| Thread Tools |
| This thread is privately moderated by evltoy, who may elect to delete unwanted replies. |
Thanks for taking the time out to comment on my problem
1 - The step-down transformer only has 2 coated wires coming out of it which can been seen in the pics. 2 – No burnt marks on the caps. It’s a shadow from the lighting I used to take the pic. Values of the capacitors are 680uf 200V. I’m 100% sure there are no burnt marks around the caps. 3- The part circled in red is the off/on switch. There is no rectifier that I can see. Could it be that the rectifier is on the same PCB above the caps and next to the AC socket? There are 3x yellow blocks with the following values; Over active & neutral plug – .68K275V~X2 CARLI MPX40/100/21 Closest to outside of case .47K275V~X2 CARLI MPX40/100/21 Closest to Caps .68K275V~X2 CARLI MPX40/100/21 After writing this all up I decided to take the grey covers over the Mosfet’s (I think that’s what it’s called) that sit on the heat sink and I found an obvious problem. So what do you think I should do now
Like I mentioned in my post, I thought that may be the problem. They are actually power transistors. Here is the data sheet> http://www.datasheetcatalog.org/data...ec/2SC2625.pdf
Another component may have been wiped out too in the process but I would first try to replace the power transistor (P/N 2SC2625) and see if that does the trick. I'm not sure who has them but you could try the obvious digikey.com or Newark.com or google the part number... Maybe Radio SHack too but they dont have much these days. You also may have to look for a similar part if they don't make this one anymore. Compare datasheets on the parts and get something as close as you can. |
yes, 2sc2625 power transistors need to be replaced. Suggest you get 3 to 5 pcs one time. They are not expensive, about $3.00 each. you may check your local electronic store in Australia first.
s.p. If you still can't find the 2sc2625, you may find the equivalent transistor from the link http://alltransistors.com/crsearch.p...nf=&caps=TO218. I have input all critical parameter matching 2s2625, pick the one closest match. |
Well after failing to find a local supplier that was cheap, I had to resort to Ebay/China.
The model matches what I need, but it does look slightly different from the one I blew up. I hope I haven’t bought the wrong part. If all goes well I have a spare one too. I guess in 2 weeks time I will find out. Here is what I bought http://www.ebay.com/itm/ws/eBayISAPI...m=180855765846 |
Going to be tough... tell me about it
![]() I do have a multimeter that can be used to check if the driver transistors are any good. In fact it has a NPN & PNP port for me to stick the transistors into. Only problem.. I dont know how to use it as I have never needed to at school (10yrs ago). If it helps the meter I have is a Jaytech QM1530 |
| Thread Tools | |
| Discussion PSU powering 3 reversible ESC + 3 outrunner dc motors causing the PSU to trip. | late_fee | Power Systems | 4 | Aug 05, 2012 08:22 AM |
| Question Is my electric motor dead? Or just needs a cleaning? | flymore | Power Systems | 3 | Jul 07, 2012 01:59 AM |
| Discussion How to us a laptop PSU as my Charger PSU | rukie | Batteries and Chargers | 3 | Aug 23, 2011 12:51 PM |
| Discussion Troubleshooting "dead" lipo | cloud-9 | Batteries and Chargers | 18 | Jan 23, 2008 08:15 AM |
| Can anyone help me troubleshoot my dead br? | webcrawler | BladeRunner Heli | 3 | Feb 28, 2005 03:02 PM |
