Old Nov 08, 2012, 12:40 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Originally Posted by AussieHoppy View Post
What is the general opinion on rudder authority- is it effective?
I've been using rudder in those vertical climbs to keep it going straight up, it's been pretty effective for me. The results of rudder commands are quite noticeable. And that's a fairly low airspeeds (good motor, but it's not a rocket )
That said, when the plane is flying level under moderate power (or gliding), a rudder command makes it yaw noticeably... but it doesn't bank worth a nickel, until I apply ailerons too. Meaning, rudder-only turns are almost nonexistent. Probably because the wing has almost zero dihedral, only the tips are curved up slightly.
My $.02
Little-Acorn is offline Find More Posts by Little-Acorn
Old Nov 08, 2012, 12:55 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
So it sounds like on landing you can align the plane to where you want? Or will it just start crabbing?
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Nov 08, 2012, 01:07 PM
San Diego, CA
Joined Dec 2006
Mostly crabbing, but it will slide left or right, sort of, a little.
You really have to turn with ailerons and rudder, but that's more restricted close to the ground obviously. In my video you can see me slaloming my way between the street light poles, the flagpole, and the blue pagoda roof that Hilltop Park has on the approach pattern, while landing. (Don't those children's-park designers know how to set up an airport? ). Slight banks and a lot of prayers. I hooked a wing on one of those streetlight poles once, oops.
Old Nov 08, 2012, 02:49 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Just installed this motor,using a 9x5 prop, i noticed motor mount was a little loose when i took off old motor,it wasnt the mount but the screws that hold it and they are inserted from INSIDE the pod !! What a pain to get at them so i could tighten it up. They wont come loose again as i glued the screw heads to foam.
fastfwd is offline Find More Posts by fastfwd
Old Nov 08, 2012, 02:52 PM
San Diego, CA
Joined Dec 2006
I drilled holes around the motor mount, put in epoxy, then inserted wood dowels 2" long coated with epoxy, and glued them to the plywood of the motor mount.
It's not going anywhere now.
Old Nov 08, 2012, 04:53 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Originally Posted by Fstclyz View Post
Thanks. The sanding/paint/clear coat took a long time but did turn out pretty nice.
What did you use for the clear coat?
kaptondave is offline Find More Posts by kaptondave
Old Nov 08, 2012, 05:15 PM
fastfwd is offline
Joined Mar 2012
In fact how about sharing step by step of the preparing and painting, like materials needed,paint type ect ?? The plane looks GREAT !
Old Nov 08, 2012, 05:55 PM
Fstclyz is offline
Find More Posts by Fstclyz
BldrFlyr
Fstclyz's Avatar
Joined Jan 2012
I sanded the entire plane down with 220, then painted with Rustoleum 2x paint and Montana flat paint. Then clear coated the entire thing with Krylon 10min gloss. Since I had carbon stripes and rods in the foam and CA, I filled those areas with that light drywall spackle. I laminated certain areas as well. TOO MUCH WORK imo.
Fstclyz is offline Find More Posts by Fstclyz
Old Nov 08, 2012, 06:18 PM
Fstclyz is offline
BldrFlyr
Fstclyz's Avatar
Joined Jan 2012
Flight Data
Here's some flight data (watts, current, etc) from different motors and props for reference.
Old Nov 08, 2012, 06:33 PM
fastfwd is offline
Joined Mar 2012
thanks for the info, i think ill pass on all that work,it is just going to get scratched,dented and dinged up anyway
Old Nov 08, 2012, 06:39 PM
chanyote66's Avatar
Joined Dec 2011
Big-ol'-box sitting at front door!!! Finally get to start wiring my beast! Ill probably run a build log to compile all modifications listed that I use and has been mentioned here.
Chris
Old Nov 08, 2012, 06:55 PM
San Diego, CA
Joined Dec 2006
Chris
RTF, ARF, or Kit?
Old Nov 08, 2012, 08:20 PM
Joined Jan 2010
Did you measure the before and after weight of the plane?
Old Nov 09, 2012, 12:56 AM
chanyote66's Avatar
Joined Dec 2011
Originally Posted by Little-Acorn View Post
RTF, ARF, or Kit?
ARF... LED's almost in wing... Had to take some time to remove the spar tubes and re mount them in the wing... They were sticking out about 1/4" so the wing halves wouldnt go together Its all good now... waiting on the .5" carbon spar to come in... This thing they send is more of a weapon than a spar
Chris
Old Nov 09, 2012, 02:54 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Finally got around to getting a nav light installed in a wing! This isn't just any nav light, but a CREE 1 watt LED!
Here is a close up of the install (It consists of a wooden dowel as a mounting base, a piece of copper tube, and the LED mounted on special heatsink PCB, which inturn uses the copper as heatsink, these guys get HOT).
Here is a frontal view:
And finally an underside view where you can see it's full brightness :
Full build log located at http://fpvlab.com/forums/showthread....urfer-Buildlog
NorCalMatCat is offline Find More Posts by NorCalMatCat
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
