Old Aug 30, 2012, 09:11 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Nice flight report! Can't wait to maiden mine now with full trailing edge camber and crow landing setup.
Doubletap is offline Find More Posts by Doubletap
Old Aug 30, 2012, 10:48 AM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by scottdearinger View Post
ok video of maiden in edit room- will post tonight
totally stock- was getting late and growing dark so i dismissed the flap programming and taped them in place
rolled off the ground in 45-50 feet- loved it
this thing looks like a slow flyer- but when you consider the size- it is actually moving quite fast- but it does niot climb like a radian or Easystar.. will prop up and try again tonight- wonder if it can handle a stiff breeze(can it push itself upwind?) was calm last night
i did not have to add any weight anywhere to balance - i used a 4000mh 3s batt andd pushed it as far forward as i could- actyaully had to remove a little foam to get it to fit..i PUT A GORO on the wing near the root- and an HK cam way out on the nose- and it balanced at 4 and 1/4 inches- 110mm is 4.33 inches- so i am close
it floated with little loss of altitude with power off- this thing wants to float- doesn't like being on the ground at all-
Ailerons worked great and turning was easy -even when barely moving- didn't notice any stall tendencies.. does lose some altitude in a tighter turn-as expected
landing were a breeze- but this in not your sport plane- this is a camera platform and glider
all in all i like it...
A couple of more observations as Scott made me go with him really I was the transport. If yo have the sss assembled and have a shortbed truck you will need to leave the tailgate down LOL .
Second about the wing saddle both Scott and myself each took a wing and removed it from the saddle and it took alot of force for us to get it apart.
Scott said it took him 20 min to get the wings on.
As for as a slow mover yes it looks slow in the air but so does a 747 compared to a cessna,and after looking at the video it did cover the ground faster than we thought.
Tonite Scott is going to try a 9x6 prop and I might bring my radian and see how that goes.
Plus I need to bring my wattmeter along to get some numbers.
eckace1 is offline Find More Posts by eckace1
Old Aug 30, 2012, 10:51 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
It is sounding better all the time! Pretty much what I had hoped it would be. I already have three planes to build now. Guess I will just have to add one more to the count!
Gord
Gordks is offline Find More Posts by Gordks
Old Aug 30, 2012, 02:32 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
I switched te stock prop to an APC 9x4.7 and like it much better. Doesnt make the plane faster but climbs with more authority and gives an overall better response to motor input. Current draw is the same as the stock prop and vibrations are gone.
compuatic is offline Find More Posts by compuatic
Old Aug 30, 2012, 03:10 PM
dbc is online now
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
Per the APC website: maximum prop rpm for the slowflyer is 65,000 divided by the prop diameter. In this case: maximum safe rpm = 7222.
http://www.apcprop.com/v/html/rpm_limits.html
This high kv motor is designed to spin fast. I measured 12360 rpm with the stock prop. The APC might reduce it a little but it will still be way over 7222.
Wear eye protection if you're going to exceed the design limits like this. That's dangerous.
dbc is online now Find More Posts by dbc
Old Aug 30, 2012, 09:48 PM
stealth01 is offline
Find More Posts by stealth01
Joined Aug 2012
damn and i thought I was getting good at this thing...
Well got mine on the 28th and I thought I'd list a coupla things I learned the hard way. First make sure you get the carbon wing rod in equally or you'll end up putting a couple of ounces of lead on one wingtip for lateral equalization...measure the dang thing first then put it in one wing then the other, glue it you aint gonna be taking it out know how.
Then...I thought those pesky varmints at the factory put the engine in caddy wampass and after an hour or two I fixed it...just to find out it was supposed to be that way...heck if you got enough thrust a barndoor will fly right? I just kept lookin at my "old" surfer and it just made sense to me that the engine should point directly back for the most effecient use of thrust, whattaya think?
The hurricane has kept me out of the air [panhandle of Florida] for the next few days so I hope I didn't screw up my new plane.
CG does seem to be about 105-110 back from the leading edge with a 3S 5000mah battery and a GoPro mounted where the pilot's head used to be. From what I've heard here it should be an awesome FPV platform...thanks for all the info even if I was alittle late reading it i'll send you some vid in a few days.
stealth01 is offline Find More Posts by stealth01
Old Aug 30, 2012, 10:50 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
here is maiden flight video- shot at sunset but viewable with 3 cameras- 2 on the plane...
opc orn:
Huge Super Sky Surfer maiden flight (5 min 42 sec)
scottdearinger is offline Find More Posts by scottdearinger
Old Aug 30, 2012, 11:04 PM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Maximilionalpha's Avatar
United States, NJ, Rahway
Joined Mar 2012
Banana Hobby has outdone themselves with that one! Nice plane Scott and thanks for uploading the video for us to enjoy!
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Aug 31, 2012, 12:49 AM
Joined Apr 2011
it will be a fav in my hanger I believe- and the price is nice- will start tweaking power system for more thrust/climb
Old Aug 31, 2012, 04:18 AM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
Very good video.
Definately want one of these in the UK,
The delivery charge to UK is $86 then of course the import tax which could be anything they decide at the time.
I'm visiting relatives in Nebraska in November then journeying down to Florida then back home before Christmas.
Does anyone think I'll get through customs UK side without paying massive import duty ?
I've never bought anything this big and tried to get it through
soundcheque is offline Find More Posts by soundcheque
Old Aug 31, 2012, 07:58 AM
Joined Apr 2011
Originally Posted by soundcheque View Post
Very good video.
What a dilemma- and I am sorry I have no idea- just wanted to chime in -that I feel your pain- My Stepmother is from England and she complained how much it cost her when she was over there- just to buy her sister a new TV...
Old Aug 31, 2012, 08:08 AM
Joined Apr 2011
heading for a great air show tomorrow-we have VIP tickets on the flight line... since there is no "Thunderbirds" thread- subscribe to my my youtube channel for those videos and much more flight stuff- ...we always try to entertain...
http://www.youtube.com/user/sdearinger?feature=mhee
Old Aug 31, 2012, 06:50 PM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Latest video, with #16 Keychain V2 (wide angle with 120 deg D lens) camera
Unfortunately my HoryzonHD cam cut power so no file from that
As well as the cameras I made the following mods since the last flight...
60a Hobbywing ESC, 8x6 3 bladed prop, wheel removed (I have no flat areas to land on)
Bananahobby 2.4m Super Skysurfer #16 keychain cam V2 (3 min 41 sec)
Next job is to fit the RVOSD properly as well as the VTX
Dogdude is offline Find More Posts by Dogdude
Old Aug 31, 2012, 06:57 PM
Joined Mar 2012
That thing really does move out!
Old Aug 31, 2012, 07:46 PM
Joined Apr 2011
http://www.youtube.com/watch?v=O7Pqfrrlpb0
How much better was the climb out and thrust with your 3 blade prop- and it is still stock motor? tis my only complaint so far is lack of thrust as i want to go high to take advantage of its large size and thus its increased visibility...
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 15, 2012 12:01 AM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 04:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 04:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 11:58 PM
