Aug 20, 2012, 07:39 PM
Joined Apr 2008
Mine just arrived - in good condition. Quick first impressions: looks nice with smooth foam and neatly applied stickers, that main spar is very heavy but probably necessary. I'm not pleased with the friction fit of the wings in the fuse. I know you often see this in these EZ type planes but this one's too large and heavy for that (IMHO). The manual says you can tape the wings or use chewing gum - yeah, right.
Others have been waiting on compartment sizes so here they are:
Front compartment 140x45x43 L,H,W in mm. There are two partial bulkheads in this compartment that could be relieved to provide a few mm more of H and W. This is the battery compartment.
There is another compartment directly under the canopy that measures 100x43x105. Again a floor bulkhead that could be relieved to provide some additional height if necessary.
The supplied spec sheet on the motor shows its only rated for a max of 29A and 3s battery. I'll do some power measurements on it a little later to compare with Blaser's.
