Old Oct 13, 2012, 04:43 PM
rhampton is offline
Find More Posts by rhampton
USA, FL, Clearwater
Joined Dec 2007
I ordered this Super Sky Surfer last week and i'm suppose to get it in the mail Monday..Am i to expect to spend most of my time modding this Glider? I hear reports about the Wing Tube and other things...Is this a Glider i can consider RTF out the box? I dont want to be ordering no Wing tube from CA and other parts. i thought the parts on this Glider was sufficient enough. Has anyone Took out the box, assembled it and then Flew it Stock with all the included parts?? I'm starting to get a little worried now.
rhampton is offline Find More Posts by rhampton
Old Oct 13, 2012, 04:46 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Outer diameter of tubes and rods is controlled better than ID or wall thickness during the mfg. process.
Prof100 is online now Find More Posts by Prof100
Old Oct 13, 2012, 05:18 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Some people report their wing spar takes some effort to put in. Mine might be an extreme case.
Tail pushrods are pretty skinny. The instructions tell you to slide a plastic tube (provided) over the last 6" or so. Some people put in thicker pushrods (or clevis rods) instead.
If you can fit your spar rod into the wing tubes, you should be able to fly as-is. Most other mods are "peace of mind" things IMHO.
Check your CG (Center of Gravity, or balance point). The manual calls for it to be 100mm behind the wing leading edge. I had mine at 104mm behind (I wasn't using a standard battery), and the plane was tricky to control. A bigger battery moved it up to 93mm behind the LE, and now it flies great. Bring some weights to put in the nose if needed.
Little-Acorn is offline Find More Posts by Little-Acorn
Old Oct 13, 2012, 05:35 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Prof100 View Post
mfg. process.
This is more of a question. As you know, I have a fair understanding of ESC's and BEC's. But, I am not clear with myself whether I should put a separate BEC (switching, of course) in this plane since I have (like many folks) 6 servos. I am deferring to your knowledge and experience on this one. Pros, Cons -Your thoughts? TIA.
AJ
P.S. STILL waiting to do my maiden.....
ajbaker is offline Find More Posts by ajbaker
Old Oct 13, 2012, 07:08 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
The only real thing that i feel should be done is replace the control rods for elevator and rudder,there just to thin for safety Other than that it will fly fly just fine stock. I put in a bigger amp esc just for safety sake.
fastfwd is offline Find More Posts by fastfwd
Old Oct 13, 2012, 07:10 PM
fastfwd is offline
Joined Mar 2012
AJ
My self i just put in a stronger esc with a built in 4amp bec, and i have yet to maiden it,was going out today but the wind is just horrible !!
Old Oct 13, 2012, 08:50 PM
fbitz777 is offline
Find More Posts by fbitz777
United States, PA, Cranberry Twp
Joined Nov 2008
I flew hours as it came out of the box without a problem...I bought it as ARF
so I put a 3S 5000mah battery for which I get 40-60 minutes of flying includng many take-offs from the grass. Battery , ESC and motor
are just mildly warm everytime I checked.
I would assume that if you bought RTF and the battery supplied is smaller you would need to put 100 grams or so in the nose.
fbitz777 is offline Find More Posts by fbitz777
Old Oct 13, 2012, 09:06 PM
rhampton is offline
USA, FL, Clearwater
Joined Dec 2007
I purchased the ARF version from Banana Hobbies and then i went ahead and got a 60a esc with a 3a bec built. I was only $20 from Hobbypartz..it has a 3a bec built in. i also purchased a new 4s 3000mah. hmmm i should have went to 5000mah? oh too late now..i guess 3000mah will have to do. So that's the only Mod i'm doing is switching to a 60a and 4s. i believe i need to change my prop? Someone suggested take the stock prop off if i'm moving to 4s and get a 8x8 APC...So i hope with this setup i can hand launch and get decent take off lift.....
i'll post photos Monday night once i get it. BTW if i use a 3000mah,,,do i really need to add weight to the nose?
Old Oct 13, 2012, 09:17 PM
fbitz777 is offline
Joined Nov 2008
4s 3000mah is probably close to my 3s 5000mah (403grams)..still I added 40 grams to the nose to balance.
Old Oct 13, 2012, 10:50 PM
Prof100's Avatar
Joined Jul 2007
AJ
With a 4S and six servos with large control surfaces it's the safest thing to do. That is, install a separate BEC.
Old Oct 13, 2012, 11:35 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
BEC question for Prof100
I can see by your answer that I did not provide enough details. I am going to use a 4000mah -30C LiPo. Should I still put in a separate BEC? TIA.
AJ
Old Oct 13, 2012, 11:44 PM
Prof100's Avatar
Joined Jul 2007
AJ
3S or 4S? MAH doesn't make any difference. It's the voltage of the pack that worries me.
Old Oct 13, 2012, 11:48 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Gee whiz. I will get this right yet. Sorry. - 3S. TIA
AJ
Old Oct 13, 2012, 11:59 PM
Prof100's Avatar
Joined Jul 2007
AJ
With a 3S it may be running on the ragged edge of an ESC with a internal switchmode BEC. It depends on servo load and current draw plus ESC cooling. Just make sure the ESC is getting plenty of air and it is not buried in the airframe. My Skysurfer with flaps has an external BEC but I am more concerned with Spektrum brownouts than ESC shutdown.
Old Oct 14, 2012, 12:07 AM
San Diego, CA
Joined Dec 2006
I did my first five flights with 3s and the stock prop. It kept vibrating although it appeared to be balanced. Finally took a close look and found that the two blades were not 180 degrees apart! More like 178 or so. Both props that came with the plane were like that. At least one other poster has said he found that, too. I had an APC 9x4.5E sitting around, so tried that and the plane flew well enough, and without vibration. See http://www.rcgroups.com/forums/showt...t#post22893382
Then went to 4s (two 2s 4000mAh batteries from an R/C car, in series) with the stock motor and a 60A ESC with 4A switching BEC. And I'm using a three-blade EMP 8x6 prop. The plane climbs noticeably better. ESC gets a little warm, it might be too much propeller for the stock motor.
If I were you I might try an APC 2-blade 8x6E prop on the stock motor with 4s. Then move to others and see if things start getting hot.
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
