Old Nov 19, 2003, 04:51 PM
MRX2099 is offline
Find More Posts by MRX2099
MRX2099's Avatar
Dayton Beach, FL
Joined Nov 2003
Wal-Mart Foam boards 20 X 30 X 3/16
Are these "foam boards" the same as depron or what type foam are they? are they good to make "foamie" type planes out of ? they have a plasticy like skin on both side should one peel this off or leave it on or are they any good at all? Also what type foam are those can holder/insulators made from, if those were a litte thicker and you could get it in sheets has anyone made anything out of that type foam?
MRX2099 is offline Find More Posts by MRX2099
Old Nov 19, 2003, 05:19 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Quartz Hill
Joined Nov 2003
The "Strudy Board" foam boards that you can get at Wal-Mart and other places is essentially "Depron" sandwiched between paper. If the paper is left on it is too heavy a material to use for most smaller electric-powered planes. However, if you soak in water and remove the paper, you can get an excellent 0.6 ounce per square foot material you can build with. There are many ways to remove the paper, but basically you soak and peel it.
I think the cup holder type of foam is polyurethane, which would be too squishey and flexible to build with. Also heating this foam (as with a hot wire) releases toxic gasses.
foamflyer is offline Find More Posts by foamflyer
Sold Carbon fiber 1/16" x 3/16" x 15" lots of 24 Zagabond Aircraft - Fuel - Airplanes (FS/W) 0 Sep 15, 2005 11:25 AM
For Sale Flat carbon fiber 1/16" x 3/16" x 15" Zagabond Aircraft - General - Radio Equipment (FS/W) 2 Sep 10, 2005 06:18 AM
Wal-Mart foam gliders. Seasonal? turbojoe Electric Ducted Fan Jet Talk 3 Jan 06, 2003 06:24 PM
Wal-Mart foam Glider turned Free Flight Sparr Foamies (Kits) 10 Apr 14, 2002 06:35 PM
Wal-Mart foam gliders JamesH Foamies (Kits) 3 Jan 24, 2002 05:02 PM
