Joined Dec 2007
for the elevator i basically did the same thing but used a small piece of balsa to bridge the gap between the fiberglass tube and side of fuse.... no play flex in elevator. R/ |
We just dont want to see more planes fail because of simple failures ![]() Chris |
![]() AJ P.S. I hope he knows to toss the stock push rod. |
servo end
Joined Jan 2010
They gave you a free replacement for the one burned because it was over-proped. Maybe they will do the same for one burned because of blocked airflow. |
I talked with CC yesterday and they agree that it should not have happened as I was totally in spec with everything. They are sending me 2 (right two! 36a) because of the problems that I had. They requested that I send them both ESC's for analysis - which I did today (they even sent me a prepaid label ) . They promised to email or call me with their findings.. I can't say enough good things about their customer service even though I have had 2 terrible experiences with their product. I will let everyone know what they reply. It should be interesting.After all, this round, I did nothing wrong whatsoever. The config was tested with a watt meter before the flight (36.3Ap). Oddly, I used a 40A with an SBEC today and I flew it for over 2 minutes at WOT with NO air flow (I blocked everything off-This was done several time via bench testing BEFORE risking a flight). I measured the temp of the ESC and SBEC upon landing. ESC temp - 81 Degrees SBEC temp - 74 degrees. And all of the above matters not a whit because the temp controls should ALWAYS kick out the motor no matter what ANYONE does - be it right, wrong, accidental, on purpose, etc. ![]() AJ |
Aspen, CO
Joined Oct 2010
Your personal experience with CC esc's although being installed in a SSS don't really pertain directly to the SSS. In fact, from my perspective it really detracts from the thread, not add value to it. I kindly suggest that you start another thread regarding the CC ESC issues and then perhaps post a link here so that anyone may follow along if they choose. Instead of having to sift through unrelated material here while looking for posts about " BlitzRCWorks Super Sky Surfer: 95" span, w/Flaps" Thanks, BG |
San Diego, CA
Joined Dec 2006
I added a little weight to the nose, to bring the CG forward, to about 93mm behind the wing leading edge. Then it flew fine, with no nose-bobbing or stalling. But with every launch, it would dip sharply toward the ground, and required a quick up-elevator to yank it up before it met the grass. |
mine can't even be hand launched, not enough power! boo
Latest blog entry: DJI F550 build w/naza
| Thread Tools | |
| Discussion Banana Hobby BlitzRCWorks Sky Surfer | JoshB | Electric Plane Talk | 12 | Feb 14, 2012 11:01 PM |
| Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set | cutty01 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 16, 2010 03:16 PM |
| Discussion BlitzRCWorks Sky Surfer Aerobatic | Flench | Beginner Training Area (Aircraft-Electric) | 4 | Feb 13, 2010 03:17 PM |
| Discussion sky surfer powered parachute $29.95 w/ Free shipping | interplanet | Hot Online Deals | 26 | Dec 30, 2008 10:58 PM |
