Posts by w4yn
Old Oct 24, 2012, 07:34 AM
Norm62 is offline
Find More Posts by Norm62
United States, SC, Greenville
Joined Jun 2011
JB
Nevada City, CA.
Love mine. 4 more flights yesterday. I fly off grass (cut short weekly) and the landing gear is holding up fine. I have not however, had any hard landings yet, but it seems up to the task. Take offs are beautifully scale if you just gently ease on the throttle and keep things straight with the rudder / tail wheel (which provides great control IMO). It lifts off at just about half throttle and I fly most of my entire flights at half to two thirds throttle and get about 7-8 minutes on a Zippy 4s 2650mah battery. I posted a video back on page 12 of this thread that shows the grass at my field and some scale flight. I'm really enjoying mine. It looks awesome in the evening sky with the sunset as a backdrop! My only concern is that the motor comes down pretty hot. I'm going to cut out more of the spaces between the cylinders on the dummy motor in the cowl and see if the added airflow helps.
Norm
Norm62 is offline Find More Posts by Norm62
Old Oct 24, 2012, 11:38 AM
CryHavoc is offline
Find More Posts by CryHavoc
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
United States, TX, Copperas Cove
Joined Apr 2000
It looks like Grayson and PW-RC are out of stock on these. Besides nitroplanes, is there anywhere else selling these?
CryHavoc is offline Find More Posts by CryHavoc
Old Oct 24, 2012, 12:20 PM
jwellsy is offline
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
Contact Steve at killerplanes.com . It's not on their website, but that's where I got mine.
jwellsy is offline Find More Posts by jwellsy
Old Oct 24, 2012, 12:25 PM
w4yn is offline
Joined Jan 2007
Norm
Exactly my experience, I can set timer to 8 minutes but if I do some full power verticle rolls etc it will come back at around 7.4-5 volts per cell, so I backed it down to 6 and ignore buzzer if I am just relaxing on throttle. I use 2600 Sky 30c cells. Motor and pack are warm but not hot at least in current 70 degree weather.
Tim
Old Oct 24, 2012, 02:40 PM
krazyman is offline
Find More Posts by krazyman
krazyman's Avatar
United States, AZ, Camp Verde
Joined Jan 2007
JB
Nevada City, CA.
I have not had any problems with the landing gear, and I have landed pretty hard on occasions. I haven't flown off grass, and if I were to do that I think I would remove the wheel pants. The only problem I have had with this plane was the stock ESC. It failed after the third flight.
Terry
krazyman is offline Find More Posts by krazyman
Old Oct 24, 2012, 05:58 PM
jwellsy is offline
Joined Aug 2012
Terry, what were the symptoms/events when the ESC failed?
Old Oct 24, 2012, 07:35 PM
pmacko is offline
Find More Posts by pmacko
Go 4th Air Force
pmacko's Avatar
United States, PA, Washington
Joined Sep 2011
Terry
I fly off of grass AND have kept my pants on....
...does that sound right?
pmacko is offline Find More Posts by pmacko
Old Oct 24, 2012, 07:54 PM
krazyman is offline
krazyman's Avatar
Joined Jan 2007
When I put a new prop on I ran up the motor and when I went past 1/2 throttle the motor started to stutter and stopped turning. I checked the connections and could not find anything wrong. I ran the motor up again and the same thing happened except this time the motor started to get very hot. I put in a different ESC and no more problems. It has been flying great ever since with all the stock equipment except for the ESC, and the 12x8 Zinger wood prop.
Terry
Old Oct 24, 2012, 07:59 PM
krazyman is offline
krazyman's Avatar
Joined Jan 2007
The grass I would have to fly off of and land on is pretty long and would probably get caught in between the pants and the wheel. I just feel more comfortable flying off the hard pack runway at the CAM field in Sedona AZ.
Terry
Old Oct 24, 2012, 08:22 PM
jwellsy is offline
Joined Aug 2012
Terry, your at least the second person on this thread that had a problem with the ESC. I think I'll go ahead and order one to have it on hand for when mine shoots craps.
What kind/size ESC did you replace it with?
Old Oct 24, 2012, 08:24 PM
Norm62 is offline
Joined Jun 2011
... and the 12x8 Zinger wood prop.
Terry
I like that idea... Bet that looks cool. Does it work with the stock adapter?
Old Oct 25, 2012, 04:14 PM
krazyman is offline
krazyman's Avatar
Joined Jan 2007
I used a FMS 50 amp ESC that I had from another plane.
Terry
Old Oct 25, 2012, 04:17 PM
krazyman is offline
krazyman's Avatar
Joined Jan 2007
I had to ream out the prop to fit, other than that it fit just fine. It also seems to pull less amps and flys a little faster.
Terry
Sold Dumas Waco YMF-5 Biplane EP Kit 35" $50 shipped carrera0to60 Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2012 07:21 AM
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 09:06 PM
Off Site Vintage PICA WACO YMF.3 NIB For Sale Come check it out! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 23, 2012 09:05 AM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 06:35 AM
For Sale LPU Great Planes Waco YMF-5D RTF $300 RCGill Aircraft - Fuel - Airplanes (FS/W) 9 Mar 22, 2012 12:42 AM
