Old Dec 08, 2012, 02:23 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Originally Posted by Little-Acorn View Post
I'd use larger, torquier servos too, if I were you. Some here have found that in a steep dive, the SSS's ailerons no longer respond, though the elevator seems to be fine. Once it levels out and slows, down, aileron response comes back.
I'm not sure why. Maybe the stock servos aren't strong enough, or maybe the wings are twisting slightly when ailerons are deflected in heavier airstreams, or maybe something else.
If you want to habitually fly at high airspeed (such as flying forward against a STRONG wind), you'll have to change a LOT of things on the SSS. It wasn't really designed for high airspeeds.
It would be pretty easy to velcro a key fob camera to the wing near the root to see what is going on. If it hasn't already been done, I will do that when I get mine in the air. But don't hold your breath. It is winter in the great northwest so we will see rain consistently until late spring. And we have lost our field as well. Although we have a very good prospect for a new one, the land owner is in Florida right now, so I am not in a big rush to finish the SSS.
Gord
Gordks is offline Find More Posts by Gordks
Old Dec 08, 2012, 02:53 PM
Gordks is offline
Joined Mar 2010
Originally Posted by polix View Post
need some advice on reinforcing the flaps and ailerons.
I hate these pressed moulds with no reinforcement, and eventually these are going to rip off.
I have a ton of glass cloth here (a result of one of my drunken ordering sprees i imagine), and i had great success using it to reinforce my icon a5 using CA.
Thoughts on using strips of glass cloth dipped into the recesses with an inch before & after the flaps / ailerons? I know it would hold, i'm just looking for a long term strong solution.
I had some control surfaces that were starting to separate on my HK 2M Minimoa when it was brand new. I used canopy glue (J & Z Super RCZ56) on the separations. There has never been a problem with those surfaces since. The glue is as flexible as the foam or more so and it sticks to that foam as well as anything I have ever tried. It is a bit hard to see, but there is an highly reflective area along the obvious separation in this photo (zoom in). That is the glue. It could be used all along the length of the hinge I suppose. Keep it thin though or it might stiffen the hinge a bit. But not any more than reenforced packing tape I would bet. And it will stay clean forever instead of starting to look grubby as the packing tape, or even more so, hinge tape, often does. It's good stuff!
Old Dec 08, 2012, 03:01 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
ah, thanks for the tip, i may just go this route instead
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 08, 2012, 04:12 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
If/when my flaps decide to part company with the wing (hopefully on the bench, not on short final), I may try to set them up as Fowler flaps. Such flaps have a LOT more effect, which this plane could use. They basically increase the wing area when you deploy them, and the slot in front causes them to increase lift a LOT more... meaning you can slow down a lot more without falling out of the sky. See the fourth example, at the bottom. Will take some work, but what's a mother to do.
Little-Acorn is offline Find More Posts by Little-Acorn
Old Dec 08, 2012, 08:44 PM
rwj is offline
rwj
Find More Posts by rwj
rwj
Joined Dec 2011
Stock out of the box
does anyone else have a problem deploying the flaps with the supplied esc and a 3s 3600mah battery?
rwj is offline Find More Posts by rwj
Old Dec 08, 2012, 08:45 PM
Canada, AB, Calgary
Joined Nov 2012
i'll let you know when i do my maiden, though i'm replacing the stock with an 85 amp esc that i have kicking around =)
Old Dec 08, 2012, 08:50 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
what do you mean ? Mine had to be set down to like 50% in my endpoints or they would bind and chatter.
fastfwd is offline Find More Posts by fastfwd
Old Dec 08, 2012, 09:20 PM
San Diego, CA
Joined Dec 2006
Mine did that on a 3s battery. So I shortened the pushrods and leaned the servo arms back (toward the flaps) about 40 degrees when the flaps were up. It helped somewhat. But I still have the feeling the servos are putting out their maximum power to get the flaps down at normal flight speeds.
I now believe that a better solution, instead of shortening the pushrods, would be to lean the servo arms back (as I did) and also move the control horns on the flap surfaces, back around 1/2" or 3/4".
Old Dec 09, 2012, 10:27 AM
robschonk is offline
Find More Posts by robschonk
robschonk's Avatar
United States, NC, Avon
Joined Sep 2012
Quiturbitchin posted some fairly simple fowler flaps on another thread using Robarts hinges.
robschonk is offline Find More Posts by robschonk
Old Dec 09, 2012, 12:25 PM
San Diego, CA
Joined Dec 2006
Yep, that's the idea, great job!
Actually those are closer to the "slotted flaps" shown in the diagram. To turn those into simple Fowler flaps, the Robard hinges would have to be longer (or something long and homemade would have to be fabricated) so that the flaps moved farthe back as they deployed; and a sort of "roof" made (say) of thin plywood would have to be glued to the top of the wing, extending over the flap.
But he's definitely on the right track.
Old Dec 09, 2012, 05:24 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
... a sort of "roof" made (say) of thin plywood would have to be glued to the top of the wing, extending over the flap.
Do you know what hinge tape is? I have some that is like a strip of thin rigid plastic that has adhesive backing along one edge. That would form the roof you are talking about.
kaptondave is offline Find More Posts by kaptondave
Old Dec 09, 2012, 05:31 PM
Joined Jan 2010
Robart makes a true Fowler hinge set but they are giant scale and expensive.
http://www.robart.com/products/fowle...hinge-15-scale
Old Dec 09, 2012, 07:27 PM
Gordks is offline
Joined Mar 2010
That is fairly similar to the flaps on a Multiplex Funcub. They do slow it down quite effectively. Particularly when set up to drop 90 degrees. And then add in crow and it can be aimed straight down without gaining much speed at all. Great fun!
Gord
Old Dec 10, 2012, 10:23 AM
jwellsy is online now
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
Originally Posted by eckace1 View Post
Was also woundering what the largest size prop that will fit without cutting the boom.
Has anybody measured how far it is from the motor shaft centerline to the top of the fuse?
I pulled the trigger and ordered a SSS this morning. I hope to have it ready to fly on our Jan 1st New Years Day fun fly. I would normally wait till the plane arrives and measure things myself, but to be ready for Jan 1st I need to get stuff ordered. I want to get a bunch of CF rods ordered to reinforce the fuse, stabs etc.
What's the diameter of the spar tube?
What's the thickness of the horizontal and vertical stab?
jwellsy is online now Find More Posts by jwellsy
Old Dec 10, 2012, 10:36 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
The stock motor position can only fit a 9" prop without modification. Getting a motor that has a 10mm longer bell can bring it out enough to throw on a 10" prop
The Spar is 0.5" it can be replaced by a carbon one from Goodwinds.com and get much more strength. Here is the Carbon Rod Specs
Part--------Diameter-length- ID------OD mm---------Weight----Price
020034 .5000" 60" 0.400" 12.70mm 110 gm $19.99
I dont have my plane in front of me, but 2mm carbon would work great in the stabs. or getting flat carbon that is .5mm x 2mm would be lighter and easier to place in the wings.
Chris
chanyote66 is offline Find More Posts by chanyote66
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
