Old Oct 01, 2012, 08:14 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Originally Posted by Livesimply View Post
How did ya get your stickers off? Mine seem to be stubborn.
They were never put on. I got this ARF version direct from Banana Hobby, even drove there to pick it up. The decals were on a separate sheet in the box. Don't know why, but actually I think I like it better this way.
Little-Acorn is offline Find More Posts by Little-Acorn
Old Oct 01, 2012, 08:20 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by fastfwd View Post
Got the lighter spar coming, got a bigger esc,got a huge field Now i have a new motor here for my Sbach,it is good up to 1000 watts and 70 amps, it is a 3720 650KV would it work on this SSS be enough power or to much ??
That motor would be great with a 4 or 5 s lipo as you wont be able to use much more then a 9 in prop.
Myself I look at thrust numbers and that motor is 1/2 the kv of the stock motor plus i'm sure it weighs much more.
If I had the SSS I would go with a 4s bat and ubec and prop it to around 500 watts to start out with.
The airfram is very draggy so you need thrust.
eckace1 is offline Find More Posts by eckace1
Old Oct 01, 2012, 08:42 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Here are the specs on that motor, it is quite heavy,but man does it scream that Sbach 342 48" around ! It is just one i have, i may just get the one that has been suggested here in the forum
3720
KV (RPM/V)
650
Operating Power
1000W
Operating Voltage
3S ~ 6S (6V-23V)
Operating Current
50A - 70A
Weight
150g
Recommended ESC
50A - 70A
Recommended propeller
12x6, 14x7, 15x5, 16x6, 18x4, 18x6
Size:
37mm (dia) x 39mm
Shaft Size:
Propeller adaptor (6mm dia)
fastfwd is offline Find More Posts by fastfwd
Old Oct 01, 2012, 09:01 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
3720
KV (RPM/V)
650
Operating Power
1000W
Operating Voltage
3S ~ 6S (6V-23V)
Operating Current
50A - 70A
Weight
150g
Recommended ESC
50A - 70A
Size:
37mm (dia) x 39mm
Shaft Size:
That would be great if the sss could run that big of prop but you are limited to mybe a 10in prop.
Old Oct 01, 2012, 09:59 PM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
What if he use a 3 blade 9x8 or 10x 5? Oh, or I forgot, a 3blade 8x6 even...?
G-LO is offline Find More Posts by G-LO
Old Oct 01, 2012, 10:16 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
It is still a 650kv motor stock is 1250 even with a 3 blade prop you would still need a 4-6s lipo.
Like i said I would use stock motor and figure it for 500w and go from there.
The real question is what do you want out of the SSS?
Old Oct 01, 2012, 10:19 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Done with this thread.
The Don is offline Find More Posts by The Don
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Oops! I see its a 3720 size & 650 kv...
Old Oct 01, 2012, 10:26 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Thanks Don.
I think they are trying to hard to make it somthing its not designed to do be a f18.
100 watts per lb would be double the stock stup.
Please either change the esc or use a ubec but even if you stick with the stock setup I would recommend using a ubec either way $20 investment is well worth it
Old Oct 01, 2012, 10:27 PM
antennahead is online now
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
Originally Posted by The Don View Post
Yep. Stock motor and a master airscrew 8 x 6 on 4S works quite well and is just under 500 watts.
What would you think of the APC 8x6E on the stock setup?
antennahead is online now Find More Posts by antennahead
Old Oct 01, 2012, 10:37 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Old Oct 01, 2012, 10:39 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Originally Posted by Little-Acorn View Post
I just spent an hour leafing thru the thread looking for a few bits of info. It would be nice if most such stuff were all in one place.
It would be nice if the thread owner (Doubletap) could post a link to these posts, in his original post that started the thread.
Sound like a plan?
So you want to populate your empty threads with all of the good stuff and have Doubletap link to them, making you the SSS Guru? Sounds like a great plan.
kaptondave is offline Find More Posts by kaptondave
Old Oct 01, 2012, 11:11 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Old Oct 01, 2012, 11:42 PM
San Diego, CA
Joined Dec 2006
Thanks Don.
Who's "they"?
See posts 740 and 741.
Old Oct 01, 2012, 11:57 PM
fastfwd is offline
Joined Mar 2012
I want it for just what its made for,floating around smooth as glass I have no plans on using the motor was just curious about the 1000 watt if it was more or less powerful than stock. The SSS fly's just fine as is,all i have done is bigger esc and new control rods ..
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
