Old Sep 05, 2012, 06:51 PM
Vern1960 is offline
Find More Posts by Vern1960
Vern1960's Avatar
United States, VA, Richmond
Joined Apr 2012
Originally Posted by eckace1 View Post
Some on similar types of planes have moved the esc to the outside for better airflow.
Can you discribe how hot it was or do you have ir measurments?
No IR measurments as my Nitro buddy who has one, was not flying this past weekend.. You could touch it with your fingers, my estimation it was around 110 degrees F. Hate to cut holes in the nose but I am sure it would help.. It looks like there is a good amount of open space in the fuse so you should get some airflow..
Vern1960 is offline Find More Posts by Vern1960
Old Sep 05, 2012, 07:45 PM
dbc is offline
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
It would really help to cut a hole in the lower fuse toward the rear, too; in addition to the front one(s). This would provide a flow through the fuse.
My esc gets a good bit hotter than you described and you can really feel the heat in the compartment when you open it after a flight.
This should have been designed better - most electric foamies provide for some airflow.
dbc is offline Find More Posts by dbc
Old Sep 05, 2012, 07:58 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
Originally Posted by Calla969 View Post
Can anyone comment about how this plane behaves as a glider? Will it thermal?
i flew mine a good while with motor off the other day- we had just a gentle breeze blowing and when i headed into the wind it would actually gain altitude- so I am thinking it will thermal well- perhaps not like a radian- but then again it did float very well and has lots of wing area-
my question is- will it penetrate a decent 10-15mph headwind- we have lots of windy days here...
scottdearinger is offline Find More Posts by scottdearinger
Old Sep 05, 2012, 08:26 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
I think it would fly great in a lame 10-15 mph wind not sure about a decent one however
I think trading out the solid spar for a hollow spar would help as you lose 8 oz of dead weight thats like over 10% of total weight.
eckace1 is offline Find More Posts by eckace1
Old Sep 05, 2012, 08:30 PM
porcia83 is offline
Find More Posts by porcia83
United States, CT, Hartford
Joined Jun 2009
That's a good amount of weight to drop for sure, my concern would be that a hollow tube would not hold up as well. Those wings are big and thick and heavy! Would hollow aluminum be better and give the same structural integrity?
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Sep 05, 2012, 09:25 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
My thinking is the wings have a cf tube in them and you insert another tube inside of those be it solid more weight hollow way less weight the smaller ones IE bixler , Easy star don't have a cf tube in the wings just the main spar.
We are not talking Redbull stresses here but sailplane stresses.
If and really when I purchase one that will be the first mod I do.
Oh and that plane has 2 wing spars not just one.
Old Sep 05, 2012, 09:41 PM
porcia83 is offline
Joined Jun 2009
I have both the B2 and the SSS, just haven't thrown them together yet. The second spar on the SSS is pretty small.
Old Sep 05, 2012, 09:59 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
My perspective comes from building rite wings and a couple of EZ1,s and a couple of Radians plus looking at my friends sss and helping him build it.
Like my Dad would say God rest his soul I'll bet you dollars to donuts a hollow tube would be more than enough.
I know it seems small but it is another spar system that fits into spars that are in the wings.
The EZ ,bixler cloud fly you name it has zero spars in the wing halfs the sss has 4.
Old Sep 05, 2012, 11:14 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
After my buddy bought one of these and i seen how well built it was and the width of the wings, i couldn't stand it !! I ordered one tonight,never bought anything from Banana before so hope i have a descent experience. I see there are ZERO extra parts available and after telling buddy about that, he ordered another one just in case I got the ARF as i have TX and RX for it. Think it will fly well enough with a 2200 3s battery or do i need to get a 3s 3600 on the way ?
fastfwd is offline Find More Posts by fastfwd
Old Sep 05, 2012, 11:22 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Originally Posted by fastfwd View Post
After my buddy bought one of these and seen how well built it was and the width of the wings, i couldn't stand it !! I ordered one tonight,never bought anything from Banana before so hope i have a descent experience. I see there are ZERO extra parts available and after telling buddy about that he ordered another one just in case I got the ARF as i have TX and RX for it. Think it will fly well enough with a 2200 3s battery or do i need to get a 3600 on the way ?
The issue over the pack capacity has to do with having enough pack weight in the nose to balance the model without having to resort to adding dead weight. this is why the RTF version includes a 3600 which is the lightest pack that will still enable balancing within the flyable CG range. Most here actually are using 4000-5000mah packs, so a single 2200 mah pack would be too light to balance the plane, you can run 2 2200 mah packs in parallel for an effective capacity of 4.4A which would give you enough nose weight and also enhance your flight times.
Doubletap is offline Find More Posts by Doubletap
Old Sep 06, 2012, 06:00 AM
blackbrabus is online now
Find More Posts by blackbrabus
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
With running such huge packs what sort if flight time are you expecting, an average flight with stop start motor and good glide rates??
blackbrabus is online now Find More Posts by blackbrabus
Old Sep 06, 2012, 07:10 AM
Dogdude is online now
Find More Posts by Dogdude
Joined Aug 2012
Yes, it will thermal and it will slope soar even with a HoryzonHD cam on the nose a keychain cam on the wing and a 5000mah 3S battery in the nose
Yesterday evening I got more than half an hour flight having only used 2 minutes of power (and that was just for loops/fun) in an 8mph wind avg, could have stayed up there forever but got cold hands and needed the toilet
Dogdude is online now Find More Posts by Dogdude
Old Sep 06, 2012, 08:07 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Will the SSS ROG on grass or does it need to be hand launched?
Rickochet is offline Find More Posts by Rickochet
Old Sep 06, 2012, 08:08 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Can someone who has one of these measure the solid spar with a caliper?
Old Sep 06, 2012, 08:17 AM
Hersh is offline
Find More Posts by Hersh
Plain City, OH
Joined May 2004
I've been tracking the comments on batteries and balance points. Cameras are not dead weight. With a GoPro on the nose I'm hopeful I'll be able to balance it out with a 2200. If that don't work I'll add another GoPro or my FlyCamHD.
Hersh is offline Find More Posts by Hersh
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
