Old Dec 12, 2012, 11:03 AM
UAVJOE is offline
Find More Posts by UAVJOE
Sr. Ext. UAS Pilot, NMSU FTC
UAVJOE's Avatar
United States, NM, Las Cruces
Joined Feb 2012
Sss
I want to make sure that this is clear. I have attached pictures of the plane post crash.
Background:
I am an experienced Aero-modeler and a professional UAS/UAV pilot. I have 22 yrs in R/C and 7 yrs in UAV operations and UAS Safety Analysis. I am also a Commercial Pilot and currently earning my Aerospace Engineering Degree.
I did question the linkage and that is the reason for adding the support at the pushrod exits near the tail surfaces.
Final:
The plane did fly good. I enjoyed the stability and the hauling capability. I am not trying to bad mouth anyone or any company. I'm just trying to put facts out from my experience with the airframe and with past dealings with the distributor.
UAVJOE is offline Find More Posts by UAVJOE
Old Dec 12, 2012, 11:09 AM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Background:
Final:
Ouch, i haven't seen a wire bend at the servo like that, since you reinforced the back side there wasn't enough give left to prevent the failure at the front with the thin wire, good lesson for the rest of us.
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 12, 2012, 11:20 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
There was no offense taken on my part
Banana Hobby has been questionable in their workings, This plane however, they have been activly modifying to correct issues. Maybe soon we will see the control rods upgraded.
Hopefully your electronics and FPV gear can be salvaged.
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Dec 12, 2012, 11:24 AM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Originally Posted by chanyote66 View Post
KK fully setup and ready to fly!
http://www.youtube.com/watch?v=zJaQwFBsJds
Fascinating stuff!
chanyote66, I notice that Hobbyking describes the KK2.0 as being designed for multicopters. Do you have to flash it with new firmware to use it in a fixed-wing aircraft like this?
Little-Acorn is offline Find More Posts by Little-Acorn
FlyingGolem is offline
Find More Posts by FlyingGolem
Subsurface flying expert
FlyingGolem's Avatar
United States, CA, Santa Clarita
Joined Oct 2012
This issue has me considering the option of placing the servos in the tail instead. CG shouldn't be a problem as I plan on running quite a few components up front.
chanyote66, would it be possible for you to gen up a simple wire diagram of your setup?
Originally Posted by Little-Acorn View Post
Fascinating stuff!
No, you don't have to but they are available. Check out the KK2.0 thread for info.
FlyingGolem is offline Find More Posts by FlyingGolem
Old Dec 12, 2012, 11:36 AM
chanyote66's Avatar
Joined Dec 2011
Im working on the wiring diagram now.
Those two links are where I found all of my information for my KK setup. OpenAero is a great firmware and HappySundays is almost done with the final release.
Chris
Old Dec 12, 2012, 11:41 AM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
Unfortunately my Adrupilot 2.0 was destroyed, 8000mAh Battery destroyed, and my GoPro in its protective case was destroyed. The only thing salvaged was my receiver.
Chris
Old Dec 12, 2012, 12:08 PM
builderdude is offline
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
That is a good idea. I've done that on a plane of mine. You relocate the servos in the tail and you not only save yourself the very long pushrod lengths, but you also probably tighten up the control accuracy.
In fact, the Bird of Time has the tail servos IN the tail, come to think of it.
builderdude is offline Find More Posts by builderdude
Old Dec 12, 2012, 12:13 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by polix View Post
This is a common problem on a lot of planes, i lost my first radian for the same reason. Any of us who have gone through this reinforce the wire, replace it, or you can redirect the wire to go over the elevator instead of under, then your up elevator is guaranteed (because you're pulling) instead of down
THis was brought up and a fix way early in the thread , we all replaced the rods with bigger ones,as one lost his plane the same way for the same reason.
fastfwd is offline Find More Posts by fastfwd
Old Dec 12, 2012, 12:16 PM
fastfwd is offline
Joined Mar 2012
Background:
Final:
man i am sorry to see that ! Early in this thread that problem was brought up,they are way to small of rods ! We replace them with bigger rods first thing. That really sucks !
Old Dec 12, 2012, 12:37 PM
chanyote66's Avatar
Joined Dec 2011
Heres my diagram...
My Ground is tied at the battery for my Flight bat and my FPV battery.
Description:
Old Dec 12, 2012, 01:00 PM
Joined Oct 2012
Thanks for that.
Old Dec 12, 2012, 02:21 PM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Background:
Final:
real sorry to hear of the crash... not only is it a serious downer to lose a plane, not to mention all the goodies, but the time dedicated to the build and then the consequent rebuild
no offence but I am a tad surprised that experienced folks would fly with stock servos/pushrods, especially with expensive gear on board
the stock electrics *may* be ok for a while, if flown with the small recommended flight battery and nothing else, purely a lightship LOS bird only
even my bixlers I relocate the servos to the tail using decent quality rod, clevis & horns eg Dubro, and this SSS is getting even more of these upgrades
also things like I mount my horns on the top of the elev so it further minimizes the risk of bendage because the pushrod is pulling for up elev
please guys, this bird is a damned cheap 2400mm powered glider, you cant expect any degree of quality in the electrics for the money, so IMHO if you intend to fly anything other than LOS, therefore add weight, change out servos/pushrods/clevis&horns/esc... it really makes me cringe when another bird is reported broken due to failure, when it can be avoided
AussieHoppy is offline Find More Posts by AussieHoppy
Old Dec 12, 2012, 03:01 PM
Calla969 is offline
Find More Posts by Calla969
United States, FL, Indialantic
Joined Mar 2012
Looking for opinions. I want to set up a plane for FPV. My goal is to be able to fly for long periods of time and work up to long distance. Can anyone comment on how this plane would compare to the 1900mm Skywalker for this purpose?
Calla969 is offline Find More Posts by Calla969
Old Dec 12, 2012, 03:21 PM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
No offense taken.
This was my first PNP airplane and was under the impression that the manufacture made some attempt to ensure safety. I will no longer look at purchasing PNP models and just get kits as I am use to.
I do know that other people have had issues with this plane and I just want to educate others to its down falls. The plane is of good basic design and I am just sharing my experiences.
Thanks for the insight.
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
