Old Jan 22, 2013, 07:47 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Originally Posted by ajbaker View Post
You are trolling too. and yes. All of your posts had nothing to do with the SSS. After all, you don't even own one. Buy one and then you can join the rest of us and contribute relevant posts.
I don't own one either but have been watching and commenting on this thread because I am considering buying one, and because some discussions concern universal RC issues. Are readers not allowed to post until we have one?
kaptondave is offline Find More Posts by kaptondave
Old Jan 22, 2013, 07:48 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Servo retainer for SSS
Originally Posted by Little-Acorn View Post
<SNIP>
Pictures show the plug epoxied into the fuselage (foam is white, plug is white, hard to see, sorry), the wing installed with the plug hanging down outside the fuselage, plug plugged in to the fuselage, everything works. Bench-tested only, still have to clean up the wiring inside and make it pretty.
I haven't had any problems with the plugs on my regular Sky Surfer coming out in flight... yet. May put in a retainer some time.
+1. nicely done. I did somewhat the same thing. I just used two 3-pin connectors to avoid soldering. What would you use for a retainer? The only one that I am familiar with is a blue plastic one from RCTimer. Here are a couple of pics. I have used them extensively and never had a connection problem. What you used looks like a little better connection.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jan 22, 2013, 10:07 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
AJ
did the same thing to mine,it is nice to quickly put wings on and off. i used these locking connectors.. http://www.hansenhobbies.com/product...nlpconnectors/
fastfwd is offline Find More Posts by fastfwd
Old Jan 22, 2013, 11:25 PM
EricClark is offline
Find More Posts by EricClark
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Yes. Electric motors are even better low end torque. As a rule of thumb, a tow plane typically needs a power system that is about half again larger than what would be used for a sport plane application.
Copied from THIS article.
FWIW-I have a Micro Telemaster and a mini-telemaster. I use the mini to tow my sons Slow Stick slope glider. But, that is an extremely light plane to tow and the mini has much more power than needed. I hope some of this helps you.
AJ
Good article, thanks.
Also, thanks to everyone else who replied to my question about tow planes, I appreciate the help.
Eric
EricClark is offline Find More Posts by EricClark
Old Jan 22, 2013, 11:28 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
@Little-Acorn
I too use this method to connect servos. I either use standard servo connectors or MPX-connectors if I have many servos/equipment in each wing. I don't use locking connectors because I've never had a problem with connectors coming loose. However I use strain relief on all cables so when the wing flex it doesn't tug on the connector.
If only a locking connector is used without strain relief there's a risk of damaging the cable or connector in other ways when the wing flex.
boopidoo is offline Find More Posts by boopidoo
Old Jan 22, 2013, 11:32 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
hmmm... one of those 12 pin connectors would take care of my servos + my LED lights thanks for that link i'll have to order some up
CrashAffinity is offline Find More Posts by CrashAffinity
Old Jan 22, 2013, 11:33 PM
Canada, AB, Calgary
Joined Nov 2012
post away! this is a discussion about the SSS, not just owners of
Old Jan 22, 2013, 11:34 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
That is a good point.
When I used locking connectors the wiring had an extra inch of wire and the body had 4 inches of spare...
My wings were connected with a 6 position latching connector:
Pin 1 - Ground
Pin 2 - 5v for Servos
Pin 3 - Flap Signal
Pin 4 - Aileron Signal
Pin 5 - 12v to Wing lights
Pin 6 - Ground
My new plane will be the same except the second ground will be 12v to the flood lights.
and it will have another 3 pin latching for the RX in one wing and the VTX in the other...
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Jan 22, 2013, 11:36 PM
Canada, AB, Calgary
Joined Nov 2012
Pin 1 - Ground
Pin 3 - Flap Signal
Pin 6 - Ground
Chris
i like this pinout, on one side i can stick with a 6 pin and on the other i may have to go with the 12 pin where i've got the vtx mounted, but it will still make transport that much easier
Old Jan 22, 2013, 11:38 PM
chanyote66's Avatar
Joined Dec 2011
Ya... I havent installed the new ones... May go with 7 or 8 pin so i can combine the video equipment in there as well...
Chris
Old Jan 23, 2013, 10:18 AM
jwellsy is offline
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
fastfwd, thanks for that link, just ordered 10 sets of 8 pin connectors.
jwellsy is offline Find More Posts by jwellsy
Old Jan 23, 2013, 12:17 PM
BldrFlyr is offline
Find More Posts by BldrFlyr
BldrFlyr's Avatar
United States, CO, Boulder
Joined Nov 2012
Originally Posted by bakchos View Post
I always do all my connectors and solder myself, if you want to keep the connector, just cut the servo wires, solder a new length of servo wire and resolder the stock connector,
I never trust the extensions.
I build my own extension. I used these multiplex connectors at the wings to connect the fuse/rx cables:
http://www.espritmodel.com/multiplex...rs-5-pair.aspx
They have 6 pins so you can gang up the flap and ail servo wires into one connector.
BldrFlyr is offline Find More Posts by BldrFlyr
Old Jan 23, 2013, 12:18 PM
BldrFlyr is offline
BldrFlyr's Avatar
Joined Nov 2012
SSS FPV at Red Rocks
Here's a nice cruise above Red Rocks.
Super Sky Surfer at Red Rocks (9 min 12 sec)
Old Jan 23, 2013, 07:53 PM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
Awesome video! I lived in Littleton (Ken Caryl Ranch) from '77-'91. Spent a lot of time climbing around the footlhills (Hogback as we called it),saw a few concerts at Red Rocks and went to Bandimere quite a bit for the high school drag races. That scenery brings back a bunch of memories.
road_rascal is offline Find More Posts by road_rascal
Old Jan 23, 2013, 10:24 PM
guaglione87 is offline
Find More Posts by guaglione87
Team Armattan
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
I have round about 4 flights under my belt on the SSS. I can barely get it off of the ground with a 3s 4000 mah. With my 4s 4000mah, she is a dream to fly. I've got the align 70A ESC on it, which gets a bit warm, and hot if I am WOT for too long, so I've got to put some vent holes in this. I open to any ideas as to where or how to put holes in it. My esc is sitting on a side of the ledge behind the battery.
Picture 1 shows my custom paint (model masters camouflage grey and krylon clear) Pic 2 is the fpv mount I've made. Wont be doing FPV until atleast a dozen flights. Pic 3 is for fun, my Bixler with new paint and FPV setup.
4S is the way to go with this plane it seems... overall with the cg on, its really nice and easy to fly. I also have fiber tape over the wings and a little below the wings. Outside of that, its stock. Ill be throwing my UHF on there, and hooking up the nova osd when i get comfortable with the system on the bixler, and we'll sit back for some nice long rides
guaglione87 is offline Find More Posts by guaglione87
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
