Old Oct 14, 2012, 12:08 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Prof100 View Post
With a 3S it may be running on the ragged edge ESC with an internal switchmode BEC. It depends on servo load and current draw plus ESC cooling. Just make sure the ESC is getting plenty of air and it is not buried in the airframe. My Skysurfer with flaps has an external BEC but I am more concerned with Spektrum brownouts than ESC shutdown.
Thank You very much. I have the stock ESC in mine (well, stock everything (electronics). Since it is linear, I can see the handwriting on the wall - Safety first. I will put in a 5A BEC (switching). Again, thanks. You make it very clear what I should do. I sorta, kinda felt like I should put an external BEC to begin with. But, your information seals the deal.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Oct 14, 2012, 12:12 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
AJ
AJ,
You are very welcome, but you knew you had to put one in anyway.
Bill
Prof100 is offline Find More Posts by Prof100
Old Oct 14, 2012, 12:32 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AJ,
Bill
Yes. But, it was just that I needed a little shove from you to do it.
AJ
Old Oct 14, 2012, 11:35 AM
antennahead is online now
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
With all of the talk about keeping the esc where it will get airflow, and some of the reports of the esc getting hot when installed in under the canopy. Will just installing a seperate BEC alone let everything run alot cooler? On my setup, I am running a 4s 4000 a Castle 10 amp Bec on the stock ESC and an 8x6 APC prop. So I hope that this will run cool enough to keep everything under the cockpit without cutting any holes.
antennahead is online now Find More Posts by antennahead
Old Oct 14, 2012, 01:12 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Short answer. Yes.(without the "alot" in the sentence, since that is subjective).
AJ
Old Oct 14, 2012, 01:57 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Finally - The day was PERFECT in all ways
The maiden was wonderful. Enjoy.
I will be posting a couple more videos in a few minutes.
I did have skids on both wing tips.
AJ
SSS#1 Maiden (3 min 49 sec)
Old Oct 14, 2012, 02:15 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
More videos
As the battery got lower, the SOGATO did not work. So, I had to do a hand launch which was the first for this plane. It worked out very well.
SSS#3 Frustration and Hand Launch (2 min 51 sec)
I broke some rule guidelines on this one (WAY over the recommended 3 minutes). But, Check the action at around 7:40.
SSS#2 Inverted and Rolls (11 min 44 sec)
AJ
Old Oct 14, 2012, 02:28 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
http://youtu.be/XD3-8rbe924
http://youtu.be/7-8ufNbdSwA
AJ
AJ,
Very cool. The inverted pass at .001 mistakes high was very cool.
Put a 4S in that puppy. It's a pig on 3S.
Bill
Old Oct 14, 2012, 02:40 PM
rhampton is offline
Find More Posts by rhampton
USA, FL, Clearwater
Joined Dec 2007
I'm impresssed AJbaker.......
Actually Tomorrow is my big day...I should get my Super Sky Surfer Arf in the mail sometimes in the afternoon.
10/15/12....
i didnt wasted anytime. i ordered my 4s and 60a esc at the same time. i'm not even gonna maiden mine with a 3s...i need some launching power cause i have to hand launch it. i hope there's not much building. I wonder how long it takes to put the whole thing together....
rhampton is offline Find More Posts by rhampton
Old Oct 14, 2012, 04:49 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
ill watch videos later ! Right now im out the door for maiden flight ! try to get video
fastfwd is offline Find More Posts by fastfwd
Joined May 2007
Nice AJ!! I really enjoyed watching your videos. I hope my maiden will go as well as yours. I have a replacement servo that I need to install, and then on to final setup, but won't get a chance for maiden on mine until next weeekend. if the weather is good I'll be able to do the maiden on the SSS and a new regular SS v3
Old Oct 14, 2012, 04:58 PM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
How did you feel about your power in your new motor, Aj?
G-LO is offline Find More Posts by G-LO
Old Oct 14, 2012, 05:19 PM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Guernsey, Cātel
Joined Jan 2012
Originally Posted by rhampton View Post
....I also purchased a new 4s 3000mah. hmmm i should have went to 5000mah? oh too late now..i guess 3000mah will have to do....
A 4S 3000mAh packs the same amount of energy as a 3S 4000mAh.
mike_o is online now Find More Posts by mike_o
Old Oct 14, 2012, 05:21 PM
rhampton is offline
USA, FL, Clearwater
Joined Dec 2007
Thanks Mike. Do you think i will need to ad weight to the nose?..i hear most people r using 5000mah lipo..
Old Oct 14, 2012, 06:37 PM
fbitz777 is offline
Find More Posts by fbitz777
United States, PA, Cranberry Twp
Joined Nov 2008
From previous posts the total weight needed in battery compartment is about 500grams.... that matches my HK 3s5000mah plus 40grams or so of ballast I had to put.
I would think in your case you'd be adding close to 100grams of ballast
fbitz777 is offline Find More Posts by fbitz777
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
