Perhaps your cg may have been a bit off (too far forward???). That behaviour sounds like a deep stall. Did you have a lot of back stick trimmed in? |
Latest blog entry: Travel Quad
![]() By the way i ordered one on friday morning...and a 4000mh 3s battery...
And I think 4 cell might be better but my 5000 -4c would not fit |
That's have to be ~1kg of batteries, plus your 500g ballast. |
Canada, BC, Burnaby
Joined Oct 2010
a quick mods
Ok here are the dyno #'s the stock motor 130 grams stock prop 8x7
stock set on 3c 1120 grams thrust 315 watts 26.1 amp 4c 1630g 583w 38.1a 4c 8x4 speed prop 1605g 453w 28.7 3c with a different type of 9x6 prop than what I was fling with http://www.bevrc.com/bev-gemfan-96-p...1900_p315.html 1480g 470w 39.8a so it looks like the 8x4 4c is the best setup by far |
Joined Apr 2008
Mine's on the big, brown truck for delivery this afternoon.
If the supplied motor is indeed about a 35/36 1250kv; most motors this size are rated for about 350-400 watts max. It could be that pushing it beyond this could impact it's efficiency and life. I'm also concerned that 500g (including the battery) is required to achieve recommended CG. Most 3600 3s weigh around 300-330g. I'd imagine the one supplied with the RTF is in this range, thus requiring nearly 200g dead weight to achieve CG? It appears the chord of the wing is about 12" which would imply a CG of between 3" and 4" back from LE of wing (using the 25%-33% of MAC rule). If the recommended is 100mm, thats in the range of what would be predicted; but toward the rear of that range. Maybe the recommendation is a little nose heavy? Maybe I'll be able to answer my own questions later today. In the meantime if anyone has some additional experience, please post your findings. |
BTW, the big design deficiency of this monster foamy, is the fact that it uses the integrated linear BEC to drive the radio equipment including all 6 of those 17g servos, which is much too much current demand from any integrated linear BEC on 3S lipo power. Typically, most ESC with built-in linear BEC recommends use with no more than 3-4 micro servos on 3S. This huge model uses 6 mini size servos, and with huge control surfaces, it would be prudent to install a separate switch mode BEC, I'll be using a 5A switch mode BEC.
Los Angeles, CA
Joined Mar 2004
Are you upgrading the power system or just the ESC? |
| Thread Tools | |
| Discussion Banana Hobby BlitzRCWorks Sky Surfer | JoshB | Electric Plane Talk | 12 | Feb 14, 2012 11:01 PM |
| Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set | cutty01 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 16, 2010 03:16 PM |
| Discussion BlitzRCWorks Sky Surfer Aerobatic | Flench | Beginner Training Area (Aircraft-Electric) | 4 | Feb 13, 2010 03:17 PM |
| Discussion sky surfer powered parachute $29.95 w/ Free shipping | interplanet | Hot Online Deals | 26 | Dec 30, 2008 10:58 PM |
