Old Jan 26, 2013, 01:39 PM
robschonk is offline
Find More Posts by robschonk
robschonk's Avatar
United States, NC, Avon
Joined Sep 2012
Originally Posted by chanyote66 View Post
I never thought of adding more caps... just looked at my ESC and it has a cap for the lipo side and the 5v side... wonder why BEC's dont (well one for stabilizing, not filtering)?
Heres my little cap array for my RX (Joking... I was bored)
Its only a measly 3400uf at 200v max
Attachment 5477829
Chris
Got me thinking....
I've got a Davis weather station with a small solar panel that charges a super cap for normal operation, with a 123 for cloudy days.
Here's a link on eBay to a one farad super cap.
Whatcha think?
http://www.ebay.com/itm/1Pcs-1F-Elec...item53efb4c0e3
robschonk is offline Find More Posts by robschonk
Old Jan 26, 2013, 11:40 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Wing holding method
Originally Posted by guaglione87 View Post
The velcro on my wings does not seem to be doing the job to hold the wings in. Any other solutions out there that are not too invasive?
I dont like the idea of drilling holes through the top of the fuselage and into the wings, because that section is weak already, so I open to new ideas.
You might consider this method:
http://www.rcgroups.com/forums/showp...&postcount=306
Any movement causes the wings to be continually held together. Additionally, it is much lighter than magnets.
That is my design from years ago.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jan 26, 2013, 11:54 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Originally Posted by robschonk View Post
Got me thinking....
Whatcha think?
Super Caps only put out a very small current for a long time... you could parallel a few to get what you want but might be better to have that and a standard cap, they will compliment eachother (one for short busts of energy, one for a slow brownout)
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Jan 27, 2013, 11:30 AM
robschonk's Avatar
Joined Sep 2012
Chris
Here's a bank of 2400 F super caps for cranking a Diesel engine. Of course you'd need a half scale model to carry it....
http://www.ebay.com/itm/Ultracapacit...item460be9fc94
I used to use one of those computer caps the size of a coke can across the power leads of a loran unit on my boat to keep it from loosing its lock when I cranked the engine.
Old Jan 27, 2013, 11:51 AM
chanyote66's Avatar
Joined Dec 2011
Yes, With enough farads it will produce enough power to do what you need. Their intent was to replace batteries for cmos and other sensitive devices. You can do it but will the weight out weigh the performance?
Just a note... running capacitors in series (just like our Lipos) will decrease the capacitance. For example, that video used 6x 2500 F cap's, each time they double it cuts the capacitance in half, so...
Two caps makes it drop to 1250 F
Four caps makes it drop to 675 F
So 6 caps is somewhere around 400-500 F (much lower than advertised)
You have me thinking more now... going to start searching for some 10uf+ 6v+ supercaps that are reasonably small...
Heres what i found... Running these in parallel can give you some nice power! .33f per 1g with a 1000c discharge rating! Ill probably order 20-40 of them for testing Id love some backup system on my SSS
http://www.all-battery.com/55v033cap...pacitor-1.aspx
40g of these gives you 13.2f at 5.5v
Chris
Old Jan 27, 2013, 12:07 PM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
Just a note... running capacitors in parallel (just like our Lipos) will decrease the capacitance. For example, that video used 6x 2500 F cap's, each time they double it cuts the capacitance in half, so...
Chris
Chris this is incorrect - in parallel they add...they drop in series.
jer291113 is offline Find More Posts by jer291113
Old Jan 27, 2013, 12:19 PM
chanyote66's Avatar
Joined Dec 2011
ya... I corrected that while you were typing...
Old Jan 27, 2013, 04:21 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Chris
Hmmmm, 2400 F, 2500 F? How about 2600 F? That's what is printed on the label on those things. Not that it is really all that big a difference!
Those little super caps are about 1/4 by 3/8 inch. Forty of them plus whatever they are mounted on is going to make a pretty fair sized bundle, and weigh slightly more that 40g in the end. But one or two in parallel with that little Turnigy cap mentioned a couple of pages back might be useful. http://www.hobbyking.com/hobbyking/s...Protector.html
Gord
Gordks is offline Find More Posts by Gordks
Old Jan 27, 2013, 04:36 PM
chanyote66's Avatar
Joined Dec 2011
Gord
ya, Im not planning on using that many... after some testing with cap's around the house I figure that 5-10 of them paired with about 1000uf standard cap would work great! and im not mounting them to anything... just solder them all directly together epoxy and shrink wrap em...
Chris
Old Jan 27, 2013, 04:48 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Chris
once you get it tested and figured out let us know, i'd definitely be interested in hearing your results
CrashAffinity is offline Find More Posts by CrashAffinity
Old Jan 27, 2013, 05:20 PM
chanyote66's Avatar
Joined Dec 2011
Will do... They probably will be here late this week.
Old Jan 27, 2013, 07:00 PM
robschonk's Avatar
Joined Sep 2012
They come in all shapes, sizes and ratings.....
http://www.ebay.com/sch/Business-Ind...uper+capacitor
Old Jan 27, 2013, 07:18 PM
G-LO is online now
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
That's fpv lingo. That's another language to me...
Its cameras just to look at the ground from the sky?..
......ok, I'll be quiet
G-LO is online now Find More Posts by G-LO
Old Jan 28, 2013, 02:11 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Thoughts???
It seems like there are a lot of good ideas on capacitor configurations here. What is a plausible max for size/weight/value/etc. I would think that there is some point that adding any more size/weight/value/etc would be counter productive or adds no more protection. Anybody have any guidelines on this.
FWIW-I use THIS one on my larger (and 6+ chs) planes with no problems. But, is it enough? I know, I know, that is the one that Boopidoo (sp?) suggests. I wonder if he has any thoughts on this?
AJ
P.S. Where I am heading is like LiPo's. Somewhere along the way, the weight of LiPo's used will cause less flying time rather than more. How to apply that logic to spike protection is the mystery for me.
Old Jan 28, 2013, 03:20 AM
boopidoo is online now
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
The cap is not to be used as a backup power but rather to handle high current spikes. Therfore I don't think larger caps then the one sold on HK is necessary.
boopidoo is online now Find More Posts by boopidoo
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
