Usa hk bec
Here is what you want. It has no known noise problems and please do not add anything (diodes, Capacitors, etc.) to the existing circuitry. It is totally unnecessary.
http://www.hobbyking.com/hobbyking/s...arehouse_.html AJ |
USA, CA, San Diego
Joined Apr 2007
Given how well the Hitec system has been working, I am now putting BECs only on my larger planes where I expect lots of servo load. |
SSS uses 6 servos
![]() AJ |
![]() It was a decision between Futaba and Hitec and at the last minute I went for Futaba as the Hitec RX antenna kind of put me off. Petty I know ![]() However. I only use 6 channel units so no major funds needed. If the Futaba system works OK I'll hang on to it but may consider a hitec unit in the future. I really like their features even on the 6 channel TX. ![]() It has everything there as standard for crow braking on the SSS. |
Initially I installed external BEC's to remedy the lockout / brownout issues but the overheating of the ESC's is not something I had considered was a factor due to the BEC working hard to power the servos. Good call on that ![]() Especially as you say on the SSS |
Silliness
. You gave me back a channel. Well, done. Thanks again.![]() AJ |
A brief word about using a 4S on a stock SSS
![]() AJ |
No problemo ![]() I notice that the Optic 6 Hitec radio has the dedicated facility to induce crow built into it's mixing. Sadly the Futaba 6EX is a little less able to do such a thing. good radio so far but not with the complexity of mixing possibilities as the Hitec. I can do it by playing with the mixes and using flaperon but so far I've not got crow set on the SSS. |
Question for all - But a little OT
I have a Hacker X-7 (actually 2). Here is my problem - I fly a 3 channel plane around and occasionally, it will lock out the motor (the controls still work fine). After having it happen many times, I try to fly in somewhat close overhead and push the throttle to zero. I hear a fairly loud "BeeP" and the motor works again. It does this with both ESC's. After swapping everything many times, it comes down to everything works great with no problems if I use a 10A ESC. I several know low amp draw servos and no change. I monitored all changes with a watt meter and I am not exceeding the 1A rating of the ESC. So, the obvious problem is the ESC's (2). Does anyone have any idea what is going wrong with the insides of the unit?
![]() TIA AJ The reason I ask is because I would like to "fix/modify" the ESC's to work properly just to learn something new. |
Now my RTH or ARF Horizon Hobby planes use the stock internal BEC. For me, it boils down to how much $$ I have into the flying apparatus and/or how much time I have in building it. Early on, I went through this exercise enough to drive me crazy. |
| Thread Tools | |
| Discussion Banana Hobby BlitzRCWorks Sky Surfer | JoshB | Electric Plane Talk | 12 | Feb 14, 2012 11:01 PM |
| Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set | cutty01 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 16, 2010 03:16 PM |
| Discussion BlitzRCWorks Sky Surfer Aerobatic | Flench | Beginner Training Area (Aircraft-Electric) | 4 | Feb 13, 2010 03:17 PM |
| Discussion sky surfer powered parachute $29.95 w/ Free shipping | interplanet | Hot Online Deals | 26 | Dec 30, 2008 10:58 PM |
