Old Nov 03, 2012, 01:35 PM
out_of_control is offline
Find More Posts by out_of_control
United Kingdom, Northern Ireland, Belfast
Joined Oct 2012
Originally Posted by rob10000 View Post
Carbon fiber dust isn't any more dangerous to your health than the byproducts of any other sanding or grinding operation - It's not some highly toxic material.
With that being said, the normal precautions you would take when working with ANY material where you are creating airborne dust should be taken.
OOC, CF has RF blocking properties. In this application G10 would probably be the best chioce.
Good info, i'm trying to find a local source for G10 in N.Ireland or UK
out_of_control is offline Find More Posts by out_of_control
Old Nov 03, 2012, 09:14 PM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
Originally Posted by out_of_control View Post
Anyone comment on the FC selection or the frsky module ?
I recently fitted a frsky module to my 9x. It has an audible RSSI indicator so it will beep at you if the radio link degrades at a distance, allowing you to turn around, rather than flying out of range unknowingly. It has failsafe on all channels, unlike the orig RX which has no failsafe at all (saves a potential flyaway).
danger_mouse is offline Find More Posts by danger_mouse
Old Nov 03, 2012, 09:16 PM
Joined Jan 2007
out_of_control, you might also find the OV3RQUAD of interest if using DJI 450 type arms.
Old Nov 04, 2012, 08:35 AM
Joined Oct 2012
If I have read right, it helps make sure you don't fly out of range and lose the quad.
I've just spent the morning watching vids 1 - 10, the commentary is great, gives me a laugh at times too when nick describes things that don't work as they should
Now that i've seen the vids i'm going to build the frame and arms from wood, looks like they work just fine, and I probably have some lying around my shed.
As a first build it will be really helpful to have a standard that I know works and a tutorial to help me all the way through.
Thanks for the additional info danger_mouse, as i'm going with this original design i'll stick with this design. Or i'll end up looking at so many versions i'll get real lost.
I keep adding a few bits to my list, like prop balancer, charger, the things most of you guys would have anyway.
This is a really well done tutorial, it explains all the steps, Thanks Nick.
I know the PID bit is going to be fun learning though. I've done Arduino stuff for a different hobby so hopefully that side should be ok.
What app and hardware did you use to change the values using bluetooth.
Old Nov 06, 2012, 05:24 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Nice spider quad design strong clever and simple
Upup is offline Find More Posts by Upup
Old Nov 07, 2012, 04:13 PM
Joined Oct 2012
I found the android app for the multiwii, needs a bluetooth adapter, one added to my order
Old Nov 07, 2012, 05:00 PM
rob10000 is offline
Find More Posts by rob10000
rob10000's Avatar
here's my version adapted to fit the SK450 arms from HobbyKing.
Since the ESCs are mounted on the arms instead of the frame, its a bit shorter in length than the original, and the spacer thickness had to be increased to 20mm.
This is a great design - My friends who fly quads are also building similiar models.
Thanks Nick!
rob10000 is offline Find More Posts by rob10000
Old Nov 07, 2012, 05:06 PM
Joined Oct 2012
Thanks Nick!
I thought of using the arms but have decided to stick pretty close to Nicks design, although I do prefer the landing feet Is that a KK FC on the top, do you have your own build thread, be interested in a look at it.
Old Nov 07, 2012, 06:19 PM
Nick_P is online now
Find More Posts by Nick_P
United States, MO, De Soto
Joined May 2003
I appreciate the feedback and really enjoy seeing the different builds. I still fly this same quad with the exception of motor choice. I switched to NTM 28-26 1200kv motors with 8x4.5 props. It give the quad some spunk.
Nick_P is online now Find More Posts by Nick_P
Old Nov 08, 2012, 08:31 AM
rob10000 is offline
rob10000's Avatar
yes, it's the KK FC, it's been very good to me.
I don't have a build thread, it's nothing too complicated.
Components are as follows...
Hobbyking SK450 Arms
NX4006-530KV motors
11x4.7 Gemfan props
SimonK flashed F-20A ESC
2700Mah 3S
cased PZ0420 camera
200mw 5.8 video TX
Old Nov 08, 2012, 09:00 AM
Joined Oct 2012
I'm planning on using the following along with these motors/props
Turnigy 3600mAh 30C Lipo pack
Hobbyking F-30A ESCs
Multiwii Flight Board SE with FTDI prog.
Bluetooth adapter for Multiwii
HK Quadcopter Power Distribution Board
Turnigy 9x with rx
Does all look ok,
Old Nov 08, 2012, 09:02 AM
Joined Oct 2012
NX4006-530KV motors
11x4.7 Gemfan props
2700Mah 3S
cased PZ0420 camera
200mw 5.8 video TX
I've read a fair few threadon KK or Multiwii, TBH if it wasn't for the info in this thread I would have been inclined to go for KK
I'm leaving the camera stuff till I learn to fly.
Old Nov 08, 2012, 10:51 AM
Joined May 2003
Turnigy 9x with rx
Does all look ok,
Looks good.
The KK2 board is a solid board and very easy to setup. Everything is programmed on the board without need for a PC or blue tooth. I have one on another quad and I like it a lot. So which ever you decide, multiwii or KK2 will be just fine.
Old Nov 08, 2012, 11:10 AM
Joined Oct 2012
Looks good.
Cheers Nick, if only even for the sake of gadgets, i'll use the multiwii with BT so I can make adjustments with Android
Old Nov 09, 2012, 06:14 AM
Joined Oct 2012
What range is achievable when using this setup.
What options to increase range, i've seen videos that look like miles away from TX
Discussion Lets build a DIY direct drive gimbal for the poor man hexa Multirotor Talk 155 May 14, 2013 09:01 AM
Cool Model Airplane Building Clinic ~ Building A Kit Murocflyer Parkflyers 484 Mar 14, 2013 03:37 PM
For Sale unused HT FPV quad spider frame dr_patso Aircraft - Electric - Multirotor (FS/W) 7 Jul 13, 2012 02:29 PM
