Old Sep 02, 2012, 06:00 PM
Hersh is offline
Find More Posts by Hersh
Plain City, OH
Joined May 2004
What size is the motor on this thing? Seems the biggest number of issues so far is with the stock power system (motor and ESC) . I fully expected to have to mod the power system all along so I'm interested in the diameter of the motor so I can search for a replacement. While I'm at it I'll pick up a BEC of maybe a controler with a BEC that can handle the load.
Hersh is offline Find More Posts by Hersh
Old Sep 02, 2012, 09:03 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by Rickochet View Post
Scott, I just saw the tail end of a news segment on Headline News about the crash and saw your name. I am waiting for it to come back on. I assume you were being interviewed.
It is 9:30EST and it looks like that segment is coming back on after a commercial.
They just showed it again. No interview with Scott but they did show his name for supplying the video.
Sad that they never name the photographer
eckace1 is offline Find More Posts by eckace1
Old Sep 02, 2012, 09:25 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
no they didn't interview us- just uesd our video of the L-39 going down and exploding -was sad to witness the death of a fine pilot- and I would much rather he lived than have the money given us by CNN and CBS for rights to the video...Bob had the best shots of the crash on his Sony Bloggie- the same one he flies on his plane....we also shared with the FAA
scottdearinger is offline Find More Posts by scottdearinger
Old Sep 02, 2012, 09:33 PM
Joined Apr 2011
Originally Posted by stealth01 View Post
:My flying buddy just got his,great solid plane,but the motor mount was installed so crooked it is pointing way left if looking at plane from back. So he will see what can be done with banana hobby come Tuesday. So sad as it looks to be a great plane ! "
Yea mine too. I was pissed off so I did what I thought was best....fixed it myself. Don't even try to return to B. hobby unless you got a month or two to waste. Cut the engine nacell horozontally then take the motor/mount off, cut off excess material under mount until straight then reglue with hot glue gun. Works great now. Still has up draft for clear air but not the egregious angle to starboard that is not necessary for this aircraft.
It is supposed to be off set like that- mine flies fine as it is and I also questioned the angle- then I checked with others who received the plane befor me and flew it- flies fine that way....
Old Sep 02, 2012, 09:38 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
I belive its 36mm but don't quote me on that.
Scott flew his all stock and it flew great but ya you could up the prop as it is a 40 amp esc and static thrust measurement puts it in the 25 amp range with the stock prop.
Old Sep 03, 2012, 12:31 AM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Has anyone purchased a Super Skysurfer in the past 2 weeks and received it, or at least shipping confirmation with tracking info?
I ordered an ARF 2 weeks ago, said in stock as it still does. Not shipped as of yet. No replies from BH, and Sebatian on their support forum here on RCG basically said "Its in Progress".......No Crap..Hmmm, I seem to have read that in my account on BH!!
This will be my last order with BH. I said that the last time too, but this time Im seriously done with BH. I dont mind so much that its taking so long to ship, but rather that they are a bunch of lying goons. If they would just tell the truth, and not play you for an idiot it wouldnt be so bad!!!!
KKUSA is offline Find More Posts by KKUSA
Old Sep 03, 2012, 12:39 AM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Originally Posted by scottdearinger View Post
How much better was the climb out and thrust with your 3 blade prop- and it is still stock motor? tis my only complaint so far is lack of thrust as i want to go high to take advantage of its large size and thus its increased visibility...
I'm going to switch back to the 2 blade prop as the 3 blade seems to drain the battery very fast, had 15 minutes on power from a 5000mah battery, not very good with the 3 blade, on a watt meter it draws 33amps at full throttle
The 2 blade thrust was adequate, not exciting but then if you buy this plane for thrills you bought the wrong plane
I may try a 9x6 or even a 9x6 folding prop just to experiment but I'm quite happy with the standard power for floating around
Here's some videos
Super Sky Surfer Bananahobby 2.4m Aerobatic Horyzon HD On Board (3 min 31 sec)
2.4m Super Sky Surfer floating around (2 min 58 sec)
Super Skysurfer Aerobatics Bananahobby 2.4m (1 min 25 sec)
Dogdude is offline Find More Posts by Dogdude
Old Sep 03, 2012, 01:34 AM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
are you pulling my leg ?? why in the world would want a motor kicked off on a side angle ? seems to me it would want to make plane go to the left.
fastfwd is offline Find More Posts by fastfwd
Old Sep 03, 2012, 01:38 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Err, do some research into thrust angles
sammyc is offline Find More Posts by sammyc
Old Sep 03, 2012, 02:54 AM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
The thing is you are exactly right
On an anti-clockwise spinning motor / prop, the forces will want to pull the airframe to the left. To counter this the motor and prop are mounted to channel the thrust to the right.
And on some aircraft it's at quite a notable angle which looks extreme and in some cases a little awkward like it was a mistake or just thrown on without thinking.
This also extends to upward or downward thrust angles.
This is why on some aircraft the angle of the prop and motor are angled down to counter the dramatic lift produced by the faster moving air.. You can see this effect by chopping the throttle and watching the aircraft baloon as there is no more downthrust to counter the upward lift.
If you look on the SSS the motor and prop are pointing up to counter the lift produced under power, this is due to the position of the power unit at the rear and top of the airframe.
I guess if you don't know then there's no problem with that, no body knows everything.
Take a look at some set ups on a few popular ARTF's to show the angle at which the motor and propeller are mounted.
The most notable one for me is the Parkzone ME109. Check the attachment for a picture with the cowl off.
Also have a look at the angle of the motors and props on pattern ships.
These angles are necessary due to the aerodynamic forces produced by the spinning propellers. Not just on model aircraft but also on fullsize aircraft of all descriptions.
The thrust line, which can be determined during design allows the aircraft to be flown without too much pilot input to ensure the airframe flies where you point it with the use of the control surfaces.
More importantly thrust angles allow the airframe to fly relatively straight and level under variable power inputs without too much input of control surfaces to counteract the forces of the spinning motor and propeller.
Hope this helps
soundcheque is offline Find More Posts by soundcheque
Old Sep 03, 2012, 03:40 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
But they did. Every time I saw the video it posted Scott's name.
Rickochet is offline Find More Posts by Rickochet
Old Sep 03, 2012, 06:46 AM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
I ordered mine on 8/26 and it's due to be delivered tomorrow according to UPS.
seojeff is offline Find More Posts by seojeff
Old Sep 03, 2012, 09:16 AM
Dogdude is offline
Joined Aug 2012
I was going to tell you guys the same
They do indeed deliberately offset the motor to get the thrust angle correct and to counter torque roll
Old Sep 03, 2012, 11:12 AM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Closed Account
Joined Mar 2012
Seems like most of you guys only know how to buy and fly, but know nothing about engine torque and how to eliminate it. If you don't offset the motor to a certain amount of degrees, it'll cause the plane to roll to the opposite direction of motor rotation and you'll be spending more time fighting to keep your plane flying level, than you would enjoying your day out flying.
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Sep 03, 2012, 11:15 AM
Closed Account
Joined Mar 2012
Here's some videos
http://www.youtube.com/watch?v=I0VNQH3ikZk
http://www.youtube.com/watch?v=uWtek2BXdyI
http://www.youtube.com/watch?v=7OHmh5kyGRo
From the looks of those cloud shadows moving across the ground, in your first video, you must have been out flying in 10- 15 mph winds. Very nice view.
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
