Old Nov 18, 2012, 11:33 AM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
No, he didn't have the wrong equipment, he did the best he could with what he had. Fpv camera is the wrong equipment if you ask me... Well, a few low passes wouldn't hurt tho.
Anyway, Fastfwd did you reverse the shaft on you 1450? I got mine in yesterday and tried to reverse it after backing out the grub screws but couldn't. Should I give it a good wack? I didn't want to damage my new motor. Can you help? Thanks
G-LO is offline Find More Posts by G-LO
Old Nov 18, 2012, 02:10 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by Little-Acorn View Post
Sweet video!
How's the climb?
The SSS is a powered glider, of course, and was never intended to be a racer or stunt plane. But the ability to get upstairs without worrying about minimum airspeed, or having to cover a lot of ground doing it, is handy at times. This was the reason I put a large motor in mine. I'll bet yours is the same way. Got any shots of it climbing?
climbs great now,i chickened out when it headed for the clouds
fastfwd is offline Find More Posts by fastfwd
Old Nov 18, 2012, 02:12 PM
fastfwd is offline
Joined Mar 2012
i didnt change anything on that motor,just installed it and flew ? I did have to bore out the prop to correct size though
Old Nov 18, 2012, 02:18 PM
fastfwd is offline
Joined Mar 2012
Originally Posted by Gordks View Post
So still 3S, right? Have you checked to see how many amps that is pulling? That 9x5 might be just about the limit. Some 'Pro contributer' posted that a 9x7 would pull 60 amps and a 9x4.5 would pull around 45. The motor is rated at 45 MAXIMUM and of course that could not be done for very long without overheating it. Looks like it could be a pretty good choice since it is really light.
Gord
Have not put the watt meter to it yet (Have yet to solder on plugs), but with two full throttle climbs into clouds,and then running around half throttle,esc,battery and motor are not even warm to touch. last flight i did was around 10 minutes
Old Nov 18, 2012, 02:45 PM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
So pretty much you used the collett hardware that came with it? (I just didn't want to assume)
Old Nov 18, 2012, 08:17 PM
fastfwd is offline
Joined Mar 2012
yes i did use the hardware that came with motor.
Old Nov 18, 2012, 09:48 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Just wanted to know, what direct fitment upgraded motor for this SuperSS?
Will I need a special motor mount like this one?
http://www.readymaderc.com/store/ind...roducts_id=748
p.s.
can you guys give LINKS to what best power combo you guys are using?
(motor/prop/etc.....) I have a bunch of 4s-5000mah Lipos here to use:-)
was planning on using (~135grams) Scorpion 3014 v2-~1200kv motor, APCe 9x6 prop.
rclab1 is offline Find More Posts by rclab1
Old Nov 18, 2012, 10:27 PM
fastfwd is offline
Joined Mar 2012
p.s.
. http://www.hobbyking.com/hobbyking/s...dProduct=18226 This is motor i put in, it bolts right in wont have to do anything to it. I am using 3s 5000mah 35C lipo,a 50amp esc with 4 amp bult in bec and a 9x5APC E prop. stays quite cool and will climb almost vertical.
Old Nov 18, 2012, 11:31 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Emax BL3526/04 motor http://www.headsuphobby.com/Emax-BL3...otor-A-274.htm
Master Airscrew 10-5 three-blade prop
Hobbywing 100A ESC http://www.hobbypartz.com/07e-flyfun-100a.html
GensAce 4000mAh 5s LiPo battery http://www.hobbypartz.com/98p-25c-4000-5s1p.html
This motor is not quite a bolt-in. The motor is 44mm in diameter, larger and longer than the stock motor, so I had to hollow out the motor pod to make it fit, and trim and re-drill the cross-shaped motor mount that came with it. See pictures here:
http://www.rcgroups.com/forums/showt...6#post23131125
And a video of it in flight here:
http://www.rcgroups.com/forums/showt...3#post23209486
It flies very nicely, does the long-slow-majestic-soaring-flight stuff that these SSSs look so nice doing. It will fly for half an hour easily, doing the usual gentle cruises and occasional stunts. It will also climb vertically till it's out of sight if you want it to. (But not for half an hour )
It's still a powered glider and always will be. But being able to get upstairs quickly is handy sometimes.
Fun, too.
Little-Acorn is offline Find More Posts by Little-Acorn
Old Nov 19, 2012, 05:06 PM
keok is offline
Find More Posts by keok
A wing and a prayer
keok's Avatar
United States, OK, Oklahoma City
Joined May 2010
Maiden Alert
Completely stock exept for 8X6 APC prop.
Sit close to the screen and your left eye will enjoy departures while your right enjoys arrivals
Super surfer maiden flight (4 min 47 sec)
keok is offline Find More Posts by keok
Old Nov 19, 2012, 05:32 PM
robschonk is offline
Find More Posts by robschonk
robschonk's Avatar
United States, NC, Avon
Joined Sep 2012
p.s.
I was wondering about this mount. I'm looking for a platform to haul cameras and batteries aloft for FPV, and was researching the Bixler 2, when I stumbled across the SSS a couple of days ago, and have been wading through 110 pages of posts. A lot of the Bix 2 folks are using this mount to upgrade their motors due to the size of the nacelle. The mount will allow you to mount the motor an inch higher, which would allow a 2" larger diameter prop. That might even allow you to put the ESC in the nacelle for better cooling. What do you think?
robschonk is offline Find More Posts by robschonk
Old Nov 19, 2012, 05:38 PM
rclab1 is offline
USA
Joined May 2010
You wont need that mount because the SSS will accomodate almost any power combo you throw at it.....(from what I read)....
Old Nov 19, 2012, 06:09 PM
robschonk's Avatar
Joined Sep 2012
But wouldn't a larger dia. Prop with a lower KV motor be more efficient?
Old Nov 20, 2012, 06:54 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Finally got the lighting system installed and the controller board working properly! I still have 2 flood lights to install yet but sofar I am pretty pleased!!!
Testing Super Skysurfer Lighting System (2 min 56 sec)
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Nov 20, 2012, 09:24 AM
fastfwd is offline
Joined Mar 2012
try it should work fine. im not sure how the mount goes on though as the mount on th SSS is buried inside the housing
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
