Old Jan 21, 2013, 02:13 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Originally Posted by ajbaker View Post
And that contributes exactly what to the SSS thread? Have you ever used PM's?
Sure I have, have you?
The contribution was that this kind bullying behavior might be stemmed if pointed out. Lurkers such as me (in this thread) have every right to give my opinion in something that ruins an otherwise good and informative thread. It is an open forum after all but it's sad when some think their opinion is worth more than others.
boopidoo is offline Find More Posts by boopidoo
Old Jan 21, 2013, 03:22 AM
EricClark is offline
Find More Posts by EricClark
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
+1
On another note, has anyone tried towing the SSS? I know its powered, but I'd like to do it just for fun. Any recommendations?
Eric
EricClark is offline Find More Posts by EricClark
Old Jan 21, 2013, 03:43 AM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Well it should be possible if it's not too heavy. What tow plane did you have in mind?
Old Jan 21, 2013, 10:49 AM
onco11 is offline
Find More Posts by onco11
Joined Jan 2013
Trying to find out if the standard sky surfer or the super sky surfer would be better for a "first" plane having NEVER flow rc before or used a sim. Advise welcome.
onco11 is offline Find More Posts by onco11
Old Jan 21, 2013, 10:51 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Go with the standard...
The super is nice but it takes room and is a little less forgiving...
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Jan 21, 2013, 11:18 AM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Experts, i need your help with a couple of questions i have:
1. what is the general consensus on what the best prop is with the stock motor / 3S battery to get max FPV efficiency? by efficiency i mean max meters covered per amps consumed to get long range coverage. Don't care about speed or power. Just miles per gallon so to speak
2. I would like to move the elevator servo to the tail for better reliability. I am planning on also swapping the servo to a Hitec HS-85MG i have sitting around from an old plane. good idea? is there a better more reliable servo choice? the elevator servo is really the one i can't have fail on me in the air so any advise here is greatly appreciated!.
3. Even though i do gentle FPV / no aerobatics, is it still a good idea to beef up the wing root area on the fuse below the motor? should i skip this and save weight?
4. anything i need to do to ensure a reliable long range FPV platform?
Thanks a lot guys!
By the way, i've done 12km fpv round trip at 2700mah consumed so far with this awesome plane.
compuatic is offline Find More Posts by compuatic
Old Jan 21, 2013, 01:25 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Thanks a lot guys!
i used an 8x8 apc E prop on stock motor and it worked fine, Hitec servos seem to be top of the line,although i have never used them. i think some nylon reenforced tape on fuse wing area would be enough.just my 2 cents worth
fastfwd is offline Find More Posts by fastfwd
Old Jan 21, 2013, 01:32 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
compuatic, I've mounted a #16 keychain cam on a few model planes, but have never done real FPV.
I've looked at some of readymaderc.com's stuff, but know very little about it.
What kind of R/C system did you use to control the plane that far away?
And what kind of video system (camera, transmitter, receiver, viewing device) did you use to get the video from the plane, back to you on the ground? What frequency, how many mW transmitted power?
Inquiring minds want to know!
Little-Acorn is offline Find More Posts by Little-Acorn
Old Jan 21, 2013, 03:01 PM
fastfwd is offline
Joined Mar 2012
i been thinking about FPV also, here are some links. http://www.fpvpilot.com/Pages/GettingStartedinFPV.aspx, http://www.bevrc.com/new-fatshark-predator-v2_p331.html, http://fpv-community.com/testblog/
Old Jan 21, 2013, 04:29 PM
BldrFlyr is offline
Find More Posts by BldrFlyr
BldrFlyr's Avatar
United States, CO, Boulder
Joined Nov 2012
SSS Ruby FPV flying the shoreline
Here's a nice flight this weekend with the SSS.
SSS FPV winter reservoir shoreline (6 min 28 sec)
BldrFlyr is offline Find More Posts by BldrFlyr
Old Jan 21, 2013, 06:41 PM View Post
ajbaker
A moderator felt this post violated the following rule: Trolling (Provocation). It is temporarily hidden while ajbaker edits it. Show it to me anyway.
Old Jan 21, 2013, 06:44 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
problem
Hmmm.... Do you even know how much an SSS weighs? Do you even own one? If so, proof please.
ajbaker is offline Find More Posts by ajbaker
Old Jan 21, 2013, 07:13 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Must be high desert
Nice video. It climbs out really well. Very smooth flying. Were you flying it with your FPV? That reservoir looks like a nice place to swim (for a polar bear). What prop did you use with the 4s LiPo? Did you have the upgrade installed when you made the video?
AJ
Old Jan 21, 2013, 09:30 PM
AMA - 734492
EricClark's Avatar
United States, MT
Joined Mar 2007
Well that is what I'm unsure of. My SSS should weight around 5lbs AUW but I don't know what kind of power/weight ratio the tow plane should have to the glider. Just curious if there was a "rule of thumb" out there for tow planes.
Eric
Old Jan 21, 2013, 10:35 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Eric
Off the top of my head, i'd say you need about 400 watts on the SSS to take off smoothly, so if the tow plane has at least that extra available for thrust on takeoff, it's a starting guideline
CrashAffinity is offline Find More Posts by CrashAffinity
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
