Old Nov 19, 2003, 03:35 PM
asennad is offline
Find More Posts by asennad
asennad's Avatar
Joined Jun 2003
Turning 2D into 3D Autocad HELP!!
I have figured out how to create 2D fuselage bulkheads in AutoCad 2000. But for the life of me I cannot figure out how to take those bulkheads and turn them into a 3D representation.
How do I use them to form a 3D fuselage?
asennad is offline Find More Posts by asennad
Old Nov 19, 2003, 06:51 PM
gjahnke is offline
Find More Posts by gjahnke
Joined Nov 2003
First you will need to create a blank 3D oblect, then you should be able to simply copy your 2D elevations onto the 3D object. You need to create a new object and copy btwn the files, though. If you are new to 3D in autocad, you might consider picking up a book on the subject. It increases the complexity of the project tenfold.
gjahnke is offline Find More Posts by gjahnke
Old Nov 19, 2003, 07:01 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Like this...
AirX is offline Find More Posts by AirX
Old Nov 19, 2003, 07:04 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I do this all day every day.
I start with a 2-D shape and make a region out of it, then extrude it to the thickness I want it to be. To get to the point where you can do the thing s like I have on the 757 in the above post takes a lot of practice, time. I started with a 3-view and went from there with this model.
Cheers,
Eric B.
Old Nov 19, 2003, 08:56 PM
gjahnke is offline
Joined Nov 2003
Ok, so if you do it that way, do you draw each part individually and then use the independant pieces to create your 3D view? Or can you do the entire airframe and then render it 3D all at once? Your way seem a lot easier than the kludge I have been using
Old Nov 19, 2003, 11:37 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
One peice at a time. Lotsa work for sure. AutoCAD is tedious in some respects.
Cheers,
Eric B.
Old Nov 20, 2003, 12:34 AM
asennad is offline
asennad's Avatar
Joined Jun 2003
This subject would make a good tutorial for the group!
Old Nov 20, 2003, 12:50 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
The quick way:
1 - make the part in 2D
2 - use command "Region" to make all the lines into one closed line. Type Region in the command line, enter, select all the lines and hit enter again.
If the region fails there is an open gap somewhere, zoom in and mend where neccesary.
3 - use command "Extrude"
Enter extrude, on promt type in desired thickness and viola its done. Rendering is done afterwards (takes no time)
To practise, draw a square, extrude it and rotate view to see how it works/looks.
Haldor is offline Find More Posts by Haldor
Old Nov 20, 2003, 08:36 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Like Haldor said...
Cheers Haldor, how is the Midi Mig coming, I have been folowing the pictures and the thread. Looks great.
Cheers,
Eric B.
Turning SS into combat plane! (HELP) csisfun Parkflyers 54 Mar 03, 2004 07:24 AM
Switchback 3D retract help MAH42 Parkflyers 3 Jan 25, 2003 06:36 PM
Switchback 3D retract help! Martin Hunter Parkflyers 23 Nov 19, 2002 01:25 PM
i want to get into electric jets. help plz wingrider Electric Ducted Fan Jet Talk 9 Jul 02, 2002 11:04 PM
Turning Ailerons into Spoilers ??? Dr.J Electric Sailplanes 18 Apr 10, 2002 08:00 PM
