Old Feb 11, 2013, 06:39 PM
robschonk is offline
Find More Posts by robschonk
robschonk's Avatar
United States, NC, Avon
Joined Sep 2012
Originally Posted by Little-Acorn View Post
You shouldn't have had trouble with yours, either, n'est-ce pas?
I think we've both learned that "what should be" doesn't carry much water, right?
http://www.hobbypartz.com/07e-flyfun-100a.html
3A BEC, nobody's perfect. At least it's a switcher.
Headzuprc has a 100 amp with a 6 amp sbec:
http://www.headsuprc.com/servlet/the...00A-ESC/Detail
robschonk is offline Find More Posts by robschonk
Old Feb 11, 2013, 08:09 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
The specs on both look good. It looks like the only real difference is the BEC spec. Oddly, the 100A opto is $4 more than the one you have.???!!
I always use a ferret ring on all my ESC's, too.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Feb 11, 2013, 09:29 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
AJ
LMAO any who .. the 50 amp esc i got from HK has a 4amp built in sbec that is the reason i got it
fastfwd is offline Find More Posts by fastfwd
Old Feb 11, 2013, 10:25 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Hey, that one looks VERY nice, robschonk! Lots of handy features, and I especially like the 6A BEC! It frankly looks better than the one I'm using... though I haven't had any problems with mine yet, to be sure.
That's what I get for not looking around more. :-\
Little-Acorn is offline Find More Posts by Little-Acorn
Old Feb 11, 2013, 11:14 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
or you could just setup a separate BEC, i have an 85A ESC (never goes over 45A) and a separate 8A SBEC for the servos, i got redundancy on my redundancy!
CrashAffinity is offline Find More Posts by CrashAffinity
Old Feb 12, 2013, 02:20 AM
RocketJoe is offline
Find More Posts by RocketJoe
RocketJoe's Avatar
Joined Apr 2007
I am now building my SSS..got it as a ARF..
it was easy to separate the 2 half's by using a xacto knife to start at the motor pod and using a pair of small pliers as a wedge then cutting the cheap glue strands..with slow work ..it came apart perfectly..
now I want to fill the inside with my FPV gear but want to test fly too....
don't want to glue it back together..so I thought Id show you guyz a trick
I've been using to fix damaged foam stuff with..
can I upload several pics to show the process?
tkx
RocketJoe is offline Find More Posts by RocketJoe
Old Feb 12, 2013, 02:23 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Post away
tkx
I would like to see your process. Post pics or a video would be even better. TIA.
AJ
Old Feb 12, 2013, 03:47 PM
1crazyflyer is offline
Find More Posts by 1crazyflyer
crazyflyer
Joined Jan 2013
Now you people that get the SSS are now warned. Before you fly this plane check the fourms and do the fixes the rod for the elevator is too weak it will bend and U will crash. You need to replace the cheap rod before you try to fly this thing. check the blogs for the SSS to see what else has to be done to make this flyable.
1crazyflyer is offline Find More Posts by 1crazyflyer
Old Feb 12, 2013, 03:52 PM
crazyflyer
Joined Jan 2013
Originally Posted by williamjames View Post
Thanks guys
Can we call you Mr Lucky?
Old Feb 12, 2013, 04:18 PM
RocketJoe's Avatar
Joined Apr 2007
how to fix foam screws
Heres my trick to fixing those torn wing assemblies and how to add screw in bolts for anchors..
descriptions are shown when you point on pics..
Description: these are the anchors..they make different sizes...these work best for most..also there are different ones but they don't screw in..the screw in ones hold best.
Description: cut the tips off to expose the hole..that way they don't y open..its for in a wall..it will ruin the foam.
Description: use a pointed object to punch a hole through..be careful and make sure it s at 90 degrees to the foam..I use a Phillips screw driver.screw
Description: the anchors will screw in with a screw driver ..becarefuf not to go through..if there is only a little foam to work with..how thick...you can cut the anchor down smaller.
Description: here it is seated in the hole side of the SSS. when your happy with the fit back out and glue  the anchor and screw it back in..wait till the glue dries.
Description: dont use the screws that come with the anchor kit there to big..for these I used a 6-32 machain screw .. you can use a small pan screw ..just ck the fit before you tighten..it may breakout the foam  before it  is secure..test fit different ones..
Description:
Description:
Description: these what it looks like..you can counter sink the head and also where the washer fits against the foam ..coat with epoxy to give it a harder surface to set to so as to  not damage the foam when tight..
this way you can take it apart to redo any thing..
hope it helps ya
Old Feb 12, 2013, 04:20 PM
crazyflyer
Joined Jan 2013
My favorite way to keep an ESC cool. Even if the manufacturer screws up his safety systems, still have an extra margin of safety.
And the single-wire-with-plug trick is a handy on-off switch.
Eventually I want to move it back under the wing, directly below the motor pod (still attached to the outside of the fuselage) where it belongs. With the present 5s 4000mAh battery, that makes it tailheavy. When I put the newly-arrived 5s 5600mAh battery in the nose, hopefully that will make everything balance out.
P.S. Ever seen a LiPo with ** 8ga ** wires? This 5600mAh had them.
Why don't you put it on a 3 foot string and pull it behind the plane.
Old Feb 12, 2013, 07:39 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
What prop do you have on there? I'm wanting to try a 3 bladed prop on 4s on the stock motor. What prop do i need?
In other news I seem a sky surfer destroy itself today ;( it was sad!
flohio117 is offline Find More Posts by flohio117
Old Feb 12, 2013, 08:22 PM
Beerwiser is offline
Find More Posts by Beerwiser
Beerwiser's Avatar
Canada, AB, Mundare
Joined Mar 2011
Thats pretty slick RocketJoe
Beerwiser is offline Find More Posts by Beerwiser
Old Feb 12, 2013, 09:30 PM
Canada, AB, Calgary
Joined Nov 2012
hope it helps ya
That's pretty sweet, thanks Joe!
Old Feb 12, 2013, 10:46 PM
guaglione87 is offline
Find More Posts by guaglione87
Team Armattan
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
I would also like to know what prop is safe to use with the stock motor and 4s battery. I have the align 70a esc (switching) and a 5a external sbec, stays nice and cool.
What happend to the sky surfer to make it self destruct?
guaglione87 is offline Find More Posts by guaglione87
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
