Old Nov 30, 2012, 05:10 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Originally Posted by chanyote66 View Post
my initial calculations was 90 min after a 5 min climb at full power.
Now i have to change that because it climbs nice at half throttle and cruises at 1/4 throttle...
Ill calculate more once I find how much its actually using...
Chris
I'll be insanely happy if i can get 45 mins =)
Now i'm gonna go setup a new base station and play with my new pocket DVR =)
CrashAffinity is offline Find More Posts by CrashAffinity
Old Nov 30, 2012, 05:17 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
ya, I have a DVR, camera, 7" screen, low light lens, and video switcher coming for christmas... cant wait!
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Nov 30, 2012, 06:35 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Chris
This thing will climb in a very light wind when going into it, i always have to give down elevator to keep from climbing ,even under no power, I think it is due to the extremely wide wings And on landing i also have to give it down to get it to land even with flaps down, it will glide forever !
fastfwd is offline Find More Posts by fastfwd
Old Nov 30, 2012, 10:35 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Chris
The calculations I have thus far come to are about 2 hours potential endurance time using 4S and 5000mah, though honestly I think it may be a bit better then that after watching a bit more FPV footage from others. Sofar I have flown mine a few times now, I clocked about 35 min in the air on a full battery charge and it still had about 40% left and I was cruising around between 1/4th to 1/2 throttle most of that flying.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Nov 30, 2012, 10:41 PM
Canada, AB, Calgary
Joined Nov 2012
Do you think i'd get a big hit in endurance if i stuck to 3S? I'm not looking at fast performance, just endurance.
Old Nov 30, 2012, 10:47 PM
chanyote66's Avatar
Joined Dec 2011
for endurance you will get better results with 4S...
The higher the voltage you use, the lower your amp draw will be for the same power.
Chris
Old Nov 30, 2012, 11:02 PM
Canada, AB, Calgary
Joined Nov 2012
Chris
True, though on larger batteries a 4s would be roughly 33% heavier for the same mAh no? This part always confuses me... i'm just gonna have to test it on 3s first or not be lazy and search through the forums =)
Old Dec 01, 2012, 11:10 AM
keok is offline
Find More Posts by keok
A wing and a prayer
keok's Avatar
United States, OK, Oklahoma City
Joined May 2010
well here it is! Actual maiden... no test flights or anything... this plane is way too hard to fly, lol...
http://www.youtube.com/watch?v=Fl6O7NLgxTY
Congratulations on the succesful maiden.
Dont you just love how it floats out of your hand?
keok is offline Find More Posts by keok
Old Dec 01, 2012, 04:18 PM
MrBob47 is offline
Find More Posts by MrBob47
Joined Dec 2012
I just received my Super Sky Suffer from BH, Their are several enhancements that have been made to the wing and tail spar. their is now an internal tube that the wing spar fit's into. as far as the shipping goes, the only cost was $10.00 and that covered the extra cost of the 5' tall package.
MrBob47 is offline Find More Posts by MrBob47
Old Dec 01, 2012, 06:30 PM
chanyote66's Avatar
Joined Dec 2011
well test results are in...
Flew 40 minutes (Ran out of daylight) with some mild acro... a few loops, and vertical climbs but mostly cruising around.
Used 2159mAh of my 2x 2650mAh 4S packs
Calculating that out to full battery usage I get 98 minutes of flight.
Im going to need to invest in a comfortable Ground station setup!
Setup: All stock except ESC (Turnigy Trust 45A w/ SBEC) and Batteries (Zippy 20c 2650 4S)
Chris
Old Dec 01, 2012, 06:33 PM
Canada, AB, Calgary
Joined Nov 2012
Flew 40 minutes with some mild acro... a few loops, and vertical climbs but mostly cruising around.
Calculating that out to full battery usage I get 98 minutes of flight. Removing the full throttle passes and loops Ill probably gain a few more minutes!
Chris
That is an insane flight time! i'm tired of only getting 12 minutes on my bix =)
Thanks for going to the effort of getting the #s and posting them here!
I think i better go camp outside the post office until my plane shows up... should be within a few days!
Old Dec 01, 2012, 07:10 PM
rwj is offline
rwj
Find More Posts by rwj
rwj
Joined Dec 2011
How do you get at the screws out of the servo arms without screwing up the foam? They do not give us any room. Also I purchased the arf version, what is the largest battery I can buy that would still work with the stock esc?
rwj is offline Find More Posts by rwj
Old Dec 01, 2012, 07:14 PM
fastfwd is offline
Joined Mar 2012
use a long handle screw driver to get at the inside servo screws,(wont hurt to even put a small hole from top down to screws) i put in a 50 amp esc with 4 amp bec as the stock one isnt enough to handle flaps,i am now using a 3s 5000mah battery
Old Dec 01, 2012, 07:19 PM
chanyote66's Avatar
Joined Dec 2011
Ya, it was a great flight... cant wait to FPV this thing!... Im building the FPV pod now...
But remember... every setup can be different... even with the same parts. So test your setup before going far or taking it to its limits!
Chris
Old Dec 01, 2012, 07:20 PM
rwj is offline
rwj
rwj
Joined Dec 2011
Ok thank you
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
